RE: Definitive Prop-Jet Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Definitive Prop-Jet Thread
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Definitive Prop-Jet Thread - 5/19/2006 5:48:54 AM
Razor-RCU
Status: offline
Have blue are retracts part of the Juno ARF is that a "mod" you are making---
Cheers!
_____________________________
Revver #5
(in reply to JS615)
       Post #: 26
RE: Definitive Prop-Jet Thread - 5/19/2006 6:42:13 AM
HaveBlue
Status: offline
Hi razor , its an option on the plans but the kit comes with fixed gear... being retract compatible was a factor in buying this model.. like the FA18 the plans cater for the Hobbico 3 gear retracts and for one other brand , but the name of those escapes me.
Other mods I'm trying to work out are to conceal the aileron control horns. The elevator and rudder horns are concealed as standard in this kit..
Another aspect I am trying to tackle is to make it as lite as I can with out sacraficing rigidity or strength, I will blend the ducts into a wing fillet type arrangement.
one other thing I might look at pending the quality of the elevators , and that is a full flying stab just like Mods-R-Me has done for the SU27..in fact I like that system so much.. it might become a standard arrangement on all the kits I have left to build
I have almost finished my Diamond Dust , I found that lost inspiration that I accidently chucked into the corner , picked it up, dusted it off and got to work again..just need to get some fibreglass material to make the cowling for the engine + pipe..then I'll build the F20
if your still in control....you aint goin fast enough
**Revver Bro 95**
(in reply to Razor-RCU)
       Post #: 27
RE: Definitive Prop-Jet Thread - 5/19/2006 4:04:25 PM
Frank78
Status: offline
Hey guys yesterday i picked up an airframe of a Direct connection r/c F-20 (the juno f-20 is the same thing) I have wanted one for some time and this one was free but i am not sure of how the fin goes on it sits in a long block but not sure how the block sits on the turtle deck or if it is supposed to be under the turtle deck and i need to know the CG of the plane
If anyone has a set of plans for this plane or can help me out it would be greatly appreciated
Thanks Frank
PS I will post picks as soon as i get my camera back from my uncle (he borrowed it for the weekend)
       Post #: 28
RE: Definitive Prop-Jet Thread - 5/19/2006 9:23:02 PM
vicman
Status: offline
Welcome to Razor's mad house Frank!
I took a few pics of my Kankgke and Sportsman Aviation (DC knock-off, the Juno is the real deal)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to Frank78)
       Post #: 29
RE: Definitive Prop-Jet Thread - 5/19/2006 9:52:37 PM
Razor-RCU
Status: offline
Thanks Haveblue - Spring Airs are my favorite but I might try that Euro brand (Eurokit?) next time... I am looking at the Juno F-20 but It'd have to have retracts...
Frank- Nice catch with the D/C F-20! I would need to see pics to help but I will google and try to find the manual for ya--
Revver #5
(in reply to vicman)
       Post #: 30
RE: Definitive Prop-Jet Thread - 5/19/2006 10:03:27 PM
vicman
Status: offline
With the big block under the vertical I am leaning tward the Kangke . Here is what the manual for the DC looks like, no block, also the CG is 5 3/4 from the LE at the root and measured upside down. I have the Kangke manual scanned but not the DC.
Vic
Click for fullsize
Click for fullsize
       Post #: 31
RE: Definitive Prop-Jet Thread - 5/19/2006 11:17:55 PM
Frank78
Status: offline
Thanks guys i appreciate the help i will post pics asap
here is a few pics of my Kobra
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 32
RE: Definitive Prop-Jet Thread - 5/20/2006 7:36:00 AM
Razor-RCU
Status: offline
Vic is the man, yes?
Frank- Sweet looking Kobra! What is the set-up there and where did you get the graphics?
Revver #5
       Post #: 33
RE: Definitive Prop-Jet Thread - 5/20/2006 11:38:57 AM
vicman
Status: offline
I think he took you LA comment serious. Just looking at the blue motor.
       Post #: 34
RE: Definitive Prop-Jet Thread - 5/20/2006 3:41:47 PM
Frank78
Status: offline
The Kobra has an OS 40 LA and a futaba radio The graphics are hand drawn and cut by me the eagle head alone is 4 pieces and the flames on the fuse are 3 different pieces it was fun getting them all ironed on exactly the same on both sides
       Post #: 35
RE: Definitive Prop-Jet Thread - 5/20/2006 11:10:48 PM
Cyclic Hardover
Status: offline
quote:
ORIGINAL: Razor-RCU
< Message edited by Cyclic Hardover -- 5/20/2006 11:12:05 PM >
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
       Post #: 36
RE: Definitive Prop-Jet Thread - 5/21/2006 5:00:08 AM
vicman
Status: offline
Aw cmon CH
(in reply to Cyclic Hardover)
       Post #: 37
RE: Definitive Prop-Jet Thread - 5/22/2006 4:56:25 AM
angelrcdesign
Status: offline
Hello guys hows it going?
Well here it goes ... Rifle (V-tail -OPT) is set up with a Jett .50 with Blk racing pipe. C/G is 6" to 6-1/2" from the Leading edge. I have all the conttrols by (3) 3004s (1) Hitech 81- Thr. These servos are good enough for the control surface. ali. 1/2" up and down, Ele. 1/2" up and down. rud. if you use it 1/2" L and R. It does help on take off. I use a landing gear. I do not recommend throwing it, it will stall the eng. I also have use a dolly. For landing I use 1/4 thr, and full trim up on the ele. this will help you get out of trouble and also keep the nose up while landing. THATS if your using a langing gear. If no gear, than you cut the eng off . It has not tip stall on me yet. I did a video on it, I hope these works.
Click for fullsize
If something fails,try and try again until you get it right.
       Post #: 38
RE: Definitive Prop-Jet Thread - 5/23/2006 5:04:27 PM
cobratraxxas69
