ZDZ 40RV on Yak
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> ZDZ 40RV on Yak Page: [1]
Login
ZDZ 40RV on Yak - 5/15/2006 5:17:55 PM
cwhite
Status: offline
Would the ZDZ 40RV work well on the YAK or would the 73" Edge be better for 3D?? I would want at least 1/2 throttle pullout.
Chris
       Post #: 1
RE: ZDZ 40RV on Yak - 5/15/2006 7:40:24 PM
ben beyer
Status: offline
If you want 1/2 throttle for pull out, I'd say the 73" Edge would be your better bet.
_____________________________
Team DOD Member
www.downonthedeck.com
(in reply to cwhite)
       Post #: 2
RE: ZDZ 40RV on Yak - 5/15/2006 9:20:33 PM
rctom
Status: offline
I agree.
(in reply to ben beyer)
       Post #: 3
RE: ZDZ 40RV on Yak - 5/16/2006 5:05:50 PM
JoeAirPort
Status: offline
Caution, 40cc gasser on 73 inch wing = brick. Chop the throttle and watch it drop. I'll take that engine on the WH Yak any day. Not disagreeing with Tom and Ben, they are both right. But I prefer the wing loading of the Yak with the 40cc gasser. Vertical pullout is not as important to me hence the Yak as my pick for that engine.
Joe AP
(in reply to rctom)
       Post #: 4
RE: ZDZ 40RV on Yak - 5/16/2006 5:35:14 PM
ben beyer
Status: offline
It will probably add another pound to the airplane. When I had mine with the OS 160 it would float and float and float. The online review has a Brison 2.4 and it floats in nicely for landing. That engine weighs the same as the ZDZ 40. Flight characteristics aren't based on wing area alone. Airfoil shape has a lot to do with it to.
Team DOD Member
(in reply to JoeAirPort)
       Post #: 5
RE: ZDZ 40RV on Yak - 5/16/2006 6:00:30 PM
rctom
Status: offline
I can assure you that with a lightweight 40cc engine the Edge is not a brick, farthest thing from it. Very well matched for 3d stuff.
The Yak is good also, but if you want to go vertical at 1/2 throttle then lighter is better.
TF
       Post #: 6
RE: ZDZ 40RV on Yak - 5/16/2006 8:41:39 PM
ben beyer
Status: offline
If you're looking for something that will be ballistic, you might look into putting a BME 55 Extreme on the 73" Edge. I think it weighs 2.5 lbs. or so with the ignition and has as much or more power than a DA 50. So think what a DA 50 would be like on a 12-12.5 lbs. plane...
Team DOD Member
(in reply to rctom)
       Post #: 7
RE: ZDZ 40RV on Yak - 5/17/2006 12:57:25 AM
JoeAirPort
Status: offline
YES !! That is the perfect engine for a 73 inch aerobat. Forgot about the BME 55 (even though it's not out yet).
quote:
ORIGINAL: ben beyer
Joe AP
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.953RCU1
