RE: home of the 60mph miss llumar    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: home of the 60mph miss llumar
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: home of the 60mph miss llumar - 5/18/2006 9:01 AM
redneckUSCG
Last Login: 5/11/2011
Status: offline
hey babflyer
yes the crumbgrabber hardware is for 6-8 cells i used rays bracket and super wedge rudder(it comes with the water pickup wedge but it is usless for any thing). yes the rudder bracket just simple turns around all you have to do is flip the rudder over and vola. yes the turn fin is rays carbon turn fin, i have both the hydro and mono turn fin, so far i have had better luck sability wise with the mono turnfin i dont know why. if you use the bracket that come with the kit you have to shim it out , i used two rubber gromets on the outbord screws so i could adjust the angle in relation to the hull. as for the flex cable i used a i think .190 i have to look at my nots back home but it is the same size ase the original flex shaft but has a longer teflon tube. u used a 3/16 strut and drive shaft it bolts right in place on the bracket. i would definatle consider going to the 3/16 shaft one if you are running a .18 u dont use a prop witha 1/8 shaft any more. two i bent many of stock shafts even with the .15 from the boat coming out of the water in the turns and under high power and bending the hell out of the shaft.
Hide Signatures
(in reply to toxic 2U)
       Post #: 51
RE: home of the 60mph miss llumar - 5/18/2006 10:38 PM
toxic 2U
Last Login: 12/17/2008
Status: offline
Wow !!!! You guys should see the rude and nasty E mail I got from our good and trusty friend Mr. redneck. Did any others that found his tail hard to grasp get E mail like that ? If so please report it to Ron Olsen . We don't want or need this type of mickey mouse crap .
_____________________________
Listen to your brain , it''''s smarter then you are .
Hide Signatures
(in reply to redneckUSCG)
       Post #: 52
RE: home of the 60mph miss llumar - 5/19/2006 12:12 AM
Jesus C
Last Login: 11/29/2006
Status: offline
60 mph? Its realy hard to belive. My aqua jet has a O.S. .18 & it could bairly do 30-31 with 20% o'donnell. Im not trying to call anyone a lier I think that that is imposible
Jesus Carrillo
Hide Signatures
       Post #: 53
RE: home of the 60mph miss llumar - 5/19/2006 12:33 AM
Lownverted
Last Login: 5/18/2013
Status: offline
There are several programs out there that will let you measure the doppler shift of a video clip to get speed. It is quite common to do this with pylon planes that are hard to radar. You can find more info in the High Performance section of E-Zone.
Red
Mach 3 with my hair on fire!
Hide Signatures
       Post #: 54
RE: home of the 60mph miss llumar - 5/19/2006 4:39 AM
Tim Wiltse-RCU
Last Login: 1/10/2012
Status: offline
Easy now guys.....give Red a break. Just by looking at the boat you can tell his machine is faster than the stock rig. Just think about the drag he lost by getting rid of the wing alone. Is it enough to get it up to 60mph..well no but it takes alot of little things to all come together to make things "click". So maybe it really doesn't do 60mph who care heck if it does 50 mph it's still kicking alot of guys tail on the water. I would love to see a video of it just to see it run not to prove anyone right or wrong. In the end what does it matter anyways, are we not all members of the same club? That club being dudes that like model boats, little models of real boat, little toy boats....come on it's not worth getting your panties in a bunch and calling people liers over something that we all enjoy.
LAter,
Tim
Halfa is the only way!
Hide Signatures
(in reply to ryan_t888)
       Post #: 55
RE: home of the 60mph miss llumar - 5/19/2006 4:55 AM
Thompy
Last Login: 2/8/2008
Status: offline
Here, here, I'll second that one. Well put.
Hide Signatures
(in reply to Tim Wiltse-RCU)
       Post #: 56
RE: home of the 60mph miss llumar - 5/19/2006 4:57 AM
toxic 2U
Status: offline
I did not say he was a liar. I just said I don't beleave it will do 60. I did not deserve to be called names or receive hatefull E mail .
