85"Yak flight characteristic ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> 85"Yak flight characteristic ?
Page: [1]
Login
85"Yak flight characteristic ? - 5/30/2006 7:04:24 PM
discusmike
Status: offline
Sometimes when entering a loop it seems my yak does not want to go threw the loop smooth,no matter if i do a small loop or large,pull back on the elevator gently or a little more harder the plane tries to point its nose vertically.Makes it somewhat difficult to do cuban 8's and so forth,do i have my plane to nose heavy?or need more expodential?Or does the plane want to do this because its designed for 3d?I'm not sure,was wondering if someone had a easy fix for this?Thanks.
       Post #: 1
RE: 85"Yak flight characteristic ? - 5/30/2006 7:18:23 PM
Rezagh
Status: offline
discusmike,
Where is your CG set at now? Do you have any problems when landing?
What is the throw on your elevator and how much expo do you have?
Please PM me with more details of your set up and CG info. Are you using a DA50?
To answer your question, you should be able to go through a loop with no problem at all. Plane is designed for both Precision and 3D flying depending on your settings.
Thank you,
Reza
_____________________________
Quique's Aircraft Company
(in reply to discusmike)
       Post #: 2
RE: 85"Yak flight characteristic ? - 5/30/2006 7:46:18 PM
exeter_acres
Status: offline
I use mine for IMAC and it is awesome on loops and cubans... I wish I could fly as well as the plane!
Hope you work it out
Extreme Flight RC tech support
"Some are born great, some achieve greatness, and some hire PR officers."
(in reply to Rezagh)
       Post #: 3
RE: 85"Yak flight characteristic ? - 5/31/2006 1:18:49 PM
discusmike
Status: offline
This is definently the best flying plane ive ever owned,i have something wrong in my set up,im sure thats why its doing this,hopefully ill figure it out soon.
(in reply to exeter_acres)
       Post #: 4
RE: 85"Yak flight characteristic ? - 6/3/2006 10:00:53 PM
exeter_acres
Status: offline
any luck???
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU5
