john68
PA, USA Status: offline
As BalsaBasher mentioned, reading the thread is a good starting point. However, if you don't like reading mindless drivel and personal conversation, mixed in with the real questions and answers, you can go to www.bladecprepair.com to get tons of info on that helicopter. If I were you, I'd learn to hover on it, as is, stock set-up. Then once you can do that, get the lipo battery, 9 tooth pinion motor, heat sinks, bell-hiller mixer, and superskids. After all that, you will have a pretty decent machine to beat on, while you learn side-in hover, nose-in hover, and forward flight. oh yes, and symmetrical main blades. get those once you learn to hover on teh stock blades. If you keep breaking lots of stock blades while learning to hover, get the plasti-blades, but beware, if you have a hard boom strike, you will be buying a $12 main frame set, and some $5 blade grips. I have a very very precise scale for measuring paint for PPG intermix system. It measures down to .01 grams, which I have used to remove some excess material from the plasti-blades. I put them on a diet and got them to 8.46 grams each. then I balanced them, and now, I have no more problems with tearing up the helicopter, when I do have a hard boom strike. I really should take some pictures of exactly where I removed material from. The shape of the blades is almost identical tot he shape of the balsa wood stock blades. This is not nessesary, since the material is stronger. There is a bit of over engineering in their design. I removed lots of weight just by trimming them down, without making them any less stable than they were. Also, I have crash tested them, once on purpose out of shear frustration, and they haven't broken. the edges do nick, but with a small flat file, I reshape them to reduce turbulence at the leading edge, and trailing edge. One thing that kills performance on a helicopter is air turbulence. With any helicopter, and I have yet to see this mentioned here... You can't bring the helicopter straight down, fast, to land. You have to either move in steps, or come in at an approach angle, by using fore cyclic, and push the helicopter down to the ground. once it is within a few feet of the ground, you pull aft cyclic, to bring the nose up, and it will stop it's decent, and you can do a landing within ground effect. By dropping the heli down too fast, the rotor blades have to operate inside of their own turbulence, and this makes them less efficient. Less efficiency means that the helicopter will decend faster and faster, and the effect will worsen. You can try to overpower the effect by giving it a high head speed, but it won't completely recover, unless you move it out of it's own turbulence. This is a critical point to learn when flying helicopters. That information was given to me by a physics professor at CMU(Carnegie Mellon University- THE school to go to for mechanical engineering and robotics.)
