zzw26n
MI, USA Status: offline
Steve, Today we had a chance to maiden the 35% Carden Extra you built last year and all I can say is WOW! Two short 8-minute shake down flights, it flies like it’s on rails, just amazing. It took one click of right aileron (we think because of the cross wind) and that was it, level and straight. You did a fantastic job on this plane; everyone at the field just loved it! It’s a Carden thru and thru, again thanks a million. This morning at 8:30 AM, my wife and I are down in the basement, checking the CG by holding the plane at the wing tips. Then we verified the CG by putting the Plane on a Kollercraft CG balancer and it was a ¼” behind the recommended point. Then at the field I put it in a 45 degree up line, it had a slight arch back to earth, perfect. Very little, if any coupling in knife-edge and high rates go beyond my capabilities! In fact, before the second flight I backed down the low rates a bit, it flies very very light. Almost forgot, the canisters and 3-Blade prop, that’s the ticket. Brian was right, what a combo and super quite, I bet it was 94-96 dB max. Great job and again, thanks. Back to the Cuda thread. Regards, Ward
