RE: Powered Parachutes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: Powered Parachutes
Page: <<   < prev  1 [2]
Login
RE: Powered Parachutes - 6/20/2007 6:09 PM
13BT
Score: 107
Last Login: 3/31/2012
Status: offline
is there a source for replacement chutes for the sky surfer? Just in case mine gets too messed up in the future
_____________________________
Those flames are normal, officer!
Hide Signatures
(in reply to para.nick)
       Post #: 26
RE: Powered Parachutes - 7/7/2007 11:24 AM
SCMSteve
Score: 100
Last Login: 8/6/2008
Status: offline
I have two chutes from troy at http://www.seabreezeparachutes.com the customer service cant be beat he test flys everyone and video tapes them and sends it to you before you ever get it. I havent found a better one yet. He has 3 sizes and a 2 year gaurantee.
Hide Signatures
(in reply to 13BT)
       Post #: 27
RE: Powered Parachutes - 7/13/2007 5:38 AM
neubs
Score: 100
Last Login: 7/10/2008
Status: offline
I was going to buy one of the powered parachutes from airfiol aviation but I though to myself, " I can make one of those myself" so I started building and now I'am almost finished making my home made custom powered parachute! The parachute is 96 inches and I made it myself. I went down to the local fabric store and bought five yards of rip-stop nylon and started sewing. It took me about 10 to 15 hrs to make the "gondala" and about ten to make and sew the parachute.
Hide Signatures
(in reply to SCMSteve)
       Post #: 28
RE: Powered Parachutes - 7/14/2007 6:43 PM
nebg9
Score: 100
Last Login: 8/15/2010
Status: offline
That sounds like a very good idea making your own parachute. I bought a sky surfer about 4 years ago and have been having a blast with it. However, now I have gotten to the point where I am bored with the stock setup and am in the process of upgrading it. So far, I have a park 370 3600kv brushless motor planning to make a custom geared system and a polyquest 3 cell 1200mah lipo. I'm replacing the receiver and esc, too, of course. But after coming along to your post I thought of the poor shape of my chute and am now interested in making my own. How do I go about doing that?
Hide Signatures
(in reply to neubs)
       Post #: 29
RE: Powered Parachutes - 10/4/2007 6:37 AM
homeadeflyer
Score: 100
Last Login: 10/5/2007
Status: offline
Hey edge you seem like you know a lot about RC parachutes. Could you use a NPW (http://members.shaw.ca/kiteman/NPW9b-4.0m.htm) as a wing? I know they used to be used as parachutes but would i be able to climb with a motor? Also I think it would make an interesting chute for you to try (very easy to make, i have a 5.5 meter kite that will pick me up)
Hide Signatures
(in reply to edge_pilot)
       Post #: 30
RE: Powered Parachutes - 10/4/2007 11:50 PM
edge_pilot
Score: 100
Last Login: 5/24/2013
Status: offline
Thanks, but I wish we knew alot more! We are in the test faze of designing a new Ultimate canopy to go along with our Ultimate diver. Alot of research and development, time and money. We spend 4 hours to sew a chute that doesn't meet our needs, thats dissappointing. As far as the kite for a parachute, not a good idea. The only thing they have in common is there looks from a distance. They are usually made of 2 differant materials, (not all ripstop is the same), they are usually strung up totally differant. Parachutes actuall use the airfoil to create lift, a kite catches wind to propell it up. I can lift myself off the ground with a bedsheet if the wind is right! That doesn't mean the kite will create any lift at all once put in the horizonal possition to be used as a parachute. I know the kite thing seems to be a good place to buy a cheap wing, but you are just creating a bunch of headaches for yourself if you think this will work. All this said is just my 5 years of experience and trial and error opinion. In no way have I tried evrything. I beleave we are on a good track though with this new chute we are making, due to the overwelming input I have taken in from many people in the hobby and in full scale chute design.
Hide Signatures
(in reply to homeadeflyer)
       Post #: 31
RE: Powered Parachutes - 8/10/2008 6:54 PM
Fred 1969
Score: 100
Last Login: 8/15/2008
Status: offline
I just purchased a used Airfoil Aviation's 1/3 scale powered parachute and have some questions I was hoping someone could answer. First I must say that the company that produces and sells these sucks they provide no help whatsoever, don't care to help you and are rude. First, I was hoping someone would have some close up pictures of the way the lines are setup on the trike and approx. servo positions at rest (neutral). Not really sure of proper radio setup. What is the best way to set up my computer radio to fly this? I can tell you I have flown it and it flies great once your in the air but then again it may fly better with it set up correctly, I don't know. What take off procedure should be used. I tried to takeoff like the real thing with the chute laid out behind it but the chute inflates and acts just like a break and stops foward progress. Can't get it to continue up over the trike. The only way I have been able to take off is by having two people run alongside and help the chute up over the trike. Once it is over the top the chute flies well. Any experiences with this unit that you could pass on would be great to hear. Very happy with it but there is no support anywhere that I can find.
