RE: 2 death 4 wounded in model airplane crash
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: 2 death 4 wounded in model airplane crash
Page: <<   < prev  6 7 8 9 10 11 [12] 13 14 15   next >   >>
Login
RE: 2 death 4 wounded in model airplane crash - 3/18/2007 11:16 PM
MMallory
Score: 100
Last Login: 11/9/2009
Status: offline
Chris,
No necessarily. Remember Turbine Jets are required to have working rudders, have brakes and a sign off of pilot ability. Jets, on the ground, will generally cause LESS damage to soft tissue than a spinning prop.
At Jet events, the spectators are much farther away than I think most people realize. Anyone in the pits is no longer a spectator. They should be a pilot (flying or not), part of a crew helping the pilot or ave signed off to understanding the risk (photographers, etc). Most every event I've been to does not allow spectators in the pits
Mark
Hide Signatures
(in reply to Chris Smith)
       Post #: 276
RE: 2 death 4 wounded in model airplane crash - 3/20/2007 11:31 PM
Chris Smith
Score: 100
Last Login: 11/20/2009
Status: offline
Mark,
You're right about ground operations. The safety zones are probably adequate. Most pilots and aircraft are up to the task. I guess I'm more concerned about in-flight hazards. At some meets I've been to the flight paths are very close to the pits and therefore very close to the spectator line.
In addition, at more than one meet I've seen a mix of crew, pilots, and family members/friends all mingling in the pits too. I agree most meets don't allow spectators in the pits, but they are there anyway. The issue may not really be safety zones, but rather people control or lack of.
I hardly think Moms or Dads with toddlers, baby carriages, 12 year olds carrying balloons, cotton candy tripping over model jets, would qualify as crew. Often I see them with pit passes too. They are unsuspecting (and uncontrolled) spectators. I don't go to more than 3 or 4 meets per year, but I have seen this scenario at the majority of those meets. How often do we see the spectator line spread out along the length of the runway? Almost always Mom and Pop set up the lawn chairs closer and closer to the edge of the runway the further away from the show center they get. Hmmm...right where the jet is at a critical point in the approach or takeoff too.
For the record, I've seen this at prop events as well.
The CD has a challange. Keeping it fun for everyone, giving folks their money's worth, and safety. That's why they are paid the big bucks
_____________________________
Fly Army
Hide Signatures
(in reply to MMallory)
       Post #: 277
RE: 2 death 4 wounded in model airplane crash - 4/5/2007 10:33 PM
JetCatJimmy
Score: 100
Last Login: 11/19/2009
Status: offline
We reply in this area because we are trying to avoid scenes like this. I understand your view. It definitely wasn't something with the turbine, but we are handling aircraft in smaller tolerances and must be aware of these occurrences.
Jimmy
BVM Bobcat - P80
Hide Signatures
(in reply to digitech)
       Post #: 278
RE: Safety Matters - 10/20/2007 4:04 AM
Eddie P
Score: 100
Status: offline
I have a question for the safety minded folks-
If one was to overhaul the safety program at an RC club that has several jets, pylon races, etc - what are, lets say, the top three things that have been done in the last 5 years that have been deemed as an improvement to safety that also allow flexibility in flight operations?
Or - are we still doing things the same way for the most part?
I assume some of the larger clubs that host large events are probably more progressive in implementing new ideas, etc. However, necessity is the mother of invention as we say, so I'm sure good ideas exist everywhere regardless of size based on individual circumstances.
Hide Signatures
(in reply to alexei111)
       Post #: 279
RE: 2 death 4 wounded in model airplane crash - 11/12/2007 8:43 PM
SJN
Score: 105
Last Login: 11/21/2009
Status: offline
This could have gone real bad:
http://www.youtube.com/watch?v=4hYNOFDRL8M
Sonnich Johannesen
Hide Signatures
(in reply to Eddie P)
       Post #: 280
RE: 2 death 4 wounded in model airplane crash - 11/12/2007 9:02 PM
Ram-bro
Score: 136
Status: online
WOW!!!!!!
Hide Signatures
(in reply to SJN)
       Post #: 281
RE: 2 death 4 wounded in model airplane crash - 11/12/2007 9:05 PM
causeitflies
Score: 100
Status: offline
DOUBLE WOW!!!
Mark P
An Expert has made every mistake - A Master has made every mistake twice
Hide Signatures
(in reply to Ram-bro)
       Post #: 282
RE: 2 death 4 wounded in model airplane crash - 11/20/2007 7:20 AM
David Gladwin
Score: 100
Status: offline
Well, heres another incident which proves that safety awareness and close inspection of our jets is vital. In preparation for this weekends meeting I have spent today meticulously checking my Mig 29. Everything checked out fine , flight controls , engine failsafe settings, and hydraulics for leaks etc. Usual stuff. Fuel system undisturbed sincle last time but just an engine run to check them out as the engines themselves had been out.
