28% Edge 540 with a 3w75Ius    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> 28% Edge 540 with a 3w75Ius Page: [1]
Login
28% Edge 540 with a 3w75Ius - 5/22/2006 6:39 AM
marshallcowboy
Score: 100
Last Login: 1/23/2012
Status: offline
Yes you read right LOL
My 28% Edge has the 3w75 on it. Lemme tell ya tons of power and a dream to fly. Now I don't recommend anyone doing what I did, and I know Tom doesn't at all. I got the engine for a good price and was looking for a home for it when I buddy told me to put it in the edge. Landings slow and predecitable with out standing verticle climb. Turned out to be a good combo on the plane and with good throttle mangement flew no different then my extra with a 60 on it. Ive got a 24x8x14 prop on the 75, fixing to order a 26x10 for it and see how it does.
Hide Signatures
       Post #: 1
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 6:55 AM
mstroh3961
Score: 100
Last Login: 3/9/2012
Status: offline
quote:
ORIGINAL: marshallcowboy
Like a saturn 5 rocket I bet!
_____________________________
Regards
Mark
Hide Signatures
(in reply to marshallcowboy)
       Post #: 2
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 7:34 AM
Ken Bryant
Score: 100
Last Login: 1/15/2012
Status: offline
Hows the prop to ground clearence? That has to be getting close. Maybe some slightly taller gear?
Ken
Hide Signatures
(in reply to mstroh3961)
       Post #: 3
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 7:45 AM
ben beyer
Score: 100
Last Login: 11/19/2012
Status: offline
I want to see pictures and a video...
Team DOD Member
www.downonthedeck.com
Hide Signatures
(in reply to Ken Bryant)
       Post #: 4
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 9:42 AM
airborneSGT
Score: 105
Last Login: 6/13/2013
Status: offline
I think there was some guy on here that did the same way over powered setup with a ZDZ 80. COOL!
PAU Sponsored Pilot
Hide Signatures
(in reply to ben beyer)
       Post #: 5
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 3:30 PM
marshallcowboy
Score: 100
Status: offline
quote:
ORIGINAL: Ken Bryant
Has plenty of ground clearance with the 24x8x14 the lg sit kinda high already and this the stock lg. When I mounted the engine to the fire wall, I cut a cpl of peice of angle iron for extra support and put them on the inside of the engine box to help keep everything together plus help with engine vibration. I'll get some pics of it with out the cowl on and next time I fly I'll see if I can get some inflight pics.
I did some checking and found the 75Ius is about 8oz lighter then the 3w60I this based on information I found on 3w's website.
MC
Hide Signatures
       Post #: 6
RE: 28% Edge 540 with a 3w75Ius - 5/22/2006 5:37 PM
Dangerous Dan
Score: 100
Last Login: 5/28/2010
Status: offline
I have flown this plane and it flew really well, Knife edge horizon to horizon an 1/2 throttle and it lands like a dream.
Dan P
when inverted down=up and up=$$
Hide Signatures
       Post #: 7
RE: 28% Edge 540 with a 3w75Ius - 5/29/2006 12:33 AM
DALE PABAJO
Score: 100
Last Login: 12/6/2012
Status: offline
I've got the same edge and plan to do the same with a 3w 70us, just hopeing every thing will fit in the cowl,I wouldn't mind if the engine head protrudes a little out of the cowl as long as every thing else fits inside, would love to see some pics of you'r edge MARSHALLCOWBOY. hey what size standoffs did you use where did you get the standoffs from any how?
WWW.LAGRARAMBETA-AEROBATICS.ORG
Hide Signatures
(in reply to Dangerous Dan)
       Post #: 8
RE: 28% Edge 540 with a 3w75Ius - 5/29/2006 7:53 AM
marshallcowboy
Score: 100
Status: offline
quote:
ORIGINAL: DALE PABAJO
I didn't use any standoffs, I cut a few peices of wood and glued then together to get the distance I needed for the engine to mount just past the cowl once in place. I also put a cpl of 2"x2" 1/16" aluminum angle iron on the inside of the engine box to help the box stay stronger due to the extra vibration of the larger engine. I did have to make a cpl of holes in the side of the cowl for the carb needles and the bottom corner of the carb to stick out since the 75Ius as the side mounted carb on it.
MC
Hide Signatures
(in reply to DALE PABAJO)
       Post #: 9
RE: 28% Edge 540 with a 3w75Ius - 8/4/2006 1:25 AM
DALE PABAJO
Score: 100
Status: offline
Ok so what your saying is that the carb. tend's to protrud out of the cowl a bit? well I just orderd my 3W 75ius the other day for my EDGE, did you do any reenforesing to the fire wall I imagine you should have the 3w 75 is kinda heavy, but ohhhh boy I do love that over power better over powered than under powered I hate weak planes.can you send me some pic's to see how you'rs look like? and how did it balance out with all the servo's in the rear or what did you need to add any lead to it?
Hide Signatures
       Post #: 10
RE: 28% Edge 540 with a 3w75Ius - 8/7/2006 5:57 PM
marshallcowboy
Score: 100
Status: offline
No lead in the tail at all. It does have the elevator and rudder servos in the tail and balanced rt in the cg range. I will try and get some pics as soon as I can, been very busy and haven't had a chance here as of lately.
MC
Hide Signatures
       Post #: 11
RE: 28% Edge 540 with a 3w75Ius - 8/7/2006 6:17 PM
Dangerous Dan
Score: 100
Status: offline
Jarrod,
You coming to texoma? you can pre-reg here, forward the link to eddy.
http://www.texomarc.org/id92.html
Dan
Hide Signatures
       Post #: 12
RE: 28% Edge 540 with a 3w75Ius - 8/8/2006 8:08 PM
marshallcowboy
Score: 100
Status: offline
Dan, Im gonna try to. That weekend is my wedding anniversery.
Jarrod
Hide Signatures
       Post #: 13
RE: 28% Edge 540 with a 3w75Ius - 8/8/2006 8:42 PM
Dangerous Dan
Score: 100
Status: offline
I hate it when that happens...Her gift to you could be a trip to Sherman...LOL
Good luck
Hide Signatures
       Post #: 14
RE: 28% Edge 540 with a 3w75Ius - 8/13/2006 4:23 AM
DALE PABAJO
Score: 100
Status: offline
MARSHALLCOWBOY I pulled out my edge from the closet as soon as I got my 75us from aircraft int. , and it seem's that I need just about 2" clearance from the engine box.I called aircraft int. and the guy's there said that I would need an engine plate that they sell and some 2"standoff's.can you briffly explian to me how did you do you edge? and if any picture's would help alot when ever you get a chance to post them.
Hide Signatures
       Post #: 15
RE: 28% Edge 540 with a 3w75Ius - 10/6/2006 7:20 AM
Mud Duck
Score: 100
Last Login: 9/21/2012
Status: offline
Hey MARSHALLCOWBOY have you had a chance to take and post any pictures of your Edge with the 3W? I would sure love to see how that monster even begins to fit in the cowling. OMG!!
Fly until the last piece stops!
AMA 5642, IMAA, Waco Brotherhood #117
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
