LDM
One more suggestion on the flaps , I have studied my idea and basicly want to use the flap design of the VQ P40 . How i will proceed is as follows , one draw out your flap , I will leave a 1/4 on the bottom trailing edge sheeting in place -so I will cut 1/4 from the trailing edge . Why ? this is make the bottom wing more ridgid , the flap will still appear scale from eye perception but actually go into the wing as opposed to be flush with the trailing edge , same will happen where the flap meets the airleron , I will leave aprox 1/8 " sheeting between the two , only visable from the bottom . I will sheet the inside of the wing with flight skin for strength , make my flap from flight skin and carbon fiber rods , all ribs will be wood but long strips for vertical support will be carbon fiber -hope this helps . Engine for me is a saito 180 , already broken in just need to finish some projects and get this one . also looking for either Sierra gear , century or new Robart heavy duty , question what size wheels did you use
_____________________________
LDM
