RE: Ultimate 120 from Nitroplanes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: Ultimate 120 from Nitroplanes
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Ultimate 120 from Nitroplanes - 12/4/2008 11:16 PM
peregrine falcon
Score: 100
Last Login: 9/10/2010
Status: offline
thanks for the answer,
now I have orderd an SV26 V4.
Markus
Hide Signatures
(in reply to opjose)
       Post #: 151
RE: Ultimate 120 from Nitroplanes - 12/10/2008 2:48 PM
cosmospho
Score: 100
Last Login: 1/12/2010
Status: offline
How are you all holding the canopy ?? Are you using the screws method ?? I want to keep all my switches on the inside and open canopy to switch on/off so the screw idea is not soo good.... Any ideas ??
Hide Signatures
(in reply to peregrine falcon)
       Post #: 152
RE: Ultimate 120 from Nitroplanes - 12/10/2008 8:25 PM
opjose
Score: 280
Last Login: 5/22/2013
Status: offline
Well one easy way to do this is to use rare earth high strength magnets.
You can find these at most craft shops.
Normally you put a magnet next to a washer or metal ring, to hold the magnet against the metal when the canopy is closed.
However on a plane I'd advise that you put TWO magnets against each other, so you would have say four sets of magnets ( 8 total )...
Four on the canopy, and four on the fuse, set up so that the magnets on the canopy align against the fuse ones.
For even more safety you can add a "hatch latch" or other similiar device.
That way you merely pull back on the latch and pop the canopy off.
I do this all the time with my electrics and it works great.
_____________________________
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to cosmospho)
       Post #: 153
RE: Ultimate 120 from Nitroplanes - 10/14/2009 5:25 AM
Javier-RCU
Score: 105
Last Login: 5/18/2013
Status: offline
Hi,
Can someone let me know the wing cord of the nitroplanes 120 Ultimate in inches?
Thanks in advance,
Javier
When you know the paradise?... When you lost it!
Hide Signatures
       Post #: 154
RE: Ultimate 120 from Nitroplanes - 10/15/2009 4:54 AM
opjose
Score: 280
Status: offline
Which wing?
Hide Signatures
(in reply to Javier-RCU)
       Post #: 155
RE: Ultimate 120 from Nitroplanes - 10/15/2009 6:44 AM
anuthabubba
Score: 108
Last Login: 2/1/2013
Status: offline
My older version (pink/blue) is right at 9 inches top and bottom wings.
Terry in LP
Hide Signatures
       Post #: 156
RE: Ultimate 120 from Nitroplanes - 10/15/2009 6:48 AM
Javier-RCU
Score: 105
Status: offline
The two wings. I have an scratch build Extra 300. I am looking to convert it into a bipe with a Ultimate wing design, the fuse lenght is the same that the Nitromodels Ultimate.
Thanks for your help.
Javier.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 157
RE: Ultimate 120 from Nitroplanes - 10/15/2009 6:49 AM
Javier-RCU
Score: 105
Status: offline
Thank you Terry!
Hide Signatures
       Post #: 158
RE: Ultimate 120 from Nitroplanes - 10/16/2009 12:37 AM
opjose
Score: 280
Status: offline
Sounds like an interesting project.
Are you going to lower the wing?
Hide Signatures
       Post #: 159
RE: Ultimate 120 from Nitroplanes - 10/16/2009 1:42 AM
Javier-RCU
Score: 105
Status: offline
"Sounds like an interesting project. Are you going to lower the wing? "
I don´t know yet. I need to know first the vertical distance between the wings in the Nitro Planes Ultimate, could you let me know please?
Hide Signatures
       Post #: 160
RE: Ultimate 120 from Nitroplanes - 10/16/2009 2:03 AM
opjose
Score: 280
Status: offline
I'll try to measure this for you.
The wings on the Ultimate are not tapered back, rather they are straight wings.
