chriswebb70
CO, USA Status: offline
I've used after-run oil in my air filters for years. Never had a single problem. IMO, as long as the air filter is sticky, it will trap dirt and keep your engine safe. quote:
ORIGINAL: ThunderbirdJunkie quote:
ORIGINAL: chriswebb70 3). The air filter does not come pre-oiled. You'll have to oil it up yourself. Don't waste too much $$$ trying to buy filter oil. Just use after-run oil, and it should work fine. As long as the oil filter is a little sticky and has oil in it, it'll trap dirt and keep your engine safe. WRONG! Use air filter oil. not necessarily RC specific air filter oil, because that ****'s expensive, but ATV/dirtbike filter oil will work fine too. do not EVER use after-run oil in your air filter! aftermarket engines are great, it's just far less fun shelling out the cash for one because your old engine died prematurely.
