Tesla1856
TX, USA Status: offline
Yes, very tight like always. I even bounce the wing a bit to get that last little bit. A few times before I have found 1 or 2 or the 4 bolts would loosen 1/4 to 1/2 turn or so, but nothing like this. On the other hand, this was the first time I flew 4 flights in a row, and did this many maneuvers in one day at the field. I've researched this problem on the board, and it's pretty common (as you might imagine). Some of the more popular fixes are various kinds of rubber and plastic washers (and lock-washers), different bolts, silicone tubing, loctite, and PVC tape. Some of these may work, but I bet they have all been known to fail at some point. Bolts loosen with vibration and that's a fact. Still not sure which one I will try first. quote:
ORIGINAL: TomTreese Were they real tight when you assembled the plane?
_____________________________
Vince (Tesla) ... http://www.vlsdynamics.com/rc FourStar40 .46 / P51 Mustang .46 / Edge540 Saito1.25
