john68
PA, USA Status: offline
YEs, yes, and no. or... Yes, no, and no or... Yes, yes, and no. or... keep the stock motor, leave all the rest of the enhancement kit on, but go with plasti-blades. OR... keep the upgraded motor, put on the sym blades, and get a li-po, but save the wooden sym blades, and get the CF ones. I had about 4,000,000 crashes on my carbon fiber blades before they bit the dust. They are pretty sturdy, and are lighter than the plasti-blades, yet not as "indestructable." You won't break as much stuff with the CF blades, because they are not as heavy handed, yet they don't splinter like the wood ones will when you crash. Just to get it back off the ground for now, I'd swap back to stock motor, and save the 9 tooth for when you get a li-po. Of course, when you get the li-po, you might want to downgrade to an 8 tooth pinion. Although, if you are looking for monster flight times of 30+ minutes, you could get the 1200 li-po, use the flat blades, and get an 11 tooth pinion, with increased pitch to about +15. Doing this will give you huge flight times, but don't plan on doing any aerobatics. That is how I have my scale Bell 222 Blade CP set-up. I have my aerobatic set up with the 9 tooth, 1200 li-po, bell-hiller, CF blades, and +10/-10 pitch... and... my stock Blade CP just has everything stock, except the stupid velcro battery attachment... I use small rubber bands.
