RE: CMP 73" P-40 kit bash
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP 73" P-40 kit bash
Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: CMP 73" P-40 kit bash - 6/5/2006 1:31:20 AM
LDM
Status: offline
Wydah , I plan on useing flite skin on mine , I just did this on a Seafury and the flitetskin is so thin , warp resistant , and when you add ribs its as strong as carbon fiber .
I am very curious on the hindge set up , did you add an internal crossbrace in the wing so that the hinges had a place to catch ?
Again , thanks for the answers you did a great job
_____________________________
LDM
(in reply to WYDAH)
       Post #: 26
RE: CMP 73" P-40 kit bash - 6/5/2006 12:50:02 PM
tahustvedt
Status: offline
I glued 3x10 mm hard balsa under the edge of the wing between the ribs and cut a hinge slot diagonally down so that the hinge point ended up at the skin. The flaps are built up 2 mm balsa with 3 mm ribs and a 3x12 mm leading edge beam. I used 2 mm balsa between the ribs to make a box structure in the forward 1/2 so they're pretty stiff and very light. I used three heavy duty pinned Du-Bro hinges on each flap.
(in reply to LDM)
       Post #: 27
RE: CMP 73" P-40 kit bash - 6/7/2006 4:48:46 AM
LDM
Status: offline
Thanks for the info
LDM
(in reply to tahustvedt)
       Post #: 28
RE: CMP 73" P-40 kit bash - 6/7/2006 10:16:37 PM
tahustvedt
Status: offline
Not much progress. The flaps are connected to the servos and operate nicely, I also cut out the cockpit sides and made balsa ledges and a cardboard instrument panel shield. Then I mixed some paint and brushed it on. I'm not going for scale perfection, just a plane that looks right to me. Eventually I'd like to recover and paint the plane in a grey/green british scheme.
I ordered parts to make my own belt reduction-drive to drive the big Soloprop so that will be interesting.
Click to see fullsize image.
Click for fullsize
(in reply to LDM)
       Post #: 29
RE: CMP 73" P-40 kit bash - 6/12/2006 7:39:48 PM
tahustvedt
Status: offline
Made an aerial mast and cut out the tail gear doors.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 30
RE: CMP 73" P-40 kit bash - 6/14/2006 7:10:51 PM
tahustvedt
Status: offline
My homemade reduction belt drive. It will be mounted on 15 mm rubber vibration dampers, hence the raised lugs.
Click for fullsize
       Post #: 31
RE: CMP 73" P-40 kit bash - 6/14/2006 9:43:36 PM
tahustvedt
Status: offline
It is quite serious looking.
The gear ratio reduces the prop RPM at 1300 W to 4160 rpm, so I shoul dbe able to spin the 20" three-blade. I have pinions to achieve a slightly lower and slightly higher gear ratio as well.
Click for fullsize
Click for fullsize
       Post #: 32
RE: CMP 73" P-40 kit bash - 6/14/2006 10:31:36 PM
LDM
Status: offline
Holy cow , for lack of the what I want to say , great job , that is a serious piece of equipment , at first i thought you were crazy going with e- power but not anymore
LDM
       Post #: 33
RE: CMP 73" P-40 kit bash - 6/14/2006 11:18:03 PM
tahustvedt
Status: offline
Hehe. I only fly electric.
I have an ESM (KMP) Spitfire that I have converted to electric. The P-40 should be lighter than the Spit:
http://www.enrarot.net/videos/spitfire/spitfire06.wmv
http://www.enrarot.net/videos/spitfire/spitfire08.wmv
The reduction drive fits in the nose perfectly. The motor is conveniently positioned behind the intake on top of the nose so cooling should be good. I may have to add some fibreglass around the box.
Click for fullsize
(in reply to LDM)
       Post #: 34
RE: CMP 73" P-40 kit bash - 6/15/2006 12:51:59 AM
LDM
Status: offline
cool interesting sound
LDM
       Post #: 35
RE: CMP 73" P-40 kit bash - 6/16/2006 1:02:11 PM
Chilipecker
Status: offline
The motor and gear reduction unit looks great! I have never flown electric, but after seeing and hearing the video of your Spit, I am inspired!
Any chance you could post templates and a parts list for the power unit???
LOOK!!! There they go.... I must hasten after them, for I am their leader!
       Post #: 36
RE: CMP 73" P-40 kit bash - 6/16/2006 4:40:48 PM
tahustvedt
Status: offline
If I were to build another belt drive I would choose smaller pulleys to save weight, maybe try plastic pulleys instead, and make the assembly a little smaller. I made it tall and used a long belt to get the motor positioned by the air intake. I used big pulleys to make sure lots of teeth were engaging but the pulleys are heavier than I thought they would be.
http://www.sdp-si.com/
Parts:
Shaft: S40PX0MHG6M-100
Belt: A 6R53M067060
Pulley: A 6A53M028DF0606
Pulley: A 6A53M045DF0606
6x12x4 mm ball bearings.
Here's a CAD drawing of the parts: http://www.enrarot.net/images/belt01.zip
Later I might make a counter-rotation gearbox for my Spitfire using both gears and belt reduction.
(in reply to Chilipecker)
       Post #: 37
RE: CMP 73" P-40 kit bash - 6/23/2006 7:02:25 PM
Chilipecker
Status: offline
THANKS FOR SHARING!
Sorry to take so long to thank you. I looks really innovative and I plan on doing the research this weekend.... I am having a problem opening the CAD drawings, I can't seem to figure out what opens a DXF file! Can this be converted to Adobe or something common?
       Post #: 38
RE: CMP 73" P-40 kit bash - 6/23/2006 7:59:24 PM
jeffk464
Status: offline
I noticed a lot of you guys are not using the spinner that came with the kit. Is anyone interested in selling one of them?
(in reply to WYDAH)
