RE: Powered Parachutes
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: Powered Parachutes
Page: <<   < prev  1 [2]
Login
RE: Powered Parachutes - 6/20/2007 3:09:18 PM
13BT
Status: offline
is there a source for replacement chutes for the sky surfer? Just in case mine gets too messed up in the future
_____________________________
Those flames are normal, officer!
(in reply to para.nick)
       Post #: 26
RE: Powered Parachutes - 7/7/2007 8:24:32 AM
SCMSteve
Status: offline
I have two chutes from troy at http://www.seabreezeparachutes.com the customer service cant be beat he test flys everyone and video tapes them and sends it to you before you ever get it. I havent found a better one yet. He has 3 sizes and a 2 year gaurantee.
(in reply to 13BT)
       Post #: 27
RE: Powered Parachutes - 7/13/2007 2:38:19 AM
neubs
Status: offline
I was going to buy one of the powered parachutes from airfiol aviation but I though to myself, " I can make one of those myself" so I started building and now I'am almost finished making my home made custom powered parachute! The parachute is 96 inches and I made it myself. I went down to the local fabric store and bought five yards of rip-stop nylon and started sewing. It took me about 10 to 15 hrs to make the "gondala" and about ten to make and sew the parachute.
(in reply to SCMSteve)
       Post #: 28
RE: Powered Parachutes - 7/14/2007 3:43:53 PM
nebg9
Status: offline
That sounds like a very good idea making your own parachute. I bought a sky surfer about 4 years ago and have been having a blast with it. However, now I have gotten to the point where I am bored with the stock setup and am in the process of upgrading it. So far, I have a park 370 3600kv brushless motor planning to make a custom geared system and a polyquest 3 cell 1200mah lipo. I'm replacing the receiver and esc, too, of course. But after coming along to your post I thought of the poor shape of my chute and am now interested in making my own. How do I go about doing that?
(in reply to neubs)
       Post #: 29
RE: Powered Parachutes - 10/4/2007 3:37:08 AM
homeadeflyer
Status: offline
Hey edge you seem like you know a lot about RC parachutes. Could you use a NPW (http://members.shaw.ca/kiteman/NPW9b-4.0m.htm) as a wing? I know they used to be used as parachutes but would i be able to climb with a motor? Also I think it would make an interesting chute for you to try (very easy to make, i have a 5.5 meter kite that will pick me up)
(in reply to edge_pilot)
       Post #: 30
RE: Powered Parachutes - 10/4/2007 8:50:00 PM
edge_pilot
Status: offline
Thanks, but I wish we knew alot more! We are in the test faze of designing a new Ultimate canopy to go along with our Ultimate diver. Alot of research and development, time and money. We spend 4 hours to sew a chute that doesn't meet our needs, thats dissappointing. As far as the kite for a parachute, not a good idea. The only thing they have in common is there looks from a distance. They are usually made of 2 differant materials, (not all ripstop is the same), they are usually strung up totally differant. Parachutes actuall use the airfoil to create lift, a kite catches wind to propell it up. I can lift myself off the ground with a bedsheet if the wind is right! That doesn't mean the kite will create any lift at all once put in the horizonal possition to be used as a parachute. I know the kite thing seems to be a good place to buy a cheap wing, but you are just creating a bunch of headaches for yourself if you think this will work. All this said is just my 5 years of experience and trial and error opinion. In no way have I tried evrything. I beleave we are on a good track though with this new chute we are making, due to the overwelming input I have taken in from many people in the hobby and in full scale chute design.
Dave Naylor
Owner of RCSkydiving
(in reply to homeadeflyer)
       Post #: 31
RE: Powered Parachutes - 8/10/2008 3:54:47 PM
Fred 1969
Status: offline
I just purchased a used Airfoil Aviation's 1/3 scale powered parachute and have some questions I was hoping someone could answer. First I must say that the company that produces and sells these sucks they provide no help whatsoever, don't care to help you and are rude. First, I was hoping someone would have some close up pictures of the way the lines are setup on the trike and approx. servo positions at rest (neutral). Not really sure of proper radio setup. What is the best way to set up my computer radio to fly this? I can tell you I have flown it and it flies great once your in the air but then again it may fly better with it set up correctly, I don't know. What take off procedure should be used. I tried to takeoff like the real thing with the chute laid out behind it but the chute inflates and acts just like a break and stops foward progress. Can't get it to continue up over the trike. The only way I have been able to take off is by having two people run alongside and help the chute up over the trike. Once it is over the top the chute flies well. Any experiences with this unit that you could pass on would be great to hear. Very happy with it but there is no support anywhere that I can find.
(in reply to samolot)
       Post #: 32
RE: Powered Parachutes - 8/10/2008 7:33:30 PM
Slammed
Status: offline
this is cool I did not know they had these
Havoc 4.6cc, FireHammer 23cc , Tmaxx HPI 21,Tmaxx 2.5,Mini LST, Cessna 182, Focus 400EP Brushless www.youtube.com/benduchi
(in reply to Fred 1969)
       Post #: 33
RE: Powered Parachutes - 10/2/2008 1:15:20 AM
bry14661
Status: offline
hey Jman, how much did it cost you to turn this into a brushless setup? do you reccomend it or would i be better off buying one that doesnt need upgrading right away?
(in reply to Slammed)
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.984RCU1