No 2 engine, fine. No 1 engine, left, slow to ramp and would not reach full rpm. Shortly afterwards fuel seen dripping from cowl.
Investigation revealed that the pressure line from pump to cutoff valve was not over even the first barb and was quite loose. Nothing has been touched since installation so it must always have been this way and the engines have been run many times without any problem. However the fuel line (Festo) has aged and lost what grip it had, result could have been a serious fire. Yes, it was my fault that the fuel line was not over the barbs but perhaps this can be a "heads up" for anyone who uses unbarbed fittings, such as some tube joiners like 3-4mm. Festo tubing WILL age over time and can lose its grip so if your fuel lines are of some age you may care to give them a close inspection, particularly if you used any unbarbed fittings in the pressure lines. Might save you a fire.
Regards, David Gladwin.
Hide Signatures
(in reply to causeitflies)
       Post #: 283
RE: 2 death 4 wounded in model airplane crash - 12/3/2007 5:08 PM
Ray Davis
Score: 100
Status: offline
Only points out the obvious, David......that shut-offs/any filters/Tees, etc., ought only to be on the pump feed side...w/ a straight shot/no breaks in the pressure line. I.e., pump-to-engine as directly as possible.
We use all manner of Festos...never had a problem w/ this configuration......and any possible air bubble introduced, due to a bad connection, is usually obvious before flight upon inspection (though I've never had one)....and HAS to be better than the situation you potentially had on your hands !
Ray
Hide Signatures
(in reply to David Gladwin)
       Post #: 284
RE: 2 death 4 wounded in model airplane crash - 12/10/2007 10:36 PM
flyinfool1
Score: 100
Last Login: 9/21/2009
Status: offline
quote:
ORIGINAL: SJN
The pilot landed fairly quick after that, I sure hope he was ordered to and sent packing.
The bump that turned the plane toward the pits was in the first few feet of the take off roll and it could have easily been aborted, taxi around and tried again.
There was absolutely no reason to continue the takeoff through the pits/ready area.
Jeff Borowski
Gohbee Field Rep
Hide Signatures
(in reply to SJN)
       Post #: 285
RE: 2 death 4 wounded in model airplane crash - 2/10/2008 2:15 AM
SGT.SHAGGY
Score: 100
Last Login: 10/17/2009
Status: offline
quote:
ORIGINAL: flyinfool1
quote:
ORIGINAL: SJN
i second that, did you notice where the pilot was standing?
SGT.-Out-
Team Jet Central- Team Shaggy
Hide Signatures
(in reply to flyinfool1)
       Post #: 286
RE: 2 death 4 wounded in model airplane crash - 2/13/2008 5:34 AM
billym8228
Score: 100
Last Login: 10/6/2009
Status: offline
Hey ghost ryder, is this true about someone getting killed by an rc plane? was it recent? i read where you said do a frame by frame analys where is the video.thanks Billy
Hide Signatures
(in reply to pcsol)
       Post #: 287
RE: 2 death 4 wounded in model airplane crash - 3/2/2008 6:21 AM
BobH
Score: 100
Status: offline
We had a club member killed by an RC plane in 1981. Was a 60 size plane that hit him in the side and ruptured his liver.. He died in the OR.
BobH.
Hide Signatures
(in reply to billym8228)
       Post #: 288
RE: 2 death 4 wounded in model airplane crash - 3/5/2008 4:46 AM
Jackjet
Score: 100
Status: offline
quote:
ORIGINAL: Stallman
What does the combustion chamber have to do with anything?
really nothing - i just wanted to show it.......
jackjet
hesperia,ca.
Click to see fullsize image.
Click for fullsize
Jack Jet Williams
Hesperia,Ca
Hide Signatures
(in reply to Stallman)
       Post #: 289
RE: 2 death 4 wounded in model airplane crash - 5/11/2008 12:56 AM
jonathang
Score: 100
Status: offline
hi this flight should of been stopped before he nearly killed at least 5 people the guy that dived on the deck would off been the first and this should also been kept local and not put out for every one to see, thats the reason we dont want d*"kheads flying jets its bad for every one no matter if you fly in the usa or the uk or the rest of the world i dont no what rules you fly to in the usa but this guy would not be flying jets here in the uk regards jonathan
Hide Signatures
(in reply to SGT.SHAGGY)
       Post #: 290
RE: 2 death 4 wounded in model airplane crash - 5/13/2008 11:43 PM
Jackjet
Score: 100
Status: offline
just how are you going to stop him from flying a turbine jet ?
