RE: Walkera No. 52 - Indoor 6Ch Helicopter
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera No. 52 - Indoor 6Ch Helicopter
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/4/2006 10:27 PM
Bandit44
Score: 100
Last Login: 8/22/2006
Status: offline
Glad to hear that I just grabbed three of the 3.6 gram servos for 35 USD .Free Shipping.
Isn't the micron coming out with a CP version soon ?
Hide Signatures
(in reply to ptremb)
       Post #: 26
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/7/2006 6:39 AM
ptremb
Score: 100
Last Login: 2/2/2009
Status: offline
I keep hearing that along with alu. swash and grips
Hide Signatures
(in reply to Bandit44)
       Post #: 27
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/7/2006 5:23 PM
heli-john
Score: 100
Last Login: 11/10/2009
Status: offline
quote:
ORIGINAL: Bandit44 Ok besides the fact that you need to use the Walkera radio.How does this little bird fly.
What a pain, I have answered this once and added some pics but god knows where they went and after searching for them I lost my answer, which went like this.
This is a tough bird to fly but 5 times better than a Dexterity. When mine arrived the cyclic stick (mine's on the right) on the Radio was stoved in. There was not a mark on the box or packaging so I am sure it happened at the factory. Someone has whacked it or dropped it on the stick. I whipped off the back to find the little retaining plate that holds the stick's pivot pin was bent and the pivot pin had come adrift. Straightened the plate, popped the pivot pin back and replaced the plate. Seems fine now but how I wish they would not force us to have to use their radios without making lots of changes. Now my 22E flew itself out of the box but this one has a throttle/collective stick that isn't progressive. The heli is either suddenly in the air or suddenly on the ground. If it had a graphic display i could set it up to my liking but this fiddling with dip switches is not only ancient but disappointing. So for the while mine is in the box. I know it will fly but I know it will need working on first. It just needs the pitch settings altering. Boring.
_____________________________
You can if you think you can!
Hide Signatures
       Post #: 28
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/7/2006 9:42 PM
apdavies
Score: 100
Last Login: 3/13/2008
Status: offline
This is what I was saying in my earlier post, I'm sure with a good Tx this thing will be quite flyable but at the moment I have the same problem, its too aggressive and just leaps into the air. Need a replacement for the walkera 4-in-1 so a good Tx could be used with it.
Hide Signatures
(in reply to heli-john)
       Post #: 29
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/10/2006 3:41 PM
Bandit44
Score: 100
Status: offline
OK I got it and I can't get a hover out of it.The tail just goes counterclockwise when she lifts off.I can't seem to control it.Any input on why the tail is out of control will help me.I'm getting frustrated with it's stock setup.Also the servos chatter quite a bit.They can't seem to find the way back to center and they just chatter away.I have recieved the Blue arrow 3 in 1 and the reciever.Now I'm waiting for the servos.Once the servos arrive I'm taking all the walkera electronics out of it.For now I'd like to figure out why I can't control the tail.My guess is something is defective.I tried adjusting the rudder mix to full and lock mode on the gyro.I tried mix down low and lock on the gyro.I tried a bunch of different settings.When I throttle up and twist the heli to the left the tail motor throttles up and leads me to beleive the gyro is functioning properly.
Hide Signatures
       Post #: 30
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/10/2006 3:56 PM
heli-john
Score: 100
Status: offline
I have just spent an afternoon modifying the Walkera 52. It has trememdous balance issues. The tail was like it was attached to the floor. I could get it to pivot around the tail vertical fin. I decided to put a load on the front to see the effect, a long heavy (comparatively) bolt. It was a great improvement and as a result I was getting a count of three in the air so I decided to dismantle the little bugger and re-site the battery way up front. Lots of things weren't right, the motor pinion wasn't parallel to the mainshaft. Screws were loose etc. so the tailboom was not pointing upwards like it should. I shortened the tail boom by sliding it forward so as to reduce the aft weight effect. Anyway, stuck it back together with the battery slung temporarily on the front of the undercarriage. Balance now a lot better, almost dead right. With the canopy on I think it'll be purfec. I put her in the air and BINGO, about a count of 10 straight off. However, after a few minutes the battery was low so end of fun 'til I recharge. The conclusion, weight balance critical. Needs a battery tray mounted up front under the canopy.
