dbacque
TX, USA Status: online
Oh yeah, the fuselage sides are 1/8" balsa. So that's lots of 1/16" balsa (10 - 12 sheets I think), probably 4 sheets of 1/8", enough 3/32" for the tail surfaces and ply as called for. Again, don't forget to add ply fuselage doublers, 1/16" or 3/32 should be fine. There's also the two 1/4" square x 48" long spruce spars, I think 1/4" square balsa for the TE, something like 1/2" x 1" for the LE (I rip my own from 1/2" sheet), some 1/8" square and some triangle stock. Oh, and aileron stock. Could be some other stuff too. I'm doing this from memory (but I have built 5 of them in the last year and a half!) Be sure to go over the plans well for anything I missed. Get extra 1/16" sheeting, this is where you might screw up and need more. For ply, you'll need a little 1/4", some 3/32", some 1/32" and what ever you decide on doublers. I used 3/32" because I had it but 1/16" should be fine. Don't bother buying at your local hobby shop. Place an order with Lone Star Balsa and get enough for at least 2. It'll cost you less than the wood for one locally and you're going to want another anyway. Get lots of spare balsa, in every dimension you order. It won't go bad and I hate paying hobby shop prices. You're going to LOVE this plane! Dave