jackjet
Jack Jet Williams
Hesperia,Ca
Hide Signatures
(in reply to jonathang)
       Post #: 291
RE: 2 death 4 wounded in model airplane crash - 8/18/2008 5:10 PM
David Gladwin
Score: 100
Status: offline
STRUCTURAL INTEGRITY
This weekend in the UK, we had a really great jet meeting at RAF Cottesmore. There was only one crash and it really worries me . An ARF model had a wing disintegrate in flight, and crashed, fortunately clear of the pits in the grass, yet another structural failure of an aircraft from the same manufacturer of other airframes which have failed. A while ago I had to dodge another machine, same manufacturer, on which the stab. had failed, due to a poorly built structure. Several of us examined the wreckage and the internal structure was very poor, minimal, and a significant amount of the glueing had NOT met both surfaces, I have the photos to prove it beyond doubt. In addition the main spar was prevented from contacting the skin beacuse it was undersize, the TE spar preventing proper contact where the two meet.minimal structure, poorly executed.
As I personally own one of these machines, yet to fly, and found some serious structural deficiencies in the wing (now corrected) and know that some of the part of the internal structure were totally undersized, others misplaced, and I have heard of several of these machines disintegrating, I have an interest.
The one at Cottesmore, was recent version, so the problem seems to be ongoing. The question is this: As we KNOW there is a problem what are WE going to do about it ? Do we wait until a possibly very serious incident/ accident occurrs or do we start to fully report such occurrences to bring pressure on the manufacturer to get this aspect of his act togther.
If nothing is done and we bury our heads in the sand, continue with this game of Russian Roulett, afraid of upsetting the manufacturer or incurring his displeasure, we are merely contributing to, even exacerbating, the problem. If there IS a serious accident the future of the whole hobby may be in serious jeopardy.
Please discuss.
Regards,
David Gladwin.
Hide Signatures
(in reply to Jackjet)
       Post #: 292
RE: 2 death 4 wounded in model airplane crash - 8/18/2008 6:48 PM
Strykaas
Score: 123
Last Login: 11/17/2009
Status: offline
quote:
ORIGINAL: David Gladwin
Please discuss.
Regards,
David Gladwin.
Well put. However, under these uncomfortable circumstances, there is no reason why you should hide which manufacturers is responsible for this.
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
       Post #: 293
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 1:30 AM
uncljoe
Score: 100
Status: offline
David
You mentioned "Structural Integrity" but said nothing as to what type of A/C or mfg. Why the silence ? In other threads you mentioned the problems with the BVM kingcat. SAFETY ISSUES should not be kept quiet
as they can only hurt the hobby.
Semper Fi
Joe
Not a BVM Rep. Just a VERY Satisfied customer.
Hide Signatures
       Post #: 294
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 1:49 AM
JetCatJimmy
Score: 100
Status: offline
I agree. Thank you for gathering and analyzing all of the information. Now it's time to allow the mfg the chance to correct the problem. I would think it would be in everyone's interest including the company fabricating the models to know that there are 'issues' in their production facility.
Just my opinion.
Jimmy
BVM Bobcat - P80
Hide Signatures
(in reply to uncljoe)
       Post #: 295
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 8:08 PM
Strykaas
Score: 123
Status: offline
quote:
ORIGINAL: uncljoe
David
Semper Fi
Joe
Maybe he wants us to speculate ? My take : I would think of asian productions
ProBro #2077
Hide Signatures
       Post #: 296
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 9:06 PM
GrayUK
Score: 102
Last Login: 11/10/2009
Status: offline
Yep
Man made global warming.....Ha! Give me a break!
Hide Signatures
(in reply to Strykaas)
       Post #: 297
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 9:11 PM
uncljoe
Score: 100
Status: offline
quote:
ORIGINAL: Strykaas
quote:
ORIGINAL: uncljoe
David
Semper Fi
Joe
I don't care what country its from If it is a "Hazard It should be Flagged" ...
Semper Fi
Joe
Hide Signatures
       Post #: 298
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 9:18 PM
GrayUK
Score: 102
Status: offline
I do know what the model was i saw it break up, i also examined the wreckage, all that David says is true.
As David made the first post on this i feel it is up to him to 'name' the model and manufacturer.
Paul
Hide Signatures
       Post #: 299
RE: 2 death 4 wounded in model airplane crash - 8/19/2008 9:28 PM
uncljoe
Score: 100
Status: offline
quote:
ORIGINAL: GrayUK
Paul
What is this a "conspiracy of silence" I only thought these happen when Governments or Moneys were involved not a hobby...
Semper Fi
Joe
Hide Signatures
(in reply to GrayUK)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.953RCU1
