HS-635HB fitting J connector
Tower Hobbies
Logged in as Guest
  Printable Version
JR NES703 Low Profile Retract Servo
Seller:  Erick Royer
Details:   $75.00   |  9/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS-635HB fitting J connector
Page: [1]
Login
HS-635HB fitting J connector - 5/15/2006 5:20:43 AM
niche
Status: offline
Hello
I just purchased a HS-635HB HT in tower hobbies
I have a Futaba radios system but the servo with the J connector was discontinued.
The one that was available at the time said within product description that it had an universal connector thet fits all radios ystems includind Futaba J.
In the box it says JR/HITEC (no J included)
when I plugged into my Futaba receiver alligning servo Yellow wire with Futaba receiver white wire the servo worked but I had to reverse its direction from the transmitter.
Is this OK?; should I do something extra to the wiring so it'd work fine with Futaba J?.
Thanks in advance for the help provided
Omar
       Post #: 1
RE: HS-635HB fitting J connector - 5/15/2006 7:34:22 PM
MikeMayberry
Status: offline
That's fine... All Hitec servos now only come with the "S" universal connector. The only difference from it and the "J" is it does not have the liitle tab. You would have had to reverse the "J" connector version (if it was available) of the same servo as well.
Mike.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to niche)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
