RE: BAD EXPERIENCE WITH FLITON PLANES    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> RE: BAD EXPERIENCE WITH FLITON PLANES
Page: <<   < prev  1 [2]
Login
RE: BAD EXPERIENCE WITH FLITON PLANES - 7/4/2008 7:20 PM
mark nichols
Score: 100
Last Login: 6/1/2010
Status: offline
Oh Well the wing tube decided to part from the wing with three ribs still on, still secured to the fuselage at about 50 ft. Plane a total wreck. So thats poor uc and obviously lack of glue on the wing.
I have another aj extra and will build as plane flies so well, but will not be buying another fliton to many bad stories and the worst support ever.
Mark
Hide Signatures
(in reply to mark nichols)
       Post #: 26
RE: BAD EXPERIENCE WITH FLITON PLANES - 7/8/2008 10:05 PM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
Even after this, I'm in line to buy a Fliton Edge Freestyle. I'm just waiting for the "go ahead" from my parents.
_____________________________
Tact is for people not witty enough to use sarcasm.
Hide Signatures
       Post #: 27
RE: BAD EXPERIENCE WITH FLITON PLANES - 11/7/2008 7:19 PM
mark nichols
Score: 100
Status: offline
I still bought another one cause they fly so well, just had a small battery cut off issue and do i buy another well yes, because it flies so well.
Im not slamming the plane, its the poor customer support, great product bad support, and with precision aerobatics raising the game its getting hard to choose.
I would say third time lucky but what fun ive had and annoyance.
Mark
Hide Signatures
(in reply to victorzamora)
       Post #: 28
RE: BAD EXPERIENCE WITH FLITON PLANES - 12/21/2008 10:45 PM
sidav
Score: 100
Last Login: 2/23/2013
Status: offline
if your heavy handed things break in your hand, very very weak wont be buying another. nice to fly though
Hide Signatures
       Post #: 29
RE: BAD EXPERIENCE WITH FLITON PLANES - 1/22/2009 12:15 PM
woo
Score: 100
Last Login: 5/23/2013
Status: offline
Advantage Hobby will stock new Fliton products
from 3rd week of Feb.
Hide Signatures
       Post #: 30
RE: BAD EXPERIENCE WITH FLITON PLANES - 5/30/2009 2:26 AM
jdbf
Score: 100
Last Login: 5/30/2009
Status: offline
Desculpe-me a intromissao ; mas apos todas as discussoes tecnicas e de linguagem , resolvi usar a minha lingua (Portugues) para nao cometer nenhum erro .A minha pergunta é : Compro ou nao compro um kit da Fliton ?
critical parts are weak and brakes, i reported this to Fliton and they were very indifferent and did not response professional, so i advise to the r/c planes comunity to be VERY CAREFULL with FLITON planes, because they brake in the air flying because the instrucction manual is missing some VERY IMPORTANT ISSUES, plus you'll loose the money you paid for it. they wont do nothing for the customer. bummer! =-(
[/quote]
Hide Signatures
(in reply to laserbeam)
       Post #: 31
RE: BAD EXPERIENCE WITH FLITON PLANES - 5/30/2009 2:30 AM
jdbf
Score: 100
Status: offline
quote:
ORIGINAL: marcoblum
Out of 3 planes i bought, 2 crash bad (total loss) because the design in some critical parts are weak and brakes, i reported this to Fliton and they were very indifferent and did not response professional, so i advise to the r/c planes comunity to be VERY CAREFULL with FLITON planes, because they brake in the air flying because the instrucction manual is missing some VERY IMPORTANT ISSUES, plus you'll loose the money you paid for it. they wont do nothing for the customer. bummer! =-(
Hide Signatures
       Post #: 32
RE: BAD EXPERIENCE WITH FLITON PLANES - 5/30/2009 2:32 AM
jdbf
Score: 100
Status: offline
quote:
ORIGINAL: bdavison
Marco, things break. It happens. I'm fairly sure I could snap the wings in half on just about any plane, or at least damage it in flight.
Every plane has operating limits, just like their full scale counterparts. If you want to operate the plane beyond those limits, you have to do things to it to increase its limits. Like installing carbon wing tubes, using plywood instead of balsa, reinforcements, etc.
Planes are not designed to fly full throttle all the time, or full throttle dives, or yanking tight loops with the power on. If you want it to do that you have to make it stronger and capable of those maneuvers. Many of us are taking these planes right to the limit of what they are capable of. They break. We fix them and move on.
There are hundreds if not thousands of pilots flying the Fliton planes. In many of the threads on here and other places, its already been discussed that the landing gear only takes normal smooth graceful landings. So many people reinforce them to allow them to make less than graceful landings. Problem solved, and the plane flys great. Saying that all Fliton planes are a waste of money because of this is rediculas. They are really good planes. If you cant set it down perfect, than be prepared to have to reinforce the landing gear.
Some say the wing spar is soft in some of the planes. It will fly fine as long as your not doing full power blenders and such. But people broke them doing other maneuvers, so now people are reinforcing that part to allow the plane to do those maneuvers.