To be honest, this now flies as well as a hoverfly.
Hide Signatures
       Post #: 31
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/11/2006 2:40 PM
Bandit44
Score: 100
Status: offline
I got the tail stabilized.I moved the 4 in 1 to a different position and that seemed to cure the tail problem.Since the tail has been going wild since I got it the blades are in bad shape.I was able to get her up for a 3 count and then batterie died.I'm charging it now.Seemed like she was pretty stable for the few seconds it was up.I also took it apart and gave an extra turn on all the lose screws .Pushed the boom in and temporarily hung the batterie up half under the 4 in 1 and half under the skids.There was a lot of loose screws.I need blades.
Hide Signatures
       Post #: 32
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/11/2006 8:59 PM
The_tinchers1
Score: 100
Last Login: 2/17/2007
Status: offline
Has anyone had problems with the battery for the Walkera #52. I just got mine and it will only hover for about 15 sec before it losses power and I have to recharge wich only takes about 5 minutes before it says it if done. For the most part I like the little bird but the flight time of 15 sec has me bit upset.
Hide Signatures
       Post #: 33
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/12/2006 6:24 PM
heli-john
Score: 100
Status: offline
Have finally got the ship to fly right - still a handful but is now in the air. Main thing I did after moving the battery was to get all outputs to 90° and all surfaces at zero at midstick. Finally the next main task was to (re)set the pitch and the throttle curve. In doing this I broke my first blades. In my book this is where knowing what you want the heli to perform like makes this task possible - I can see if it needs more pitch or juice etc. from experience - and is where a beginner would probably be most at sea with this heli. This is what makes all the difference. Plus which by now I am starting to learn to fly it. All this done I was able to check blade tracking (while light on the floor!!!) and correct as necessary. Now I can hover it within a 6 foot square, it still isn't easy but I have to admit, I set the throttle/collective/rudder stick to get lift off and then, unbelievably, more or less, leave it alone and concentrate on cyclic. Yes, it will hold it's heading lock solid and it's height pretty well unattended. It has gone from a pig bouncing up and down to a real flying machine. However, it will be a cold day in hell before I can fling it around the room. It needs a 20 foot square room for that. I really think this heli is not for the faint hearted.
Hide Signatures
(in reply to The_tinchers1)
       Post #: 34
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 1:59 AM
Thorndike
Score: 100
Last Login: 4/25/2008
Status: offline
Hey guys, well I've had my 52 for about three weeks, and I am pretty much satified with it. I am getting about 10min flight out of it. I have had no problems with the stock batery, I think the chargers that come with them are junk though. The stock charger takes about 15min to charge and my electifly charger set at 300 takes 45 mins and I get a lot longer flights out of it. A good batery is the 3 cell 300mha "20" from hobby lobby.
This is my second walkera heli and both of them have no problems with the electronics, go figure. My servos do chatter a little though.
I am not pleased with how fragile certin parts are. I started on a walkera #4 which you can almost fly straight into the ground with hardly any damage.
I have gone through 2 sets of blades, flybar, main motor and landing gear.
To solve the balance problem, I use velcro to hold the batery under the receiver/gyro. I completely removed the battery holder.
I also drilled out the tail motor and tail boom clamp to fit 4mm (I think) carbon fiber tube so I don't have to pay 10 buck everytime I break one.
All in all not a bad little chopper, it is a little twitchy but is pretty easy to controle.
Hide Signatures
       Post #: 35
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 2:12 AM
Thorndike
Score: 100
Status: offline
I forgot to ask, where is everyone getting spare parts? I bought the heli and the first round of extra parts through rc-fever.com but I hate the long wait for the shipping from HK.
Hide Signatures
(in reply to Thorndike)
       Post #: 36
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 2:18 AM
The_tinchers1
Score: 100
Status: offline
RCandMe.com will be carrying parts for the #52 shortly.
Hide Signatures
       Post #: 37
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 9:04 AM
heli-john
Score: 100
Status: offline
I get my 52 spares from these people:
http://cgi.ebay.co.uk/Walkera-Dragonfly-52-7CH-RC-Helicopter-Radio-Control-NR_W0QQitemZ6065821369QQcategoryZ123847QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
No problems.
