wojtek
Joined: 12/25/2001 From: old bridge, NJ, USA Status: offline
quote:
ORIGINAL: David Gladwin I was flying at a really excellent UK meeting this weekend. I was NOT impressed when a "heads up" call came and I looked up to see a jet model passing overhead minus BOTH of its stab . halves and crashed, inverted, on the 'dead" of the airfield, 50 or 75 meters from the pits. Why? The model, a much vaunted ARTF, did not have its load bearing stab. spar installed at the factory, meaning ALL of the stab loads were carried by the skin and a balsa, butt joined, spar which promptly and not surprisingly, failed ! Structural failure because of abysmal QC at the factory. I was shown, and examined in my own hands, the evidence so no excuses. Another lucky escape before the "big one" which, if this nonsense continues, is sure to happen. Regards, David Gladwin. PS. All of the BVM ARTFs plus my Bobcat performed flawlessly as well as the Savex's etc. David, I agree, BVM ( I personally do not have experience with Savex) quality is some of the best, but it still does not mean that every ARF will be perfect. Hey , remember the king cat boom issues ? I know of at least 5 cases that were publicly disclosed where the whole tails ripped off in flight ... no matter who you get an ARF from, there is always the possibility of flaws / errors, be it in the design itself, material selection, or the assembly process. In the spirit of not caring about political correctness I will say that the planes I have seen and hear about failing the most in flight have been those from CompArf. Usually the failures i have seen are due to sloppy assembly where the glue joints are inadequate, or poorly asembled. Also, I have seen these come apart after slight dings and scrapes that the pilot disregarded as minor, which ended up being the root point of failure. I would say the old Cermark kits make a close second for in flight failure rates .. the Viperjets are known for the stab failures .. be it poor materials, or poor design, there are issues .. I have seen several MB339s come apart as well from Cermark ( i will say i was happy with mine however, and it survived my abuse for many flights ) Then there are the old Skymaster kits ( from what i have seen, the new manufacturing process SM uses has improved the quality of these greatly and there is a night and day difference between the ARFs of old and what’s being produced now) .. i have seen the occasionally missed glue joint cause devastating failure in flight, such as a friends elevator ripping off due to missing glue in the stab causing the plane to go into the ground. Bottom line, if you did not build it yourself, you do not know how well an ARF is assembled beyond where you can get at the glue joints yourself. Its a good idea to go over any ARF as thoroughly as possible ... Voy
_____________________________
Nothing can ever be fast enough !!!