Every kit has some issue or thing that could be done better. There is NO perfect kit. Ive got a Brio right now that is giving me fits with a odd stall charectoristic that others have noticed too. I dont go around telling people all E-flite planes suck just because I had a problem with mine. We are currently trying to diagnose the problem...then we will fix it and let others know.
I'm curious, did you go online before building your Fliton plane and look around at threads regarding that plane? If so, why didn't you choose to follow recommended guidance with it and reinforce the parts that wouldn't allow you to perform your choice of maneuvering? Have you found a new problem? What is it? Did you find a solution?
I apologize for attacking your spelling, but if your going to start a complaint thread. Substantiate it by supporting your claim with the facts, situation, and information leading to your conclusion.
You said "...critical parts are weak and break". What critical parts?
You said "...instructional manual is missing some very important issues". What important issues?
You said "... they won't do anything for the customer?". What did you ask them for? What information did you provide to them? What was the response?
Chiedo scusa per l'attacco della vostra ortografia. Spiacente. Non ho realizzato che provenivate dall'Italia. Il vostro profilo dice Miami, FL.
Guten tag, Herr Marcoblum.
Wirklich kann ich andere Sprachen sehr gut sprechen. Vielen Dank.
Je peux egalement parler francais.
Vraiment inutile. Je ne projette pas sur visiter la France n'importe quand bientot.
Im het leren Nederlands.. Het helpt met de F3Ai websites Ik geniet van.
Im niet zeker dat is correct. Im het nog leren Nederlands. Het is een harde taal. Ik denk die is correct gespeld.
I'm also curious which ARF electric kits in this size range you've had that were covered better than a Fliton. Ive owned and flown just about every manufacturers planes at one time or another. So far the only one that comes even remotely close to Fliton is Hyperion, but they still exhibit some of the warping like the E-flite kits have.
Hide Signatures
(in reply to bdavison)
       Post #: 33
RE: BAD EXPERIENCE WITH FLITON PLANES - 7/28/2009 2:18 AM
rmillerawacs
Score: 105
Last Login: 4/28/2013
Status: offline
quote:
ORIGINAL: rc-sport
My FLiton Extra broke too, when it hit the ground.
hahaha!!!
Hide Signatures
(in reply to rc-sport)
       Post #: 34
RE: BAD EXPERIENCE WITH FLITON PLANES - 7/31/2009 8:39 AM
tIANci
Score: 116
Last Login: 9/16/2011
Status: offline
I owned the following Flitons:
Prodigy
ICON
Extra 330 Freestyle
AJ Extra
Votec
Edge 540
Extra 330 120
Element 170
I did not end up flying the last few though ... friends took it off me like immediately since I ordered them in from Fliton direct. The quality of all the above were good. No real issues BUT some are built too light and this problem is not only Fliton's but also many other manufacturers'. The ailerons tend to warp, seen this in Sebart planes too. However, some were complaining about certain models, the AJ Extra comes to mind. Basically, the RC plane manufacturers' have kinda gone overboard with getting a plane light.
I love the Fliton Extra 330 Freestyle! It was way ahead of its time. Now the only plane I find that can outfly it are the Sebart planes. Seb's planes are superb too.
Its nice to be important, but its more important to be nice ...
Revver Brotherhood No. 232
Hide Signatures
(in reply to rmillerawacs)
       Post #: 35
RE: BAD EXPERIENCE WITH FLITON PLANES - 1/9/2013 11:05 PM
paulbyrum
Score: 100
Last Login: 5/9/2013
Status: offline
Davison is wrong when he says there is no perfect plane. 3D hobbies 89" slick is perfect in every way. you get what you pay for!
Hide Signatures
       Post #: 36
RE: BAD EXPERIENCE WITH FLITON PLANES - 1/22/2013 6:43 AM
fgdsfg
Score: 100
Last Login: 1/25/2013
Status: offline
i never meet your situation,while in my mind this is Good company, nice .planes. Highly recommended
Robust Buys
Toys and Hobbies , Radio Control Toys , RC Heli
Hide Signatures
       Post #: 37
RE: BAD EXPERIENCE WITH FLITON PLANES - 1/28/2013 3:10 AM
jackeylewis
Score: 100
Last Login: 3/18/2013
Status: offline
sorry to hear that, but it is really infuriating thing, I think other customers should pay more attention to this kind of company.
Hide Signatures
       Post #: 38
RE: BAD EXPERIENCE WITH FLITON PLANES - 2/10/2013 9:57 PM
mbrewer
Score: 100
Status: offline
I have a 330 mini and a 330s. Both are about 10 years old. The 330s has a Saito 100 on it, never had any issues with this plane. The only problem with the mini was due to a bad battery which forced me to land in the weeds, which of course yanked the gear off. I've flown these planes hard for the best part of their life and never had any issues because of the design. IMO they are some of the best performing arf's you can get.
Hide Signatures
(in reply to jackeylewis)
       Post #: 39
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
