RE: GREAT PLANES YAK 54 BUILD THREAD    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: GREAT PLANES YAK 54 BUILD THREAD
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9   next >   >>
Login
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/19/2006 9:27 PM
marmitas
Last Login: 9/14/2011
Status: offline
quote:
ORIGINAL: Machinegun21
Sound good, when i get mine i will prob put a 1.60 on it. can the 1.60 on the yak do full 3d?
I am not good enough to try a full range of 3D but hovering, high alpha flight, climbs form a hover, etc. are no problem. Jason Knoll appeared to have no problems doing a wider range than I'm capable of doing.
Hide Signatures
(in reply to Machinegun21)
       Post #: 51
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/20/2006 7:01 AM
Machinegun21
Last Login: 10/28/2007
Status: offline
Well just keep practicing, you'll get better.
Hide Signatures
(in reply to marmitas)
       Post #: 52
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/20/2006 11:06 AM
I Buy Houses
Last Login: 2/26/2013
Status: offline
Hi,
Just got the plane flying and she is awesome. 9 Flights over the last few days
DA-50 weighs in at 13.9LBS
Li-Ion batteries and Micro throttle servo
Just Tintied the Canopy and it looks great. I'll post a pic here soon.
_____________________________
$20,000 Raffle For Anyone/ 3D Freestyle / IMAC TX ShootOut 9/25/10
http://www.jetero.com/imac.htm
Hide Signatures
       Post #: 53
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/21/2006 12:37 AM
Vlad3D
Last Login: 8/27/2007
Status: offline
Hy guys !
I"m planing to put an mvvs 3.15 in this plane but i don't know if this engine have enough power for 3D manuvers !
What do you think ? It will work ?
Hide Signatures
(in reply to I Buy Houses)
       Post #: 54
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/26/2006 12:54 AM
charlesdanni
Last Login: 12/4/2008
Status: offline
I am going to be getting a DA50 for my GP Yak and this will be my first gasser. Not sure what you mean by cutting a hole in the firewall for the 1" clearance to the carb body? How big of a hole are you talking about and exactly where do you cut it out at. Also do the push pull servo in the fuselage do a good job and did you have any problems setting them up? I am go to need all the help I can get with this DA50.
Thanks to all who reply.
Hide Signatures
       Post #: 55
RE: GREAT PLANES YAK 54 BUILD THREAD - 7/26/2006 9:42 AM
I Buy Houses
Status: offline
Hi Charles,
I did not cut a hole for the Carb and it works fine. I used the Pull Pull set up with just one HD servo JR Z900T Works awesome. I'm using li-ion packs for weight and have them both mounted on the motor box up fornt. The plane flys awesome.
If you have any other questions just let me know.
Hide Signatures
(in reply to charlesdanni)
       Post #: 56
RE: GREAT PLANES YAK 54 BUILD THREAD - 8/9/2006 7:43 PM
charlesdanni
Status: offline
Thanks for the heads up. I was also wondering do I need to put some right thrust in the engine when I mount it. It appears that this is already built in to the fusealage. I have read that you are suppose to keep the batteries at least 12" away fro the electronic ignition due to interference. Have you had any issues with radio interference?
Hide Signatures
       Post #: 57
RE: GREAT PLANES YAK 54 BUILD THREAD - 8/9/2006 8:15 PM
The MacDaddy
Last Login: 4/7/2013
Status: offline
IBH,
Can you put some links in for the batteries and switches you used? How about some pics of the mounting locations?
Mac
Hide Signatures
       Post #: 58
RE: GREAT PLANES YAK 54 BUILD THREAD - 8/9/2006 11:30 PM
I Buy Houses
Status: offline
Hi,
Here is a link for some inexpensive packs they are the same LG cells everyone else uses. http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2732 For switches I use the MPI HD switch and MPI 10 amp regulators.
For mounting I put the Ign battery inside the battery box and the RX pack I have next to the Receiver. I'm a little too tail heavy and would recommend mounting them both on the battery box unless you do a lot of Hovering.
Hope this helps.
< Message edited by I Buy Houses -- 8/9/2006 11:45 PM >
Hide Signatures
(in reply to The MacDaddy)
       Post #: 59
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/18/2006 6:33 PM
mippe
Last Login: 11/20/2011
Status: offline
Hallo
I have buy YAK from GP and i thinking about putting a ZDZ 50NG or 3W 48i B2 in .
Someone who can help me with the choice?
Sorry about spelling i´m form sweden
< Message edited by mippe -- 12/18/2006 10:59 PM >
Hide Signatures
       Post #: 60
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/20/2006 12:08 PM
k_jitsu
Last Login: 4/11/2012
Status: offline
Hi everybody.
I've just got my GP yak and I'm thinking on a DA 50 on it. I'd like someone with this configuration to tell me if any change in right or down thrust is required for this engine. I hate to have to move the cowl after some flights to adapt it to the new position of the engine...
Thanks a lot
Javier
Hide Signatures
(in reply to mippe)
       Post #: 61
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/20/2006 9:47 PM
Kostas1
Last Login: 5/14/2013
Status: offline
Hey,
this question goes to all guys that have assembled this Beauty of sky!
Did you reinforced the firewall?
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
(in reply to k_jitsu)
       Post #: 62
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/20/2006 10:58 PM
marmitas
Status: offline
I did not reinforce ANYTHING and have many flights witout any problem. I'm using an OS 1.60 but people with gasoline motors (DA 50, etc) do not have any problems either.
Don't worry, this plane is NOT built like the CAP 232 from Hangar 9. I had one of those and reinforced most of the airframe because I saw what happened to a friend that did not.
