rc3dflyr
Joined: 4/27/2006 From: Rocklin, CA, USA Status: offline
quote:
ORIGINAL: reynolds-racing quote:
Well, I didn't have a chance to wring it out yet, but it has plenty of power for any thing you want to throw at it. It is lacking in pull out from a hover though. Not to say it's bad. I just like a little more pull. CJE (or others with an opinion), I am just referring to the prior posting in reference to the 26cc Brillelli that you have on your plane. In your view, would you recommend the Brillelli 36cc engine, or perhaps even a 40cc engine to get a little more pull? I know someone had previously mentioned that 50cc would certainly be overkill. I would like to buy the plane, put a gas engine on it, and put a smoke system on it as well. So, I am looking for a good match between performance and power to pack the added weight of the smoker. Hey Guys, check out the harrismodelproducts smoke pump,it is the smallest and lightest pump on the market. It only weighs 2 oz and requires no AUX battery. It plugs directly into the RX for power and only draws 25-40 Mah for 6 minutes of smoke, thats less than most high Torque servos. Other systems add 8+ ounces with a pump and AUX battery. The harris pump with an extra tank and lines will only add 4 oz to your airframe,the fluid is extra weight but gets pumped out during flight. rc3dflyr
