Glow fuel, for all the chemists out there
Tower Hobbies
Logged in as Guest
  Printable Version
BCMA-42 Pro - RTR
Seller:  blackbaron
Details:   $325.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Glow fuel, for all the chemists out there
Page: [1] 2   next >   >>
Login
Glow fuel, for all the chemists out there - 5/18/2006 6:19:04 AM
skateflyer
Status: offline
Does anyone know the difference between Methonal and Metholhydrate, (spelling???)is there any?????
       Post #: 1
RE: Glow fuel, for all the chemists out there - 5/18/2006 6:28:45 AM
CP140
Status: offline
Nope... no difference apart from the name. Methanol=methyl hydrate
_____________________________
Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup.
(in reply to skateflyer)
       Post #: 2
RE: Glow fuel, for all the chemists out there - 5/18/2006 6:48:16 AM
DarZeelon
Status: online
Albert, Martin,
The word 'methanol' (note correct spelling) has a couple (...) of synonyms...
...As you can see here.
It is an alcohol derived from the hydrocarbon 'methane', which is used as a gas for cooking in many countries.
In its chemical notation, methane is CH4 and methanol is CH3OH; a hydrogen atom (H) was replaced by a hydroxide (OH).
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to CP140)
       Post #: 3
RE: Glow fuel, for all the chemists out there - 5/18/2006 7:24:28 AM
skateflyer
Status: offline
OK thanks for the info. That means I should be able to buy inexpensive gallon of methal hydate at the local harware, add 20% oil and end up with something close to FAI fuel.
(in reply to DarZeelon)
       Post #: 4
RE: Glow fuel, for all the chemists out there - 5/18/2006 8:57:26 AM
DarZeelon
Status: online
Albert,
Just make sure it is at least 99% pure... doesn't contain harmful/acidic impurities.
And 'methal hydate' is not one of the names used to describe methanol.
Make sure the spelling is correct before you buy it, because if it is not methanol (or any of its synonyms), your engine will not run!
       Post #: 5
RE: Glow fuel, for all the chemists out there - 5/18/2006 1:15:41 PM
pe reivers
Status: offline
The cheap stuff is good for paint applications and degreasing, but is not pure enough for our glow engines.
You will get inferior fuel.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
       Post #: 6
RE: Glow fuel, for all the chemists out there - 5/18/2006 1:48:42 PM
Sport_Pilot
Status: offline
H'mm, the fuel bought at the race track seems to be a LOT cheaper than from the hardware store. About half. I suggest you find a good source of methanol race fuel.
“I Saw Elvis at 1000 Feet” John Force
(in reply to pe reivers)
       Post #: 7
RE: Glow fuel, for all the chemists out there - 5/18/2006 1:55:44 PM
Turk1
Status: online
Hi,I am using industrial type methanol,directly pouring from 200 liter barrel.Wihout nitro and 20% full castor with OS A3 plug,Im having good power. Fuel costs me about 3$ per litre
< Message edited by Turk1 -- 5/18/2006 2:00:02 PM >
       Post #: 8
RE: Glow fuel, for all the chemists out there - 5/18/2006 2:19:22 PM
Sport_Pilot
Status: offline
Costs about the same as a gallon of gas in the US. About $3.00 per gallon. That is for race fuel. A gallon of wood alcohol is about $6.00.
(in reply to Turk1)
       Post #: 9
RE: Glow fuel, for all the chemists out there - 5/18/2006 2:34:24 PM
Turk1
Status: online
Hi, dont forget Im talking for Turkish market.Here a commercial brand fuel such as 5% nitro comes about 9,5 $ per litre.If I want to buy one liter nitro,I have to pay about 110$.My methanol costs me a little more than 1 $.
< Message edited by Turk1 -- 5/18/2006 2:35:49 PM >
(in reply to Sport_Pilot)
       Post #: 10
RE: Glow fuel, for all the chemists out there - 6/2/2006 1:15:39 AM
loughbd
Status: offline
I think you guys had better check the CRC Handbook of Chemistry and Physics. Methanol is wood alcohol, methyl alcohol, or methanol. It is an alcohol.
There is no such chemical as methyl hydrate listed in the handbook and there is a listing for all the thousands of organic chemicals. The suffix hydrate indicates there is a water molecule in the base compound. You see this in many rocks and minerals. Opal is one. It's formula is SiO2-nH2O. It is SiliconDioxide with an n number of water molecules bonded to the SiO2. SiO2 is common quartz.
If you add water to methanol, all you get is contaminated alcohol.
Methanol and methyl hydrate (whatever that is) are two different things.
Definition of a hydrate from the glossary of "Chemistry and Chemical Reactivity, third edition". "An ionic compound in which water molecules are trapped within the crystal lattice." Methanol is not an ionic compound and does not have a crystal lattice. It is not a hydrate.
That was your chemistry lesson for the day.
< Message edited by loughbd -- 6/2/2006 1:22:22 AM >
(in reply to Turk1)
       Post #: 11
RE: Glow fuel, for all the chemists out there - 6/2/2006 2:32:43 AM
CP140
Status: offline
True, the CRC does not list "Methyl Hydrate"... neither does the copy of the Merck Index I have. However... both are American publications and may overlook common or more antiquated names from the other side of the Atlantic.
I will refer you to the following link
http://ptcl.chem.ox.ac.uk/MSDS/ME/methyl_alcohol.html
and have attached the following scan of a bottle I have...
Click to see fullsize image.
Click for fullsize
(in reply to loughbd)
       Post #: 12
RE: Glow fuel, for all the chemists out there - 6/2/2006 2:50:48 AM
loughbd
Status: offline
Again, the definition of a hydrate is an ion with water as part of the crystal lattice. Alcohol doesn't have a crystal lattice and it isn't an ion. In a hydrate the water molecule latches onto the atom that is missing an electron in the lattice. Alcohol don't do dat. I can write Rolls Royce on a Yugo but that don't make it a Rolls.
< Message edited by loughbd -- 6/2/2006 3:45:24 AM >
(in reply to CP140)
       Post #: 13
RE: Glow fuel, for all the chemists out there - 6/2/2006 4:08:52 AM
CP140
Status: offline
I suspect methyl hydrate is one of the more antiquated names for methanol and/or not commonly used on this side of the world.
However, that does not detract from the fact that methanol and methyl hydrate are synonyms. ( I apologize to all of you IUPAC lovers out there. )
http://www.hc-sc.gc.ca/ahc-asc/media/advisories-avis/2001/2001_07_e.html
http://www.centrum-labs.com/mobile/Safety/MSDS/methanol.htm
http://www.mfa.org/_CAMEO/FRONTEND/material_description.asp?name=methyl+alcohol&language=1
http://www.recochem.com/english/products/faqs.html
Also, while your description of hydration is correct, there is (at least) one other definition.
http://www.iupac.org/goldbook/H02876.pdf
       Post #: 14
RE: Glow fuel, for all the chemists out there - 6/2/2006 4:34:10 AM
loughbd