I find the lack of image posting facility in this forum to be a real pain.
Hide Signatures
       Post #: 38
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 9:12 AM
twisted-pixel
Score: 100
Last Login: 9/28/2006
Status: offline
I hope to finally get my 52 out of it's box this weekend. Bought it a couple of weeks ago, but haven't had a chance to even look at it yet. I imagine I'll spend a few hours trying to get it set-up before attempting to get it in the air....only to crash it I bet
Hide Signatures
       Post #: 39
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 9:24 AM
heli-john
Score: 100
Status: offline
I made the mistake that it would fly straight out of the box like my Walkera 22E did. After I had spent time doing whay I oughta have done in the first place, this heli outperforms anything I have had in the sub micro range (mind you, that isn't saying much!!!!) and is looking like a real flying machine worth keeping. Time will tell!!!!
Good luck with yours.
Hide Signatures
(in reply to twisted-pixel)
       Post #: 40
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 9:32 AM
twisted-pixel
Score: 100
Status: offline
do you have any tips then?...what should I do first or where should I start?
my normal method is pretty standard I think:-
check for loose screws
centre servos
balance blades
check tracking (although I often find that at full power the lift of the blades varies as they flex and never gives a perfect track)
and then try a few hops....
Hide Signatures
       Post #: 41
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 11:52 AM
heli-john
Score: 100
Status: offline
Other than what I have posted I can't think of anything. The major improvement was to sling the battery forward to get CoG right and preferably with a little forward leaning. I am going to mount the tray on kebab sticks like a stretcher forward of the undercarriage. The next improvement to make any significant difference was setting the control rods to 90°(with control surfaces horizontal) at half stick and then finally getting the radio settings to suit me. I know I dialled in more rudder mix but did most of it by "eye". It ain't perfect but it is better than some.......and it flies!!!!!
Hide Signatures
       Post #: 42
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 7:15 PM
Bandit44
Score: 100
Status: offline
Mine is in the closet due to frustration.I been flying an Esky Lama around to pass the time.Very stable and very fun to fly.I am waiting on the servos still and new blades before I give this little guy another shot.Parts aren't local.I ordered blades from same guy on ebay.
Hide Signatures
       Post #: 43
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/14/2006 9:45 PM
heli-john
Score: 100
Status: offline
I can honestly say that, as a concept, this is one of the best littl'uns. Stick at it as I am confident you will succeed. I have put a pic in my gallery showing the way I have used the kebab stick to hold the battery tray. Haven't flown it yet with the battery in that precise position.
Hide Signatures
       Post #: 44
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 7:04 AM
JohnY2004
Score: 100
Last Login: 7/8/2006
Status: offline
The heli beary lifts itself with the 050 carbon brush motor.
Hide Signatures
       Post #: 45
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 3:00 PM
heli-john
Score: 100
Status: offline
While I was messing with pitch curve and ATV I had the same problem - no lift. It seems mine needed the pitch and travel at high setting - but then, if too much, it'll leap in to the air. So sensitive on the adjustments.
Hide Signatures
(in reply to JohnY2004)
       Post #: 46
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 3:05 PM
The_tinchers1
Score: 100
Status: offline
Mine was doing the same thing. It would get off the ground for about 15 sec then nothing. It seemed it had a lot of power just sitting there. So I charged the battery again, and it would only hover for about 15 sec with a full charge.
Hide Signatures
       Post #: 47
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 5:23 PM
heli-john
Score: 100
Status: offline
tinchers1 Did you get a new battery from the supplier as you should be getting nearly 10 mins??
Hide Signatures
       Post #: 48
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 8:49 PM
The_tinchers1
Score: 100
Status: offline
Yes, it was brand new in the package. I am working with the dealer to try and get a new one.
Hide Signatures
       Post #: 49
RE: Walkera No. 52 - Indoor 6Ch Helicopter - 6/16/2006 10:45 PM
The_tinchers1
Score: 100
Status: offline
Does anybody know if you think a 11.1V, 1000 mAh would work on this heli.
Thanx
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.266RCU1
