RE: Seagull Edge 540 - 68" (60-90) ARF New v2- Building
Tower Hobbies
Logged in as Guest
Users viewing this topic: enephel
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Seagull Edge 540 - 68" (60-90) ARF New v2- Building
Page: <<   < prev  11 12 13 14 15 [16] 17 18 19 20   next >   >>
Login
RE: Seagull Edge 540 - 68" (60-90) ARF Ne... - 4/14/2008 7:32:41 PM
Mr. Mugen
Status: online
For those running the YS110-what prop did you find best? I put the 16x4W on it for balancing purposes but am unsure if this would be the right choice?
_____________________________
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
(in reply to Geardaddys)
       Post #: 376
RE: Seagull Edge 540 - 68" (60-90) ARF Ne... - 4/14/2008 10:23:56 PM
42etus
Status: offline
I''ve got a 16x6 on mine and it still revs a little high. I''m going to try a 16x8 next time I get to the LHS. That''s with 30% Cool Power.
Paul
I know right from wrong.....Wrong is the fun one
(in reply to Mr. Mugen)
       Post #: 377
RE: Seagull Edge 540 - 68" (60-90) ARF Ne... - 4/14/2008 10:47:56 PM
Jinxx
Status: offline
I''m going to be putting a Saito 150 on mine (ordering the plane tomorrow but already have the engine looking for a home). Since i am overpowering it, I was thinking of using a 3 bladed prop. Does anyone else use 3-bladed props on their Aerobatic/3d planes? I was going to try 16x8 and 14x9. Any reason why i shouldn''t use 3 blades?
(in reply to 42etus)
       Post #: 378
RE: Seagull Edge 540 - 68" (60-90) ARF Ne... - 4/25/2008 9:36:58 PM
Tesla1856
Status: online
Thanks for the info.
My Edge 540 repair is complete.
http://www.vlsdynamics.com/rc/planes/seagull_edge_540_repair.htm
It's suppose to rain here this weekend, but I should be able to get it back in the air next week.
I put my Four-Star-40 back together and flew it a little while the Edge was out of commission.
Vince (Tesla) ... http://www.vlsdynamics.com/rc
FourStar40 .46 / P51 Mustang .46 / Edge540 Saito1.25
(in reply to TomTreese)
       Post #: 379
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 4/25/2008 10:29:16 PM
digtman
Status: offline
I like to know if the 1.20 os 2 cycle will hoover the edge with a 16X5W prop?
(in reply to Tesla1856)
       Post #: 380
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 4/30/2008 1:50:34 PM
Mr. Mugen
Status: online
42etus-did you get a chance to try the 16x8?
(in reply to digtman)
       Post #: 381
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 4/30/2008 4:31:44 PM
42etus
Status: offline
quote:
ORIGINAL: Mr. Mugen
Nope. The LHS doesn't have one, so I'll have to add it on to my next Tower order. I do think that a 16x8 will be the one to use, though.
42
       Post #: 382
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 4/30/2008 8:58:16 PM
Mr. Mugen
Status: online
Well my lhs had one so I scooped it up and threw it on after balancing. I got it started up but forgot to bring the tach out so I will get those numbers tonight at the field. What an awesome running engine! Could not believe the transition from idle to full and vise versa.....nice!
Kevin
       Post #: 383
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/1/2008 3:52:04 AM
Mr. Mugen
Status: online
I maidened it today! It was awesome! I think the motor could have produced more power but I kept it a tad rich due to the cold. It was a great 2 flights with lots of power. What fuel are you guy's using with the YS's? I use wildcat 15%/18%oil. Is this good for this motor?
Kevin
       Post #: 384
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/1/2008 4:11:43 AM
42etus
Status: offline
quote:
ORIGINAL: Mr. Mugen
Kevin
Try some Cool Power 30% helicopter fuel. It'll give you a higher top end and a more reliable idle. You'll need to adjust the needles a little. It also has 20% to 22% oil. The YS engines love this stuff.
what prop were you using.
42
       Post #: 385
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/1/2008 5:34:21 AM
Mr. Mugen
Status: online
I have some of that fuel on hand actually. I run it in one of my saito's. I ran it today with a 16x8 APC prop.
       Post #: 386
RE: Seagull Edge 540 - 68" (60-90) ARF New v2... - 5/8/2008 7:09:14 PM
erec11
Status: offline
Hello G-Pete i need to ask you a few tinks because i´m planing to build this plane with a Peack 26cc that is similar to yours. So can you post some pictures on your firewall so i could see how much i need to cut because of the rear carb, and also of the cowl. And also were did you locate the CG?
(in reply to G-Pete)
       Post #: 387
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/9/2008 3:07:56 AM
Mr. Mugen
Status: online
I flew the crap out of this plane today and it was a blast. It hovers at just under 1/2 stick and pulls out with authority. Using the 16x8 right now and will try the 16x6 next. I got 2 hours of flight out of it tonight. What a gas!
Kevin
(in reply to erec11)
       Post #: 388
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/11/2008 1:15:43 PM
Mr. Mugen
Status: online
Here is some vid of a pal and I flying these planes yesterday.
http://www.youtube.com/watch?v=cmNWTdgemMQ
       Post #: 389
RE: Seagull Edge 540 - 68" (60-90) ARF N... - 5/11/2008 9:49:36 PM
checkmate91
Status: offline