Hide Signatures
       Post #: 161
RE: Ultimate 120 from Nitroplanes - 1/17/2010 10:37 PM
XNavyKittyHawk
Score: 100
Last Login: 12/26/2012
Status: offline
I've had the Ultimate 120 55" wing for just over a year. I installed a .26 cc gasser in it, digital servos, still has the wheel skirts on it. The plane flies great. I have actually tired to twist it into splinters in the air, and it's survived everything I could throw at it, with no problems. I have had 3 deadstick landings that didn't fair so well, and each time some damage, but the 120 is still flying like a dream. BTW the deadstick crashes were only because I was too far out to make it back to the field. (Only thing to know about a bipe is that it won't glide very far, and KEEP THE NOSE DOWN and AIRSPEED UP on a deadstick, lest you will have a rolling stall) Hope this is helpful.
Hide Signatures
       Post #: 162
RE: Ultimate 120 from Nitroplanes - 2/3/2010 2:02 AM
eloyherna
Score: 100
Last Login: 5/17/2013
Status: offline
Hello does any one know where I can get parts for an ultimate 120 55
Hide Signatures
       Post #: 163
RE: Ultimate 120 from Nitroplanes - 2/3/2010 5:01 AM
jetfixr
Score: 100
Last Login: 5/20/2013
Status: offline
You can get cowls and canopies from Nitroplanes.com, but if you need more than that you may have to post it in their support forum here on RCU.
Hide Signatures
(in reply to eloyherna)
       Post #: 164
RE: Ultimate 120 from Nitroplanes - 3/27/2012 11:41 PM
Cientifico
Score: 100
Status: offline
I have one of those planes, Just install a DLE 30 with a apc 18X8 that plane really goes
With that engine you can even do Knife edge loops
Beautiful plane with alot of power.
Hide Signatures
(in reply to dubflyer)
       Post #: 165
RE: Ultimate 120 from Nitroplanes - 12/3/2012 4:15 PM
airborne14830
Score: 100
Last Login: 4/1/2013
Status: offline
what type of reverseing servo folks are using? I have a futaba 2.4 6EXA FAAST radio i am using, and i had no look with a reverseing harness?
airborne crazy
Hide Signatures
(in reply to Cientifico)
       Post #: 166
RE: Ultimate 120 from Nitroplanes - 12/3/2012 6:59 PM
opjose
Score: 280
Status: offline
I've had no problems with these: Reverser
I used the above on many planes.
I've also used the Hyperion servos which are programmable and reversable.
You buy two of the latter and revers on for perfectly matched servo pairs. I did this for my 50cc Ultimate.
Hide Signatures
(in reply to airborne14830)
       Post #: 167
RE: Ultimate 120 from Nitroplanes - 12/4/2012 1:32 AM
XNavyKittyHawk
Score: 100
Status: offline
I use a "Matchbox" which is a bit more expensive than a reversing servo, but very accurate, and can be used in other applications as well. (Matching travel on ailerons, elevators, flaps, etc.
Hide Signatures
       Post #: 168
RE: Ultimate 120 from Nitroplanes - 12/4/2012 1:17 PM
airborne14830
Score: 100
Status: offline
Thanks I will give the reverse a try.
airborne crazy
Hide Signatures
(in reply to XNavyKittyHawk)
       Post #: 169
RE: Ultimate 120 from Nitroplanes - 12/4/2012 6:48 PM
opjose
Score: 280
Status: offline
Yeah I use Matchboxes on my larger planes. Great product, better than Futaba's equivalent.... but not cheap too.
Hide Signatures
       Post #: 170
RE: Ultimate 120 from Nitroplanes - 12/26/2012 6:53 PM
Twin_Flyer
Score: 108
Status: offline
Nice to know it flies well, too bad its always out of stock...
Bill S.
Carl Goldberg Ultimate Brotherhood #56
Ultra Sport Brotherhood #135
http://radiocontrolhobbies.freeservers.com
Hide Signatures
       Post #: 171
RE: Ultimate 120 from Nitroplanes - 3/13/2013 9:21 PM
airborne14830
Score: 100
Status: offline
with the nitro Ultimate version has folks used the one elevator setup with success, and are there any watchouts?
airborne crazy
Hide Signatures
(in reply to Twin_Flyer)
       Post #: 172
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