Hide Signatures
       Post #: 57
RE: home of the 60mph miss llumar - 5/19/2006 8:47 AM
Ron Olson
Status: offline
Toxic, if you or anyone else get hateful e-mail or PM's from this site, those should be reported to myself, Piper Chuck any Community Moderator or Administrator.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
       Post #: 58
RE: home of the 60mph miss llumar - 5/19/2006 9:47 AM
toxic 2U
Status: offline
I'm sorry Ron and to the rest of you . It just gives me a warm fuzzy feeling to know that someone in the cost gaurd like that is watching out for us. He says he wants respect in one of his posts here . Respect is an earned thing and when you give so shall you recive. Most of you are gentelmen There is no reason to be crude , rude or obseen to express our opinions. thank you to all that think this also . Ok? Have fun guys
Hide Signatures
(in reply to Ron Olson)
       Post #: 59
RE: home of the 60mph miss llumar - 5/19/2006 4:20 PM
piper_chuck
Last Login: 3/1/2012
Status: offline
As Ron said, let one of us know if anyone receives an inappropriate PM. As for this thread, plenty of people have expressed skepticism about the speed. Redneck has given information on how the measurements were done. Continuing to beat on that issue will only cause more hard feelings. It's up to each to decide whether you do or don't accept the results. It's obvious there are some innovations on his boat that would make it faster than the standard production boat.
AMA 87959
Hide Signatures
       Post #: 60
RE: home of the 60mph miss llumar - 5/22/2006 7:32 AM
seawolf31635-1661
Last Login: 1/4/2013
Status: offline
Hi to all you boaters out there I have the miss bud with straight shaft and the llumar with a flexcable in it I have playing around with the strut in the llumar Ive been putting drifferent sizes of smale wedges to tilt strut down .Im running a os18 in them I haven,t cut wings off yet but Im going to later.I got x6372blade and 4403blade from Andy Brown he done some work to them I can not run them flat out wide open in the straightway but on a real slick even with no wind what so ever I can get the llumar running at an angle into circle on the water flat out and I can say one Thing that little yellow thing is moving .I have a small 29 inch aeromarine cat with a thunder tiger .21 running ax442 mod IM runnind 30% fuel in all and and that little llumar is running right in there with them .this old boy here Just might have hit the nail on the Head so to speak . Me and one of my cousins have to monos just a like and mine will runn circles around his it is just the little things that you do to them that makes them run good .Im still running stock rudder on bud &llumar .I,ve putt lead in left sponson on bud i have not cut the llumar yet toput lead or batterie pack in boat is to small to putt a gps in them my wifes two brothers one of them is the sheriff in the next county they said they just got new radar update guns when I get the bugs worked out and teach my wife to work new camcorder we are going to film anything possible .This is big D out And Gone.
Hide Signatures
(in reply to piper_chuck)
       Post #: 61
RE: home of the 60mph miss llumar - 5/22/2006 9:12 PM
redneckUSCG
Status: offline
imdone posting here if anone whants more pics and setup info i would be more than happy to help any one out but every on that wants to give sceptacism dont even bother
Hide Signatures
(in reply to seawolf31635-1661)
       Post #: 62
RE: home of the 60mph miss llumar - 5/22/2006 9:27 PM
Tim Wiltse-RCU
Status: offline
redneck,
Listen don't let the people that are talking smack get you down. Just because they can't get their boats to run as well as yours they just assume it can't. By all means don't stop posting here. It's like this, remember the car make "Tucker". Everyone called if a pile of junk. Now look at them they gave us things that we all have on our cars today. It was a car before it's time. Like I said in my other post maybe you found the "sweet spot" in this hull. Let the ones that are crying foul do just that...cry because your boat would kick their butts. It's like this, one of my airplane buddys we'll call him "PT" (Chuck knows who I am talking about) said he had a plane design that would fly over 100mph with a little Cox .049 reeed valve engine. I call Bull Crap on him because the math didn't add up. Given the rpm and pitch of the prop, slippage etc. There was no way it could. Till I saw the darn thing fly. That was when I stuck my foot in my mouth. Sometimes it's not all about the numbers somethings it just plain works without any answers. Rock on brother!!!!
Later,
Tim
Hide Signatures
       Post #: 63
RE: home of the 60mph miss llumar - 5/23/2006 12:31 AM
redneckUSCG
Status: offline
i got a mini gps thing from the nav Bm's if the water is calm enough in the torth pacific this week im am gona tri to run in the saltwater and take a pic of the GPS screen
PS i am sory for the obsene messages that i sent to u toxic it was a product or two stack fires and a freon leak witch equals a bad day but it will not hapen again.
Hide Signatures
       Post #: 64
RE: home of the 60mph miss llumar - 5/23/2006 12:39 AM
ryan_t888
Last Login: 4/10/2013
Status: offline
I would really like to see a video of it running in the North Pacific. I will also request more photos of your drive line and the bottom of your hull.