Hide Signatures
(in reply to Kostas1)
       Post #: 63
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/21/2006 12:37 AM
Kostas1
Status: offline
Well,
so that's very good.
Greatplanes's engineers made it AGAIN!
Am,
could you please post some other pics from different views of your Yak 54?
Also,
how possible it is to make a video of it?
Hide Signatures
       Post #: 64
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/21/2006 4:32 AM
maxun
Last Login: 4/9/2013
Status: offline
I you do a gas motor, because of vibration I recomend to got thrue the whole aircraft especially the fire wall, extra glue is allways good.
Hide Signatures
       Post #: 65
RE: GREAT PLANES YAK 54 BUILD THREAD - 12/22/2006 11:03 AM
fingers73
Last Login: 2/3/2012
Status: offline
I am on my second yak, the first went in doing a low high alfa knife and the left elevator servo locked in the neutral position. That plane had the fuji 50 with a bisson muffler and a 3w 20x8 prop. It would do everything you would ask of it. My setup had 1 rudder servo in the tail. the reciever and battery were on the secondary servo tray. The only thing that took a bit to get used to was the rate of descent, very steep needed a little power to not pancake it in. I would land with about a 15 foot rollout. I do not know the weight or the cg I just put it where it needed to be to fly for me. I will say I added no weight to the plane to balance. Plane number two is almost done it will havev a DA 50 for the weight. I found that the landing gear wouldn't hold the plain up very well if it has the heavier engines. In my gallery is a picture of the fuji and the gear splayed out and it is just sitting . It seems the file is to large to post here.
Once upon a time there was a guy and he asked a girl to marry him. She said no, so he lived happily ever after. THE END
Hide Signatures
(in reply to maxun)
       Post #: 66
RE: GREAT PLANES YAK 54 BUILD THREAD - 1/14/2007 11:59 PM
Spynete
Last Login: 3/3/2009
Status: offline
Hey Marmitas,
me encanta ver, desde España como usas nuestro escudo en tus Post.
Hoy he estrenado mi GP Yak 54, gracias por tus consejos, y que sepas que es un lujo para mi poder leer en vuestro Foro consejos desde este rinconcito de España, cuenta con un amigo en en Cabanillas de la Sierra.
Spynete
Hide Signatures
(in reply to fingers73)
       Post #: 67
RE: GREAT PLANES YAK 54 BUILD THREAD - 1/15/2007 1:31 AM
marmitas
Status: offline
Hola Spynete,
(This message goes in Spanish followed with the same content in English)
Muchas gracias por tu mensaje, yo vivo en USA pero mi familia es de Casares de Arbas, Leon. Es un pequeño pueblín más pequeño que el tuyo. Está cerca del puerto pajares. Yo hace 42 años que vivo en USA pero me enorgullezco de mis raices, por eso uso el escudo español en mis mensajes. Marmitas es el apodo que heredé de mi abuelo porque tanto él como yo "explotamos" con mucha facilidad.
Thank you for your message, I live in the USA but my family is from Casares de Arbas, Leon. It is a small village smaller than yours. It is close to Puerto Pajares. I have lived in the US for 42 years but I'm proud of my roots and that is why I use the Spanish seal as my avatar. Marmitas is a nickname that I inherited from my grandfather who, like myself, could "blow-up" easyly.
Un abrazo
Andrés Rodríguez
Hide Signatures
(in reply to Spynete)
       Post #: 68
RE: GREAT PLANES YAK 54 BUILD THREAD - 1/18/2007 12:49 AM
bartoke
Last Login: 3/15/2008
Status: offline
Hey
Does anybody knows if the yak 54 can fly with a titan zg 38cc.
With flying I mean hover and torque rolls and much more.
Or is the titan zg 45cc a better option.
I've heard someone whose horizontal fin was come loose,
do you have the problem too?
thanks Bartoke
< Message edited by bartoke -- 1/18/2007 12:54 AM >
Hide Signatures
       Post #: 69
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/15/2007 1:07 AM
crash99
Last Login: 4/29/2013
Status: offline
What prop should I with a OS 1.60?
Crash99
Hide Signatures
(in reply to bartoke)
       Post #: 70
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/15/2007 9:30 AM
maxun
Status: offline
APC18X4W for 3D
Hide Signatures
(in reply to crash99)
       Post #: 71
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/16/2007 1:02 AM
crash99
Status: offline
OK guys, I am sure there has to be some video out there. I have seen the sales video from GP but I would love to see some of your video. I am picking up mine on Monday and I would love to see your planes in the air first.
Crash99
Hide Signatures
(in reply to maxun)
       Post #: 72
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/16/2007 1:20 AM
Kostas1
Status: offline
Yet me too need a video.
Please HI_RES!
Hide Signatures
       Post #: 73
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/17/2007 3:28 AM
crash99
Status: offline
I am picking up one that is ready to go. The Length is 68" but How tall is it? How wide is it? I will be taking my 4 door truck. The short bed is is 5' 3" long. 7" in a 45 deg angle. I will have to see how tall tith the top closed. I do not know if it will fit. I don't want to take a trailer down there unless it will not fit.
Crash99
Hide Signatures
       Post #: 74
RE: GREAT PLANES YAK 54 BUILD THREAD - 2/17/2007 7:32 AM
flyman1948
Last Login: 3/19/2013
Status: offline
Bartoke
An earlier post addressed a way to prevent the horizontal fin from coming loose that I used in building my Yak. Remove the covering on the bottom of the plane in front of the tailwheel where there is no balsa sheeting..you can lay in a fillet of epoxy on the inside, and if your creative you can get epoxy on the top of the stab as well.
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.859RCU1
