robl45
It will fly pretty decent. Its still a little jumpy though, not sure if that is just because of its size or if I can make it a little better. My throttle stick was very stiff when I first got the heli, I had to open up the transmitter and loosen it a bit. Now it is better, but not idea, the radio isn't super high quality. Also, make sure you turn your pitch down. My pitch is set at like the 10 0 clock position on the transmitter. Thats on the left knob when setting pitch. The right knob is in the 0 or 12 0 clock position. The servos should be fine, at least mines are decent enough to fly it around. Finally, try to get a pitch gauge on the thing just so you can get the blades at the same zero pitch and get zero pitch somewhat close to mid stick on the transmitter. And you need the transmitter in idle1 if you want to see the full pitch range.
