RE: Another Hots!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: Another Hots! Page: <<   < prev  1 2 3 [4]
Login
RE: Another Hots! - 1/14/2008 2:54:36 AM
dbacque
Status: offline
After the wing and fuse are glued together you will cut out the sheeting both above and below the wing for the receiver, battery, servos and wires. You want to do the upper fuselage sides before cutting the hole in the upper wing sheeting or you may cut the hole too large.
There's no need for a hatch but installing everything is a tight squeeze. Load the battery and receiver in, then mount the servos.
Dave
(in reply to modegrande)
       Post #: 76
RE: Another Hots! - 1/14/2008 3:16:13 AM
modegrande
Status: offline
Thanks Dave, That makes better sense and less work than building a hatch. I did cut the opening for the fuel tank and since I'm using a 6oz. tank it's rather small. The top sheething should cover it with no problem.
Maurice
(in reply to dbacque)
       Post #: 77
RE: Another Hots! - 9/15/2008 5:39:44 AM
michou41a
Status: offline
here mine 12 feet wingspan
Click to see fullsize image.
Click for fullsize
       Post #: 78
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
