RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR Page: <<   < prev  72 73 [74] 75 76 77 78 79 80 81   next >   >>
Login
RE: ... - 5/29/2008 3:01:48 AM
BudBud
Status: offline
Clutch set and a pilot nut is all you should need. BB
_____________________________
Doing my best to fill a 55 gallon drum with broken or worn out R/C parts.... 8^)
(in reply to lisasguy4ever)
       Post #: 1826
RE: ... - 5/30/2008 12:30:34 AM
lisasguy4ever
Status: offline
Well BB I won the OFNA .26 engine. I am going to order the other parts I need from tower. Have you broken any fuel tanks yet? I have broken 2 now, one was due to hitting a full size ford while in the air the other I don't know how it broke. These trucks are alot of fun for the price, this is my first nitro truck and I will some day probally get another nitro. Thanks for all the help with this stuff.
(in reply to BudBud)
       Post #: 1827
RE: ... - 5/30/2008 1:01:44 AM
BudBud
Status: offline
I have no experience with that engine, but if it is anything close to that Ofna Picco 26, you will have a rocket!
Here is a comliation of a couple of posts I did for the Picco guys on the RCU Savage forum. If any of it helps you get that Ofna sealed up and running strong, it was worth the time to post it. BB
Here is the most unusual Picco issue. They used a plastic carb body for insulation and aluminum end bells. On some of the carbs, the plastic and the aluminum expand at different rates, probably all of them. I used red RTV to seal the first couple, then tried tire (CA) glue. If you Picco starts going wacky as it warms up, then in a few minutes it cools off to normal again, the jets setting is not the problem. This fix costs next to nothing and takes twenty minutes if that. I apply the glue in three or four coats. Just be careful so it does not run down inside the carb. I always remove the slide just to be safe. BB
I am not sure I ever had one leak here, but I always take the engines apart to inspect for metal machine shavings inside. Why not take a few seconds to apply a thin coat of sealer on the back of the block to eliminate that problem while we are in there?
I was going to make a video and decided to just take photos. Why after run oil? When I take the head off and clean everything up, I like to lube the piston during assembly and then put a drop on the crank pin before installing the rod, I put another drop in after installing the rod. That is all the lube it is going to get until fuel gets there. No sense starting dry. The alcohol is to clean all the surfaces.
It also takes next to no time to apply a thin coat on the carb base where it seals to the block.
When you get done, it looks like this, this one is an Orion 26, but it is Picco in every way. BB
This particular engine is a bump start Orion 26, everything is identical to the Picco. It was made by Picco.
       Post #: 1828
RE: Tower Hobbies Nitro TOWER Terror MT .25 RTR - 5/30/2008 6:18:22 AM
edawg12345
Status: offline
I have one and the truck screams and long, long whellies it's a kool truck
(in reply to Chronic)
       Post #: 1829
RE: ... - 5/31/2008 2:59:55 AM
tyson08tyson
Status: offline
I am looking for a dogbone for my Terror. i lost the front dogbone on one side and was wondering if there is a different brand that would work other than Towers.
(in reply to edawg12345)
       Post #: 1830
RE: ... - 5/31/2008 3:12:05 AM
BudBud
Status: offline
They are a different design than any other I have run across. The Trinity Spyder is the closest thing have seen to a Terror.
< Message edited by BudBud -- 6/1/2008 5:06:31 AM >
(in reply to tyson08tyson)
       Post #: 1831
RE: ... - 5/31/2008 3:16:28 AM
BudBud
Status: offline
Their dogbone is similar, but different... that axle end makes one wonder what wheel options that would give us. BB
< Message edited by BudBud -- 6/1/2008 5:06:46 AM >
       Post #: 1832
RE: ... - 5/31/2008 4:06:23 AM
BigGrump
Status: online
My new Tower Terror is two days old.
When it arrived yesterday, my plans were to immediately remove the stock engine and install a broken in .28, since I have several laying around on the work bench. First problem was the screws through the TVP's into the motor mounts were apparently put in with glue or at the least red locktite. I have very high quality hex drivers so I was not worried. I turned as hard as I could and nothing moved. I put a rag around the handle for more grip an one screw came loose. The other three stripped their hex heads. So, for now the idea of changing engines was out the window, because I would not be able to adjust the gear mesh.
Next I removed the stock engine and took it apart. It is a very basic .25 three port engine. I cleaned it and sealed it, then paid special attention to carefully removing the carb and then sealing it and re installing.
I put a re-chargable 5 cell battiry and soldered on deans plugs. At this point I turned on the electrics and the controller. Everything worked the way Tower intended.
