"Hard Solder" for Aluminium
I have several JMB silencers and notice that the joints are made with what they call "Hard Solder", the appearance resembles that of a very smooth soft solder joint, not at all like a TIG weld.
My question is this. Does anyone know how this hard soldering is done and can it be purchased for home use?
I have tried the types that need a stainless steel wire brush and a filler rod that has to be applied by a scratching action. The end results are very ugly and altogether not very good.
Were the hard solder system available then I think it would be much simpler to make bespoke silencer systems for our engines as well as repairing damaged ones.
As a matter of interest, Tony Clark lists what may be the type in his Practical Scale catalogue.
Thanks for reading this, any info most welcome.
Mike
Mike
RE: "Hard Solder" for Aluminium
I googled hard solder came up with www.ring&things.com
they talk about hard and soft solder check it out.
I.m watching you Larry
Hi tkg.
Thanks for the info.
Unfortunately that is the type that uses the stainless steel wire brush then scratch/rub the filler rod onto the work.
The type that JMB and some other manufacturers use produces a very smooth joint very much like a soft solder joint.
I have tried the aluweld system, and several others like it, without much success, but no doubt others will extol its virtues.
Regards.
Mike
Regards.
Mike
Bill
Do jewellers solder aluminium (aluminum) ?
Bill
The process is brazing at those temperatures - The product may be called solder but the process is brazing
Soldering ends at about 550 F
The problem with aluminum is that its surface oxides immediately after cleaning - this is what protects it Anodizing is a better protection but plain old aluminum lasts a loooong time
Also it is difficult to make aluminum rust ---
Bill
