Loswave
NY, USA Status: offline
Well, I made it to the LHS today and bought the aerobatics kit, an extra tail motor heat sink, and a bell hiller kit; that pretty much wiped out my funds for today, I hope to buy more stuff next week. After installing these and replacing the flybar which was actually bent, I tried to take off using the stock battery and it wouldn't make it off the ground, I messed around with pitch for quite awhile before concluding something must be wrong. I have a thunder power 1320 mah 3S pack sitting here because the plane it normally flies in blew it's esc, so I figured I'd give it a shot. The heli took of the way it should no problem. Man it's so much more responsive, when I get used to it, that'll be great, exactly what I wanted, and tons more lift at full. So I guess I'll have to retire the stock battery now, I wasn't happy with it anyways, it always took about 2 hours to charge with a peak charger at about .8 amps, which is totally messed up. The only problem I have with this whole thing is that my Lipo was very specific that if it goes below 9v it's toast, so what's the best way to know when to stop flying? I suppose that it should stop producing enough lift to fly before it get's to 9v though. My stock battery was reading 10.5v, and it wouldn't take off on that, so I guess maybe it won't be a problem, but I figured I'd ask. Thanks for the instructions Dave, I hope to get the servos in a week or two, it looks pretty straight forward. One thing I did really like about the lipo was the increased tail authority, it seems to have much more pep now!
