Engine choice Raptor 60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Thunder Tiger - Raptor 30, 50, 60, 90 >> Engine choice Raptor 60
Page: [1]
Login
Engine choice Raptor 60 - 5/29/2006 8:17 AM
Sharkyhatman
Last Login: 8/11/2010
Status: offline
I was curious to ask what engine would be recommended for a Raptor 60 V2? I was looking at the OS 61 SX-HG. but any suggestion would be helpful in making my decision. thanks all
Hide Signatures
       Post #: 1
RE: Engine choice Raptor 60 - 5/29/2006 1:34 PM
Charlie
Last Login: 4/20/2013
Status: offline
From a lot of posts I have read about 60 size helis, a lot of people use the OS 70 and have good luck. They seem to have lots of power for a 60 size heli. I've read post where people put them in 90 size heli and have good luck (they just change the gearing).
I guess it boils down to what kind of flying are you going to be doing. If your getting into 3D flying you want to get as much power out of your setup as possible, if you just going to be flying around then I don't think it matters what 60 size motor you use.
_____________________________
My Gallery
http://www.rcgroups.com/gallery/showgallery.php?cat=500&ppuser=13338
Hide Signatures
(in reply to Sharkyhatman)
       Post #: 2
RE: Engine choice Raptor 60 - 5/29/2006 3:33 PM
jez33
Last Login: 11/3/2012
Status: offline
yes as above but OS 70 and then also put a mustle pipe on it with loads of nitro ...the power from that will punch big holes in the sky..
Hide Signatures
(in reply to Charlie)
       Post #: 3
RE: Engine choice Raptor 60 - 5/30/2006 12:23 AM
Tomppa
Last Login: 10/5/2010
Status: offline
I recommend the Ys61 or Ys80 and good pipe. I have ys80 and hatori in my Raptor 60. Yes i know lot´s of power but awesome to fly.
-Tomi
Hide Signatures
(in reply to jez33)
       Post #: 4
RE: Engine choice Raptor 60 - 5/30/2006 12:25 AM
jsenicka
Last Login: 3/28/2013
Status: offline
My R60 is running an OS70 and a Hatori SB70 pipe on CY30%. Very nice combo. The new generation OS70 seems to have worked out the original piston issues, and the 3 needle carb is excellent
Hide Signatures
(in reply to Tomppa)
       Post #: 5
RE: Engine choice Raptor 60 - 5/30/2006 12:42 AM
Sharkyhatman
Status: offline
thanks for all the info, i think now I will go for the OS 70 engine. thanks again for the information, what problems were they having with the original OS 70? just out of curiosity
Hide Signatures
(in reply to jsenicka)
       Post #: 6
RE: Engine choice Raptor 60 - 5/31/2006 1:52 AM
barndoorski
Last Login: 3/21/2008
Status: offline
I use the os70 also. fairly easy to tune even for a new guy like myself. Although I do tend to stay on the rich side.
Hide Signatures
       Post #: 7
RE: Engine choice Raptor 60 - 5/31/2006 12:28 PM
Buck Rogers
Last Login: 4/26/2013
Status: offline
i would go the os 70 ...ys engines are great tho but a bit on the expendsive side
...OS=rolls royce of R/C thats my opinion
X50 Torque Tube
Hide Signatures
(in reply to barndoorski)
       Post #: 8
RE: Engine choice Raptor 60 - 5/31/2006 9:53 PM
jsenicka
Status: offline
Sharky,
the original OS70's had some issues with a very thin piston top resulting in burn through
Hide Signatures
(in reply to Buck Rogers)
       Post #: 9
RE: Engine choice Raptor 60 - 6/1/2006 1:44 PM
CrocEnd
Last Login: 5/5/2013
Status: offline
The 50 hyper has the now same problem.
Hide Signatures
       Post #: 10
RE: Engine choice Raptor 60 - 6/1/2006 1:53 PM
Charlie
Status: offline
WOW, don't tell me that, I just bought one of them. I didn't read or hear anything about that anywhere, where are you getting your info from?
< Message edited by Charlie -- 6/1/2006 2:00 PM >
My Gallery
Hide Signatures
(in reply to CrocEnd)
       Post #: 11
RE: Engine choice Raptor 60 - 6/1/2006 5:45 PM
Mr Lee
Last Login: 8/13/2012
Status: offline
Yes please let us know as I could be getting one soon!
Hide Signatures
       Post #: 12
RE: Engine choice Raptor 60 - 6/2/2006 1:20 PM
CrocEnd
Status: offline
Don't overley worry fellas's It has happened twice here in a month. Mine my have been running lean it also showed head gasket leakage the lean run did show heaps of smoke but who knows, It was being given a good whip round suddenley went dead , auto'ed well. The fuel was 7%castor,13% syn.,oil and 10% nitro. Go figger?????
The second 50 not mine insane head speed may be too lean too long,different fuel 20% syn. oil 10% nitro.
Conculsion Not enough nitro richer mix needed?????
The head on the piston is very thin.
Both our fuels now 22% oil syn.20% nitro and very rich burned now 3 gal.
Bob..
PS will put pic up.And check my gallery
< Message edited by CrocEnd -- 6/2/2006 1:37 PM >
Hide Signatures
(in reply to Mr Lee)
       Post #: 13
RE: Engine choice Raptor 60 - 6/2/2006 2:15 PM
CrocEnd
Status: offline
Mates holed piston
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 14
RE: Engine choice Raptor 60 - 6/2/2006 4:08 PM
Charlie
Status: offline
By the look of that picture it does look like it had a hot supper. How much fuel was burnt through it before that happen?
My Gallery
Hide Signatures
       Post #: 15
RE: Engine choice Raptor 60 - 6/2/2006 5:43 PM
BarracudaHockey
Last Login: 5/17/2013
Status: offline
We had one go but the head bolts were loose. Picture looks the same though. OS replaced it under warranty.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 16
RE: Engine choice Raptor 60 - 6/2/2006 9:07 PM
CrocEnd
Status: offline
Fuel use on that one about 4 gal's., mine 3.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 17
RE: Engine choice Raptor 60 - 6/2/2006 9:37 PM
misileman
Last Login: 3/20/2011
Status: offline
You can't go wrong with either the YS80 or OS70. Had a OS 61 WC in Raptor 60 V2 for over a year and replaced with OS70 because of 61 would bog under loads even with GV1 governor and high speed throttle servo. With the OS70, I don't even engage the governor unless overspeeding the head is evident. Just remember the YS and OS have differant crank thread size (OS american thread size - YS is metric) so you'll have to rethread the fan hub or buy a metric thread size fan for YS.
If you want to go with an OS61WC with 3 needle carb, I have one I'll sell ya, CHEAP .
Happy Landings
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