In a little while I was out in the front yard starting break-in. To my suprise, it started right up and with about 30 seconds of warm up and a preliminary needle adjustment, it was on the ground and driving around. Put through about 4 tanks. I found I could not stand the flat tires the truck comes with, so using the Tower adaptors, I put a set of Proline wheels and Badlands tires on (23 mm.) Much better now.
After several more tanks today, the engine is to a point where it could be tuned. Pleanty of power once it gets up on the pipe. Soft suspension and quick steering made it a handful in the street.
Later I changed shock oil to 70 weight, changed to an airtronics radio that has some steering coltrol so it can be dialed down. I found the steering servo horn had the streeing linkage in the outermost hole, giving the steering full lock to lock control even with the controller turned down, so I moved the linkage in two holes on the horn so the servo has more leverage, but has to move farther to get full movement at the wheels. Better now in the street, with the steering turned down, it controlls much better.
Overall I first thought the truck was poorly made and drove bad, but now I have a better opinion, it is really getting fun to drive.
The brakes are grabby. Is there something "trick" to do to improve them?
Tomorrow I hope to take it to an open area and find out what it can do.
Right now, I need advise about the engine mount. Should I dremmel off the screw heads and take the TVP's apart to get it out? Or is there some other way I have not thought of. I will try to get a new engine mount from Tower.
I fully expcted the servos to be weak. I have not found this so. Before the truck arrived at my house I had planned to right away request new servos from Tower, but now I am thinking not. They are just TH servos, the steering one says "heavy duty"on it. I do not know if the servos I got are the same as everyone has trouble with. I do know, Twoer does not list these servos for sale on their web site, so I assume they are the problem ones.
Thanks, will keep you guys informed is something changes. I do, however, want to get a high performance Big Block .28 in it as soon as I can.
Dennis
< Message edited by BigGrump -- 5/31/2008 4:10:40 AM >
       Post #: 1833
RE: ... - 5/31/2008 4:13:36 AM
BudBud
Status: offline
PM me with an address.... or an e-mail address... BB
(in reply to BigGrump)
       Post #: 1834
RE: ... - 5/31/2008 8:27:27 PM
BudBud
Status: offline
quote:
ORIGINAL: lisasguy4ever
Somebody just posted in the Savage forum that they bought an Ofna Force 26 and the bolt holes are different. I wonder if that is a Revo style mount. I sure hope yours is not the same engine he bought....
       Post #: 1835
RE: ... - 5/31/2008 8:39:10 PM
BudBud
Status: offline
quote:
ORIGINAL: amf66
WOW! I just found an Axial 28 for only $109.99 here http://www.amainhobbies.com/product_info.php/cPath/1_23_79/products_id/16858
Your Terror will be like this one with an Axial 28, actually a lot stronger as we were running it really rich to finish off the break in. That is the one I gave to my oldest son. That engine is the same as an Hpi K4.6. You will lose a little top end from the 25, but the torque increase is worth it. Ebay is just cluttered with Axial 28s and Hpi 4.6 engines right now. They have a bad habit of leaky front bearings and backing plates. BB
(in reply to amf66)
       Post #: 1836
RE: ... - 6/1/2008 5:13:33 AM
BudBud
Status: offline
We went out and burned over three quarts of fuel, blew one rear shock, and two Tower Throttle Servos. One of them was a steering servo I had moved to the throttle. I spotted a few loose chassis screws and had to make some small tailgate repairs, a fun day all in all. We had a blast and I should have done some videos, it is hard to take video and blast through the park at the same time, nobody else wanted to put away their radio either. My nephew brought a ramp and I must confess I am really poor at jumping, the sharp kick up at the end of the ramp made the Terror want to back flip. It was fine with no throttle being applied, but that is like sweeping water uphill, a lost cause. BB
       Post #: 1837
RE: ... - 6/1/2008 9:29:24 AM
BigGrump
Status: online
My adventure with the Terror was cut short when it went to front wheel drive only. I figured the Diff stripped. At least that was what happened when my Savage did the same thing.
At home I took the back end off the chassis and had a chance to look close. Wow, only a loosened up set screw at the right rear hub that locks it to the axle shaft. I took the set screw out and found the end point had broken off. I cannot get the piece out of the axle, so I will order some spare parts from Tower to fix this and do the same in the future.
Since I already had the rear end out, I pilled the Diff out just to look at it. WoW, is that a robuse heavy duty gear. I am now convinced, that lacking a freak problem, the diff's can hold anything, and they are some of the best parts on the Terror.
So far so good.
Dennis
