Imac Cg
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> IMAC >> Imac Cg
Page: [1]
Login
Imac Cg - 12/20/2002 9:08:26 AM
krayzc-RCU
Status: offline
Is there certain traits a plane will have with a IMAC type of CG? I want to set 2 of my plane up for an IMAC dayview.
_____________________________
smooth as silk!
       Post #: 1
Re: Imac Cg - 12/20/2002 9:15:40 AM
wgeffon
Status: offline
[QUOTE]Originally posted by krayzc
an IMAC dayview. [/QUOTE]
????? Whats that?
Wayne
(in reply to krayzc-RCU)
       Post #: 2
Imac Cg - 12/20/2002 6:26:42 PM
krayzc-RCU
Status: offline
it means going to my 1st constest lost as hel% getting your butt kicked
smooth as silk!
       Post #: 3
Imac Cg - 12/20/2002 8:23:26 PM
wgeffon
Status: offline
LOL.
It wont be that bad. Just have fun.
You flying the Edge?
Wayne
       Post #: 4
Cg and Imac - 12/20/2002 8:28:13 PM
chance12
Status: offline
Depends on the plane your flying . Normaly you want the plane to break clean in Imac on the stall. 3D setups you will want to move the CG slightly back . I normally set my 33% Edge540T up so I dont have to hold any stick when I am inverted. also I have to mix in a little down elevator with idle so the plane will continue on a straight downline. When in knife edge if you are to tail heavy the plane will pitch to the belly. You just have to fly the plane and set it up the way you like the plane to fly . If you can have a spotter watch you as you fly that can be helpfull because they can see things that you wont as you fly. Hope that helps some.
       Post #: 5
debut - 12/23/2002 7:39:51 AM
Brian Dorff
Status: offline
It is most important to fly what you are comfortable with. If this is your first contest with a olane that flies halfway good that you are used to- DON'T CHANGE ANYTHING!
Brian Dorff, CD
Grand Forks, North Dakota- where time stands still but the air is always moving
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
