bobhvac
Joined: 9/2/2006 From: Montgomery, NY, USA Status: offline
Hi all, Just received my 52 from china/ebay yesterday, only 7 day delivery not too bad... Ok out of the box, found this little carbon rod/pin, I guess thats to hold on the tail plade with the rubber hold down nut/fastener. Good thing, I opened it on the sheetmetal layout table, both parts were rolling around in the box. Put the lipo battery on the supplied charger, and inspected the heli. The battery charger went green in 5 minutes. Ok here we go on the shop floor, wow a bit of trimming the cyclic to the left and in the air she was in the air. Right into a hover, I'v only been flying heli's for a month. Drifting around the shop a bit I had to set it down. Ok after about 3 minutes of playing my battery couldn't generate enough lift to fly it. Note to self, Adding more throttle, had my blades whipping the air with too much pitch, was killing the battery too quick. Made some adjustments on the dip switches and v1 v2 knobs and back in the air again, flight time 3 to 4 minutes now. The battery charges in about 6 minutes every time. After about 4 flights in the shop, I headed out side, by the way in the shop I flipped it on its side and chopped the throttle, didn't even loose a blade. Out side, Swoop right into a hover 2 feet up, Nice and steady, I love this thing..... Flew 1 circuit around the parking lot, and the battery was failing. Couldn't hover in and dropped on the pavement from about 2 feet, No damage. Took her home and put my astroflight charger on her. Could only pump in about 100ma on the 270 pack. Ok to me the battery pack needs more c's, it seems that after you drain less than half the rating, it cant get into the air again. In conclusion, This thing is a blast, it came with the same 701 transmitter that my DF 60 came with 72mhz, not one glitch all day and night in my home. However the battery is junk, if you order one, find a new lipo pack around 300 to 480ma 12c or higher. Don't wait order the pack while waiting for the bird to arrive. Then send that one back to walkera maybe you'll get a free one. I am going to do a brushless up grade, only after I fly it for a while. A note for newbie's leave the blades loose you'll get some dihedral and she will hover better, later when your ready tighten them up and do some flying. Bob
