BudBud
KS, USA Status: online
That will work perfectly! Buy away, if you switch to Hpi bells, you have to buy the hardened bell. Your Axial 28 will not turn as much rpm as the 25, so you will lose some top speed, you will never know it though, because you will love all that low end, wheel standing, grass tossing power. The kit shoes from Hpi are great, not the plastic, but the composite. I think they came on the 4.6 trucks. Anyway, aluminum is good too, just buy the springs with the shoes if you can. BB This is what you can expect, same engine, same clutch bell.
_____________________________
Doing my best to fill a 55 gallon drum with broken or worn out R/C parts.... 8^)
