new announcement about 28% Edge
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> new announcement about 28% Edge Page: [1] 2   next >   >>
Login
new announcement about 28% Edge - 5/30/2006 9:47:19 PM
rctom
Status: offline
Hi:
I am here to make a little news.
The next batch of 28% Edges is changed slightly.
The fuse is 1" longer, with the stabs staying in the same place and the rudder moving back. This change, in our testing, has greatly reduced or eliminated wing rock in a harrier.
The other change was to go to full length ailerons, all the way from tip to root. This makes the ailerons more effective at zero airspeed when you only have the prop blast to rely on. This is typical in a hover.
Same price, same plane, just improved harriers and hover.
TF
       Post #: 1
RE: new announcement about 28% Edge - 5/31/2006 6:27:49 AM
RCFREAK
Status: offline
damn, i feel so..... Meh. I would like it, but since my edge is practicly brand new, i would loose to much money purchasing a new plane.
(in reply to rctom)
       Post #: 2
RE: new announcement about 28% Edge - 6/1/2006 5:54:08 PM
Tired Old Man
Status: offline
Good call Tom.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to RCFREAK)
       Post #: 3
RE: new announcement about 28% Edge - 6/1/2006 5:56:04 PM
Tired Old Man
Status: offline
An excellent plane just became even better.
(This darn internet system I'm using blanks out all the option buttons or the first post would have been edited)
(in reply to Tired Old Man)
       Post #: 4
RE: new announcement about 28% Edge - 6/1/2006 8:24:51 PM
shogunmst
Status: offline
When will these new version of EDGES be available??? Will any be in the JUNE shipment??
       Post #: 5
RE: new announcement about 28% Edge - 6/1/2006 9:02:54 PM
Shogun
Status: offline
HA! I pretty much determined that lengthening the fuse and inch would have been just about perfect but I wound up moving the stabs 1.25 inches forward to acheive the same results with mine.
To say it's like a different plane is an understatement in the least. If you have an oder one, sell it and get the newer version when it becomes available.
Scott
(in reply to shogunmst)
       Post #: 6
RE: new announcement about 28% Edge - 6/1/2006 10:00:36 PM
rctom
Status: offline
quote:
ORIGINAL: shogunmst
Yes, they are on the way and should be here in about 3 weeks, as always dependent on US ports and railroads.
TF
       Post #: 7
RE: new announcement about 28% Edge - 6/2/2006 12:30:29 AM
Ken Bryant
Status: offline
So is the color scheme going to change at all too?
Ken
(in reply to rctom)
       Post #: 8
RE: new announcement about 28% Edge - 6/2/2006 3:12:22 AM
Tesla540
Status: offline
Shogun, how hard was it to move the stabs? Do you have any pics? Thanks.
(in reply to Ken Bryant)
       Post #: 9
RE: new announcement about 28% Edge - 6/2/2006 3:32:05 AM
Shogun
Status: offline
Tesla, relocating the stabs was actually pretty simple be to do it right you need to remove the covering from the bottom of the model so you can access the inside. I don't have any pics of the build so I can't help you with that, the completed model is here in this forum somewhere so you can read about it there. I actually changed more that simply moving the stabs forward but I beleive that relocating them made the biggest difference in the planes 3D flying abilities.
Scott
(in reply to Tesla540)
       Post #: 10
RE: new announcement about 28% Edge - 6/2/2006 4:47:38 AM
aerobatic 3D
Status: offline
Shogun,
I moved my rear stabs forward just like you did and thats all I've done. The plane still rocks like it did before, I think the fix to your plane was the enlargment of the rudder. I seen a BME 28% Edge this last weekend that was just the first flight and it was stable and its rudder was larger like your modifications. I dread making this change but I hate the wing rock and unstableness, Tom sent me new stabs hoping this would resolve it cause one of mine wasn't straight with the other side, great customer service, but I really think your rudder modification was the root to stopping the wing rocking.
Here is your post on your Edge Mods......
http://www.rcuniverse.com/forum/m_3506160/tm.htm
(in reply to Shogun)
       Post #: 11
RE: new announcement about 28% Edge - 6/2/2006 5:08:58 AM
Shogun
Status: offline
The one thing that moving the stabs forward, or the rudder aft, allows for is the ability to fill in the rudder cut outs on the inboard side of both elevators. I'm pretty sure that the improved flight performance was the result of all of my mods and not simply a single change. One thing is for sure, moving them forward was probably the biggest part of the project that I did on my plane.
Scott
(in reply to aerobatic 3D)
       Post #: 12
RE: new announcement about 28% Edge - 6/2/2006 5:20:06 AM
Cappy69
Status: offline
Aerobatic...like shogun said...I agree it is probably a combination. I myself modded the rudder...adding 1.5-2" to the height, making it look more scale...but left the stab alone. Still rocks like a SOB. Getting it pretty low now because I'm getting used to it.....but is definately a handfull to say the least to keep it locked in.
Cap
Altitude is your friend.....AHHHH, who needs friends!!!
       Post #: 13
RE: new announcement about 28% Edge - 6/2/2006 7:56:51 AM
bluemagic98
Status: offline
I ussed to think it was something with my edge till I asked one of the most talented guys in our club to fly it. He flew it right down onto the deck and said it flew just like his. here is a short video of his http://www.rivervalleyflyers.com/Vid/brian2.wmv I also fly one of toms ultimates and that has almost no rocking to it. Ill be looking for another 50 cc plane as soon as I do something foolish with one of the ones i got. I keep getting braver and braver with that Ultimate.
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
(in reply to Cappy69)
       Post #: 14
RE: new announcement about 28% Edge - 6/2/2006 1:25:03 PM
aerobatic 3D
Status: offline
Thanks Cappy69,
The next thing I was going to do was enlarge the rudder. I really wished that we had the exact thing that corrected Shogun wing rock pin pointed. I guess we could do all the mods. and get the same results, hopefully.
(in reply to bluemagic98)
       Post #: 15
