RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR
Page: <<   < prev  70 71 [72] 73 74 75 76 77 78 79   next >   >>
Login
RE: ... - 5/11/2008 8:15:35 PM
BudBud
Status: offline
It will, I used a couple of them, one new one did not work and I had a couple die already. I have been using the MG995 lately. Several Ebay sellers sell them for around 15 dollars shipped. A 180 oz servo that seems to be pretty good. BB
_____________________________
Doing my best to fill a 55 gallon drum with broken or worn out R/C parts.... 8^)
(in reply to tyson08tyson)
       Post #: 1776
RE: ... - 5/13/2008 10:41:09 PM
amf66
Status: offline
I have heard bad things about those servos, do you think that they are any good?
Tower Terror | HPI Nitro Rush
I''d rather be bashing...
(in reply to BudBud)
       Post #: 1777
RE: ... - 5/13/2008 10:51:28 PM
BudBud
Status: offline
So far, so good, I should know for sure by the end of summer. BB
(in reply to amf66)
       Post #: 1778
RE: ... - 5/13/2008 11:35:06 PM
tyson08tyson
Status: offline
Did you get the servos (MG995) from an Ebayer in Hong Kong?
       Post #: 1779
RE: ... - 5/13/2008 11:42:59 PM
madmax93
Status: online
I have the HPI 4.6 engine in my Terror. When I hit WOT it does not pick up like it should. It also sounds blubbery. Any ideas on what it is, high speed needle or low speed needle?
       Post #: 1780
RE: ... - 5/14/2008 12:09:08 AM
BudBud
Status: offline
Too rich on the high speed, make 1/12th turn adjustments in on the screw until it clears up, if you lose ground, you can back up and be where you where. BB
(in reply to madmax93)
       Post #: 1781
RE: ... - 5/15/2008 2:38:15 AM
kdiddy93
Status: offline
well i split the clutch bell trying to press the bearing out any other good cheaper clutch bells to use over stock?
       Post #: 1782
RE: ... - 5/15/2008 2:40:01 AM
kdiddy93
Status: offline
im just looking for a cheap bell just to get it fixed with good performance
(in reply to kdiddy93)
       Post #: 1783
RE: ... - 5/15/2008 3:14:29 AM
aleknocker
Status: offline
make sure whatever you use is hardened for use with metal spur gears, if not you wont make it thru a tank of fuel before the bell is all chewed up. I put an HPI hardened bell with a Terror spur that is in my g/friends ST and it was chewed up in no time. I think that the pitch is different than most others also. Good luck
       Post #: 1784
RE: ... - 5/15/2008 3:39:10 AM
BudBud
Status: offline
I have been running the Hpi vented clutch bells without any problems. Be nice to Aleknocker, I think he has a spare! BB
Edited... I cannot spell clutch tonight... duhhh
< Message edited by BudBud -- 5/15/2008 3:58:23 AM >
(in reply to aleknocker)
       Post #: 1785
RE: ... - 5/15/2008 4:16:46 AM
aleknocker
Status: offline
as a matter of fact I do, DUH. did'nt even think of that. I replaced my super tiger .27 in that POS Evo I have with one of those .25's. It runs better now than it ever has. smaller engine but faster. It runs hot like the super tiger though, I wonder if it is because of the way the engine sets way down inside of the frame? What do you think BB?
       Post #: 1786
RE: ... - 5/15/2008 5:16:57 AM
BudBud
Status: offline
quote:
ORIGINAL: aleknocker
You are going to ask me about one of these 25s? I think I just gave away the last two I had. It is no secret that I do not have a very good working relationship with these engines. I agree with you though, air flow is extremely important for any of these higher rpm small engines. That 25 is capable of screaming! The one I did play with was pretty impressive. BB
       Post #: 1787
RE: ... - 5/15/2008 8:24:32 PM
kdiddy93
Status: offline
what exact bells would work?i know it has to be hardened and 14 teeth
       Post #: 1788
RE: ... - 5/15/2008 8:38:26 PM
BudBud
Status: offline
I have been running Hpi hardened vented bells without any trouble. I would share a link to where you can buy them but the RCU Nazi thread police have been deleting my posts lately. Try a Google search for HPI77104 or Hpi 77104 BB
       Post #: 1789
RE: ... - 5/16/2008 3:40:24 AM
amf66
Status: offline
What wt shock oil do you guys use? I would like to improve the handling of my Tower Terror and am wondering if 40wt shock oil is a good choice? I have also heard that the Trinity Xxtra Heavy Spring Set T/E-Maxx would work on the Tower Terror shocks. Here is a link to the product page: Trinity Xxtra Heavy Spring Set T/E-Maxx
