RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 4:09:01 PM
ThunderbirdJunkie
Status: online
quote:
ORIGINAL: chriswebb70
3). The air filter does not come pre-oiled. You'll have to oil it up yourself. Don't waste too much $$$ trying to buy filter oil. Just use after-run oil, and it should work fine. As long as the oil filter is a little sticky and has oil in it, it'll trap dirt and keep your engine safe.
WRONG! Use air filter oil. not necessarily RC specific air filter oil, because that ****'s expensive, but ATV/dirtbike filter oil will work fine too. do not EVER use after-run oil in your air filter! aftermarket engines are great, it's just far less fun shelling out the cash for one because your old engine died prematurely.
_____________________________
"Some people can mess up an anvil with a rubber hammer"-46u
(in reply to chriswebb70)
       Post #: 76
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 6:52:26 PM
naturefreak
Status: offline
I've had it since Monday but really haven't gotten a change to break it in yet. Been too busy. plan on going over it today with a fine tooth comb, and breaking it in Tomorrow.
For 300.00 I personally can't complain, looks to be a bargain. I'm expecting nothing more than a 300.00 basher, if I wanted quality
I would have spent 500-600 on a LST 2. Looking forward to hearing other peoples opinions as this truck gets out there.
I'll post my opinions as I mess around with it.
Just looking at it I have a feeling this thing is going to be a blast and could even surprise a few hard core critics.
Anyway back to my truck I'll post later with any info I have.
Wayne
USN RETIRED
(in reply to ThunderbirdJunkie)
       Post #: 77
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 7:04:07 PM
REVO_RACER
Status: offline
ok
but still no 1 told me how it runs
(\__/)
(='.'=) This is Bunny.PLEASE KILL HIM
(in reply to naturefreak)
       Post #: 78
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 7:32:56 PM
chriswebb70
Status: offline
OK, so I got the recoil starter fixed. I will finish the break-in process later. I hope things go better this time around.
And yes, there is no slipper clutch assembly, so one may want to take it easy while landing. All the gears are metal though, and under warranty.
(in reply to Downhome4x4)
       Post #: 79
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 7:36:35 PM
chriswebb70
Status: offline
I've used after-run oil in my air filters for years. Never had a single problem.
IMO, as long as the air filter is sticky, it will trap dirt and keep your engine safe.
quote:
ORIGINAL: ThunderbirdJunkie
       Post #: 80
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 7:49:15 PM
chriswebb70
Status: offline
To anyone else that has this kit:
Did your kit come with tire foam?
       Post #: 81
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 8:08:22 PM
HerrSavage
Status: offline
If I understood the German correctly, I think I just read in a German forum that a guy is putting an SH28 P6 in one of these things...
       Post #: 82
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 8:10:39 PM
REVO_RACER
Status: offline
care to have a link cause i can read german (kinda)
(\__/)
(in reply to HerrSavage)
       Post #: 83
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 9:12:15 PM
HerrSavage
Status: offline
Looks like I was right - he is putting an SH P6 in it.. Says pictures are to come shortly...:
http://www.rcindependent.com/wbb2/thread.php?postid=122059#post122059
(in reply to REVO_RACER)
       Post #: 84
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 11:15:31 PM
digout
Status: offline
Mine did not have the foam in the tires when it arrived. I called Tower Tech Support and they said they would give me new tires if I had any problems while running. I ran it for about an hour during break-in and found that the running motion kept the tires true and had no problems. Evidently, it being so light, the tires ran okay during the day's runs. I can understand that if the truck was to be jumped, it would definitely need the foams in them. So far the terror has been a good buy for the price.
       Post #: 85
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/10/2006 11:51:09 PM
REVO_RACER
Status: offline
i think my revo is gonna get a new best friend
(\__/)
(in reply to digout)
       Post #: 86
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/11/2006 3:35:28 AM
chriswebb70
Status: offline
Hey guys, tell me how to fix this....
Every time I apply any throttle at all to my engine, it dies.
HSN is set at 3 1/2 turns out
LSN is set at 3 1/2 turns out
Digout, what do you have your carb settings at?
       Post #: 87
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/11/2006 3:43:00 AM
Downhome4x4
Status: offline
look at the manuel it should tell you what the factor or baseline settings are. At 3 1/2 out that seem kinda Rich (to far out) If it doesn't tell you in the manuel then i would set them HSN 2- 2 1/2 and the LSN 2. From what i have sen that should get you going. you might could also try the pinch test to check you LSN setting. It should idle for about 5-6 sec then die. Hope this helps
       Post #: 88
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 12/11/2006 4:18:40 AM
chriswebb70
Status: offline
The manual says 3 1/2 turns out.
I thought that was a little too rich.
I'll try 2 turns tomorrow and see how it works.