Ryan
Hide Signatures
       Post #: 65
RE: home of the 60mph miss llumar - 5/23/2006 12:51 AM
redneckUSCG
Status: offline
if i get a chance i will take some pics of the ride pads, the drive line is the same i just put a longer teflon tube to make up the distance of the strut. its the same size flex shaft. my camera will take video but the government computer does will not download it i tried every thing. i will take some and post it when we pull into Duch and my friend can get internet acsess on his laptop
yea it cool there is a couple people that have boats on the boat and when we stop for fish call they lower the small boat and run if the water is calm.
Hide Signatures
       Post #: 66
RE: home of the 60mph miss llumar - 5/23/2006 3:28 AM
Jerry Dunlap
Status: offline
If you run in salt water - make sure you take everything out of the boat, engine/drive system/rudder and WD the heck out of it as soon as your done.
JD
AquaCraft Models
Hide Signatures
       Post #: 67
RE: home of the 60mph miss llumar - 5/23/2006 12:57 PM
redneckUSCG
Status: offline
yea im reluctant to do it, i have flown flat planes of salt water in the florida keys back in the day and we had all kinds of corotion problems so i think i might just waite till i get to Duch and run in the lake on the other side of town if its not frozen
Hide Signatures
(in reply to Jerry Dunlap)
       Post #: 68
RE: home of the 60mph miss llumar - 6/28/2006 5:37 AM
engine geek
Last Login: 6/1/2011
Status: offline
Wow, how did you hit 60 miles per hour?
I have the exact same boat, with an O.S. .18TZ EB fully modified engine.
I'm running a modified X440 2 blade prop. I have already removed the wing. If I prop any larger or any smaller, the speed decreases. I have GPS'd the boat at 43.7 mph. I have played with the prop height until i reached such speeds without blowing over.
I want to know how you are able to hit 60 miles per hour with a lower performance engine. It is very tough to keep this boat on the water at such speeds over 40 mph.
Hide Signatures
       Post #: 69
RE: home of the 60mph miss llumar - 6/29/2006 3:40 AM
ledzep
Last Login: 8/28/2006
Status: offline
Hey Redneck, i am very interested in your work. I myself am a speed freak and i would love to get my little boat up to as fast as humanly possible. well for starters My boat is a home made and I have the same engine as you. But i am so confused on props and the depth it needs to be. well i dont wanna complain but I think what u have done is really cool. Anyway i noticed you were talking about some interesting things that i have never herd of before. you called them built up hull steps. what exactly are those? and what do you mean by port polish on your engine?
Thankyou
Ledzep
Hide Signatures
       Post #: 70
RE: home of the 60mph miss llumar - 7/7/2007 10:14 PM
Diegoboy
Last Login: 2/10/2013
Status: offline
Any news on the GPS run?
I have no idea what I''''''''m doing! <Disclaimer
Hide Signatures
(in reply to ledzep)
       Post #: 71
RE: home of the 60mph miss llumar - 7/8/2007 3:09 AM
gooycheese
Last Login: 7/18/2010
Status: offline
This is the first I have seen this post, I would love to see this boat run. Considering the IMPBA Sport 20 speed record was just set about 2 months ago at 60.349mph and thats using a custom designed hull and a Nova Rossi .21 engine, until that time the speeds where under 60mph. Please if you still frequent this site post some vids or pics of the boat in action, at 60mph you will be able to see this boat just barely touch the water.
Thanks Paul
Good Luck and Good Boating. :)
Hide Signatures
(in reply to Diegoboy)
       Post #: 72
RE: home of the 60mph miss llumar - 7/8/2007 4:06 AM
toxic 2U
Status: offline
OH GREAT It's back. I was hopeing this thread would stay dead. It was a BS flame then and still is. I'm still feeling the sting of that nasty E-mail. I should have saved it and posted here for all to see.
Hide Signatures
(in reply to gooycheese)
       Post #: 73
RE: home of the 60mph miss llumar - 7/8/2007 5:03 AM
alloutcustom
Last Login: 1/18/2013
Status: offline
vid??????????????????????????????????????????????????????????????????????????????????????????
If the boat doesnt fly, dont buy!!! ; )
Hide Signatures
       Post #: 74
RE: home of the 60mph miss llumar - 7/8/2007 5:51 AM
mopartybob
Status: online
first time I seen this thread too,I like the part where he had it radared by a wash. state trooper(county mounty)....I new i should have contested that ticket.......
< Message edited by mopartybob -- 7/8/2007 6:40 AM >
.....If I had a plan,I''''''''''''''''d be screwed....
Hide Signatures
(in reply to alloutcustom)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
