superelf
Joined: 12/19/2003 From: denver, CO, USA Status: offline
Thought I better put my 2 cents worth in this forum. To answer a couple of questions, the 6 volt hump back battery packs fit and work fine. As for removing the tires I just pushed on them and with some minor effort they will roll right off the rims, no need to cook or boil, at least not with mine. As for getting the tires off the axle that's another story, the wheel nuts were on so tight, it will strip out the less than quality wrench they give you. it is a 2 man job, one to hold the truck while the other one uses a breaker bar to try and remove these, once removed you will notice, they have already begone to strip out on the axle. I would suggest to all, dont bother putting foam inserts in these tires, go with the upgrade to 23mm. with new wheels and tires, I know mo money. But as we all know this is not a cheap man's hobby. thank you, and goodnight.
