redneckteddy103
FL, USA Status: offline
ok guys im going to tell you a hobby shop secret to setting the mesh on the spur gears ok frist thing the package that the gear comes in dont rip it , just below the tag take a knife and cut it , then replace the gear , and just befor you go to tighten the motor mount screws stick the package that the gear came in between the spur and the clutch bell , snug the screws but let them still move a bit for now from the right side of the truck softly push the motor mount and snug the screws all the way down , and you shouldnt have any problems till you get something between the gears . i know this due to i work at a hobby shop and have set more than i care to count this way and it is suggested by the tech dept from hpiracing the package that the gear comes in is the corect 2mm mesh this is also true with the robinson metal gears too