Hide Signatures
(in reply to samolot)
       Post #: 32
RE: Powered Parachutes - 8/10/2008 10:33 PM
Slammed
Score: 100
Last Login: 4/7/2009
Status: offline
this is cool I did not know they had these
Havoc 4.6cc, FireHammer 23cc , Tmaxx HPI 21,Tmaxx 2.5,Mini LST, Cessna 182, Focus 400EP Brushless www.youtube.com/benduchi
Hide Signatures
(in reply to Fred 1969)
       Post #: 33
RE: Powered Parachutes - 10/2/2008 4:15 AM
bry14661
Score: 100
Last Login: 6/25/2012
Status: offline
hey Jman, how much did it cost you to turn this into a brushless setup? do you reccomend it or would i be better off buying one that doesnt need upgrading right away?
Hide Signatures
(in reply to Slammed)
       Post #: 34
RE: Powered Parachutes - 11/4/2008 8:45 AM
Shortbuss
Score: 105
Last Login: 5/5/2013
Status: offline
I had a brainwave today. I was reading this thread the other day and realized I really want an RC PPC. I have a Firebird 2 that I have crashed way to many times, and a dual control lone kite. First I am not sure if the kite will work, I dont see why it wont. Second I am not sure in the Firebird 2 motor is powerfull enough. But it is a three channel, so I could have left, right and flare.
I have 80 real paragliding flights and almost 40 skydives, so I almost know what I am doing.
Any advice or tips?
Hide Signatures
(in reply to bry14661)
       Post #: 35
RE: Powered Parachutes - 11/4/2008 9:29 AM
Shortbuss
Score: 105
Status: offline
Damn I found a problem already. The servos arent going to be strong enough I dont think. And I am not sure if I can wire stronger servos into it. I want to make this thing out of existing junk I have lying around. I might try and construct a gondola and see how it free flys first. Then add the motor and controls.
Hide Signatures
(in reply to Shortbuss)
       Post #: 36
RE: Powered Parachutes - 3/26/2009 12:00 AM
KATANA260
Score: 100
Last Login: 11/25/2009
Status: offline
Hello everyone.
I bought a model www.paramotoreskamicaze.com and I'm very happy.
Fly very well.
It's fantastic
Hide Signatures
       Post #: 37
RE: Powered Parachutes - 3/27/2009 6:30 PM
rcflyby
Score: 100
Last Login: 5/16/2013
Status: offline
I have an airfoil paraglider. What engine do you have on yours. Mine has a O.s. 46 fx. First make sure the line are not tangled and then hook it up. I lay the chute spread out on the runway with the open to the back of the paraglider. I give about half throttle or less till the chute fills with air and I can steer it. the I give her the onion and take off. If you would Like i will film it and post on youtube for you. I going flying this weekend and I love to fly mine and film with it. I also let other newbies fly it. Its a great training tool. I post on ofmy flight on youtube last night. Check it out.
Thank you,
Mike
Hide Signatures
(in reply to KATANA260)
       Post #: 38
RE: Powered Parachutes - 3/27/2009 11:09 PM
KATANA260
Score: 100
Status: offline
I have OS46
Hide Signatures
(in reply to rcflyby)
       Post #: 39
RE: Powered Parachutes - 3/29/2009 6:10 PM
BigTb17
Score: 136
Last Login: 9/23/2012
Status: offline
edge pilot, I know it has been a long time since you posted, but I was just wondering if your powered parachutes/paragliders are available yet. My buddy and I saw them on display at the Toledo show and he has wanted one ever since. He actually just brought it up again the other day because with the show coming up again, he was hoping they would be available to purchase this year. Now I found this thread and was just wondering it they are available yet.
Edit: Went to your website and found them. Guess I should have spent a few seconds searching first . Thanks.
< Message edited by BigTb17 -- 3/29/2009 6:36 PM >
Hide Signatures
       Post #: 40
RE: Powered Parachutes - 3/29/2009 10:16 PM
KATANA260
Score: 100
Status: offline
You can Buy it in www.paramotoresrc.com
Email: juanpacho@telefonica.net to order.
