question about wiring my charger to a glow stick
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> question about wiring my charger to a glow stick
Page: [1]
Login
question about wiring my charger to a glow stick - 5/22/2006 2:52:39 AM
yamaans
Status: offline
Hey,
I have this Duratrax charger, and I want to attach the thing that fits into the glow stick to the charger so I can get faster charges. The thing is, I dont know which wire I should attach to positive or negative. Is the interior metal piece on the glow stick positive, or negative?
Secondly, would it be wise to discharge a one cell glow stick at a 1 amp rate? That's the only discharge rate I have.
Thanks, and sorry if my post is confusing.
       Post #: 1
RE: question about wiring my charger to a glow stick - 5/22/2006 6:23:39 AM
mikekomm
Status: offline
I Hope there's somebody following this thread that can help.
Mike
www.CommonSenseRC.com
(in reply to yamaans)
       Post #: 2
RE: question about wiring my charger to a glow stick - 5/22/2006 8:50:50 PM
yamaans
Status: offline
oh yea and would a .5 amp rate be too fast for a one cell glow stick?
(in reply to mikekomm)
       Post #: 3
RE: question about wiring my charger to a glow stick - 5/22/2006 9:03:13 PM
warcmalla
Status: offline
I did the same thing with my glow igniter and my charger for larger packs. I used a volt meter to determine which lead was pos or neg from the original glow charger. Check the charge rate of the glow igniter charger vs the minimum current you can achieve through your duratrax charger. It might be pointless to try, if your charger wont recognize the voltage from one cell. That was the case when I tried. It was a long time ago, i must say, when the novak digi-peak plus was the hot charger. I always had to keep pressing the charge button on the charger to keep it charging at low voltage and 1 or 2 amps.
       Post #: 4
RE: question about wiring my charger to a glow stick - 5/22/2006 10:31:37 PM
yamaans
Status: offline
cool thanks man. i just tried it and all that happened was the glow stick started vibrating and humming and didnt charge, and if i switched the pos/neg, it started to spark. i guess the charger didnt recognize one cell. thanks for the help tho
(in reply to warcmalla)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
