RE: Another Cuda Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: Another Cuda Build
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Another Cuda Build - 6/12/2006 3:23:45 AM
OnTheEdge
Status: offline
Ward, did you get your thumb screws yet?
_____________________________
Avoid zen aerobatics...when the ground........and the plane.......become as one.
(in reply to zzw26n)
       Post #: 26
RE: Another Cuda Build - 6/12/2006 5:53:10 PM
zzw26n
Status: offline
OnTheEdge,
Yes I did, very nice! Thanks ...............
(in reply to OnTheEdge)
       Post #: 27
RE: Another Cuda Build - 6/12/2006 11:34:14 PM
ibow24
Status: offline
I got a set too. They'll look great in my Yak.
Steve
       Post #: 28
RE: Another Cuda Build - 6/13/2006 12:12:19 AM
OnTheEdge
Status: offline
quote:
ORIGINAL: ibow24
Steve
Did you call Dennis to place your order for your Yak-in-the-box yet....??
(in reply to ibow24)
       Post #: 29
RE: Another Cuda Build - 6/13/2006 1:40:57 AM
ibow24
Status: offline
sort of but it's not official. I talked to Caroline last week and told her I would be putting a deposit down on something for this winter.
I'm still going back and forth between the Yak in the box (thats funny) and the 260.
I haven't said nyet to the 260 but I'm leaning toward the ruskie.
I'm looking to have it for Christmas week since I'm off that week and it's a good one to start building.
       Post #: 30
RE: Another Cuda Build - 6/13/2006 3:01:46 AM
OnTheEdge
Status: offline
quote:
ORIGINAL: ibow24
Build one of each.
       Post #: 31
RE: Another Cuda Build - 6/13/2006 3:17:18 AM
ibow24
Status: offline
I guessing someday I will...now where did I put that winning Powerball ticket?
       Post #: 32
RE: Another Cuda Build - 6/14/2006 12:38:36 AM
ibow24
Status: offline
last night I made the 2 1/2 degree wooden standoffs that give the engine the right amount of offset.
and today I got the engine mounted...Everything is looking good so far.
Steve
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 33
RE: Another Cuda Build - 6/15/2006 1:09:11 AM
ibow24
Status: offline
Back to the wings.
Tonight I laid out the aileron and servo locations on the wings.
I use a plywood template and bend copper wire that I put in my solder gun to cut out the foam.
the last two pictures show the "tunnel" for the servo wire. After I melt the tunnel out I back fill the slot in surface of the wing
with sheet balsa sanded down to fit the slot.
The 1/4 x 1/2 servo rails have been expoxied in place. I will back fill extended sides with scrap foam, give the wings a light sanding and they will be ready to be sheeted this weekend
Steve
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: Another Cuda Build - 6/16/2006 11:29:28 PM
ibow24
Status: offline
Here's a pic of the finished servo box. I back fill over top of the hardwood servo rail with scrap foam and then use 1/16" sheet to frame the box.
once the wing skin is glued on this all gets locked in very solid.
Steve
Click for fullsize
       Post #: 35
RE: Another Cuda Build - 6/20/2006 1:26:31 AM
ibow24
Status: offline
All the foam has been sheeted and the leading edges installed and planed / sanded.
Next up, cutting out the ailerons, elevators and rudder.
Click for fullsize
Click for fullsize
       Post #: 36
RE: Another Cuda Build - 6/27/2006 1:17:54 AM
ibow24
Status: offline
All of the control surfaces have been cut out. I added the leading and trailing edges to them and planed and sanded them flush to the surface.
Next I drew center lines and hinge locations. I also drew the angle of bevel on the end caps and line contecting them from end to end as guide when I plane and sand the bevel into leading and trailing edges. I then made the holes for Robart hinges and checked the fit and did some touch up sanding. Take the time make sure you have a nice tight fit with the hinges installed. It's hard to go back and fix once you cut the angle into the edges.
In these pictures the hinges have been inserted (but not glued) into all the surfaces. Tomorrow I will get to work on beveling all the surfaces.
Steve
Click for fullsize
Click for fullsize
       Post #: 37
RE: Another Cuda Build - 6/28/2006 1:20:59 AM
ibow24
Status: offline
That should be enough elevator for nice loop
       Post #: 38
RE: Another Cuda Build - 6/28/2006 1:22:32 AM
ibow24
Status: offline
oops.
THIS should be enough elevator
Click for fullsize
       Post #: 39
RE: Another Cuda Build - 6/28/2006 2:09:49 AM
Flyin Woodbutcher
Status: offline
maybe