Hide Signatures
(in reply to BigTb17)
       Post #: 41
RE: Powered Parachutes - 7/7/2009 11:29 PM
Tcoltpilot
Score: 100
Last Login: 6/13/2011
Status: offline
My brother just got his PPC from Seabreezeparachutes last Thrsday and is in the process of getting it all together. We are both in our early 50's. I gave him my Airtronics RD6000 to put in it as I no longer have a use for it. What a nice set up as I viewed the video of his PPC in action during its test flight by the company. Yes all chutes are tested before they are shipped even if it takes an extra day or two because of weather conditions. The web site is awsome and takes you through every stage of how the chutes are put together. I would have to say a very nice product with quality materials and personel workmanship. My brothers PPC can be viewed at the following link (http://www.seabreezeparachutes.com/2009-parachutes/82/82-6-28-09.wmv) that was videoed by the company before being shipped. He and I should be ready this weekend for the first flight. My brother has had a flight in a real PPC and enjoyed the experience. I am getting my brother involved with the RC aircraft side to include AMA and local clubs. I personnaly fly the Aeroworks Pitts Python with a DA-50 and smoke. What a plane. I have been into RC for about 35yrs. Hope this brings some insight into the PPC world.
Tim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 42
RE: Powered Parachutes - 9/23/2009 12:05 AM
N5RMQ
Score: 100
Last Login: 3/2/2011
Status: offline
I just got my Seabreeeze parachute and gondola. I am having a ball flying it, with no prior experience I took it out and had a very successful flight. I now have a Canon digital camera mounted on it and the videos are awesome. The customer support you get from Troy is not like any support you will find at anyother business today. He goes way beyond the term "customer support" His website is amazing you can spend days there looking and reading. Check it out you wont be sorry. Seabreeze Parachutes is THE PLACE for paraplanes, the product quality and support are phenomonal.
Hide Signatures
(in reply to Tcoltpilot)
       Post #: 43
RE: Powered Parachutes - 2/9/2010 9:30 AM
urs856
Score: 100
Last Login: 12/8/2012
Status: offline
Katana
hi! i need your help to translate how much the electric version in usdollar pls.
do they have an english forms bec its hard to understand to register to their website. thank you.
Hide Signatures
       Post #: 44
RE: Powered Parachutes - 6/13/2011 9:51 PM
Tcoltpilot
Score: 100
Status: offline
I have the Sea Breeze PPC and it flies great. I had it made in the American Flag and have done a lot of opening RC Airshow ceremonies with it. Just a great piece of work and made in good ole USA. It's worth the price as mine is the 82" chute. I have many folks ask where they can get one. The best thing is that each chute is test flown before shipping and you get a video of it to see your chute in action. I do touch and goes with it ROG, and really nice tight turns. I can even taxi it in without the use of nose wheel steering.
Hide Signatures
       Post #: 45
RE: Powered Parachutes - 3/7/2012 1:16 AM
flyinjrc74
Score: 101
Last Login: 5/6/2013
Status: offline
Not sure how to post pics on here but here is a link to my blog on my Airfoilz Powered Chute on RCGroups. I have since sold it and now working on a 120" SeaBreeze that will be powered with a 15cc RCGF gasoline engine swinging a 14" prop.
http://www.rcgroups.com/forums/showthread.php?t=1550126
My Airfoilz flew well and I converted it from the way it was intended for a nitro .15 to a 1120kv outrunner turning a 10x7e APC prop. I had a blast with it and as usual it is time to go bigger!
There is a video online of a guy flying a 120" chute using a CCRC 26 gas engine. It flies well but to keep weight down and also to be able to mount a cam on it I will be using my 15cc gasser!
Hide Signatures
       Post #: 46
RE: Powered Parachutes - 5/29/2012 2:03 AM
F1992
Score: 100
Last Login: 5/18/2013
Status: offline
I made same models (~8) different design rc powered parachutes.
My friend is crezy about RC powered parachutes too.
We both jamp to connclusion, that according to fly parameters and anothers on first place - HIROBO parachute, the second place - sea breaze, three place - airfoil aviation, four- five places parachutes from France and ES.
I used sea breze 66" and ES.
ES has very specific design - central sells have hol on back side for stabilization!!
I will try soe sea breaze in fly.
I have sea breaze 66" (5-7 flies and ES 55" (new ) for sale.
If interesting give me to know
PS. Unfortunately my web site cannot display.
(I have ~ 20 photos...)
If interesting give me to know.
Hide Signatures
(in reply to 13BT)
       Post #: 47
RE: Powered Parachutes - 5/29/2012 5:28 AM
flyinjrc74
Score: 101
Status: offline
I am selling this 120" SeaBreeze I built! It flies awesome and runs on 32:1 gas oil mix! $750 Spektrum BNF or $700 RX ready! Anybody needs one with all of the hard work finished and one that will last see my ads. The engine is a 15cc RCGF Ei.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to F1992)
       Post #: 48
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.219RCU1
