**HELP** Genesis 1st/2nd gear removal ?? :-(
Tower Hobbies
Logged in as Guest
  Printable Version
THUNDER TIGER EK4 1/8 SCALE WITH PRO-70BX - RTR
Seller:  RCJAX904
Details:   $400.00   |  1/8/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> **HELP** Genesis 1st/2nd gear removal ?? :-(
Page: [1]
Login
**HELP** Genesis 1st/2nd gear removal ?? :-( - 5/31/2006 10:31:12 PM
Scott_GTR
Status: offline
Some how my Genesis (gen3) destroyed its gear box today.
I have stripped the gear box out of the truck but can't split the 'box open as I can't get my 1st/2nd gears off.
The manual says there should be a nut at the end of this shaft, and when is it removed the gears should slip off. But my generation3 Genesis has a carrier at the end of this shaft, (something the manaul does not show so I take it it was a design change to stop flex maybe).
So can anyone tell me how to remove 1st and 2nd gear assembly????
I have noticed there are 4 bolts in the clutch to engage 2nd, two at an angle are for the spring tension to adjust shift speed.
Are the other two in line with the shaft centr line holding the gear on???
Once this is removed should the 'box split open to I can repair the damage?????
< Message edited by Scott_GTR -- 5/31/2006 10:40:56 PM >
       Post #: 1
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/1/2006 3:16:49 AM
The Real Dogman
Status: online
The carrier at the end of the shaft you ae referring to should have a small hole cross drilled in it. Slide an allen wrench of the appropriate size thru that hole and a second allen wrench thru the hole on the opposite side of the tranny on the same shaft and gently but firmly twist the carrier to the left and viola it should turn. finish threading it off and gently pull the first and second gear off the shaft. Be Careful, there is a small pin in the shaft the locates the hub on the shaft that easily falls out!!
_____________________________
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Arena/3 Tubers/Axial Comp Crawler/Raze
(in reply to Scott_GTR)
       Post #: 2
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/1/2006 8:08:41 AM
Scott_GTR
Status: offline
Dogman,
Sweet, I'll try this tonight.
Many thanks.
(in reply to The Real Dogman)
       Post #: 3
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/1/2006 6:02:27 PM
Scott_GTR
Status: offline
Dogman,
Is your instructions to remove the gears or remove 1st and 2nd gear assembly as a whole????
Or does it have to be split down for removal???
Sorry for being 'Mickey Thicky' on this.
       Post #: 4
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/1/2006 7:11:38 PM
Status: offline
Hi Scott GTR. Check out the manual for the Nemesis truck. It shows the revised break down of the transmission and shows the pilot shaft. http://www.cenracing.com/cars/manual/nemesis-manual-jpg.zip
Go to page 07 and look at 02-17 assembly. You will see the "T" Bolt that is holding the 2 speed assembly on the shaft. The 1st and 2nd gears will remove as a whole assembly. If you don't need to then don't take the 1st and 2nd speed assembly appart.
Best Regards
CEN Racing - www.cenracing.com
       Post #: 5
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/1/2006 7:33:06 PM
Scott_GTR
Status: offline
Cen,
Now I see, I am sure this is different to my Genesis manual.
So do I need to lever off the 1st/2nd gear assy to reveal the pin, as it seems to be stuck fast???
I'll give it a whirl.
Cheers.
Scot.t
< Message edited by Scott_GTR -- 6/1/2006 10:36:08 PM >
(in reply to CEN Racing)
       Post #: 6
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/2/2006 6:57:13 PM
Status: offline
Scott GTR - It should slide off the shaft. You might need to use a flat screw driver to help it come off.
Best Regards
       Post #: 7
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/3/2006 7:07:55 PM
Scott_GTR
Status: offline
I finally got my 'box open today.
Mind you I was not ready for what I found .
I thought I'd have to replace 2 or 3 gears, but oh no, only two gears have survives all the other 6 are totaled plus there is a bent input shaft.
I am in no doubt the engine puts out 5hp now!!
I don't think my Nissan Skyline's 530hp could have done a better job!!!!
Oh well. I think I may just go for a new 'box.
< Message edited by Scott_GTR -- 6/3/2006 7:09:22 PM >
       Post #: 8
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/3/2006 8:53:29 PM
The Real Dogman
Status: online
Scott For the price from eBay, you are better off going with a new tranny!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6062233469&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
These usually go for between $30-$45. And This One Is The Nemesis Version!!!!Excellent buy!!
I Have Three!!
       Post #: 9
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/4/2006 1:32:01 PM
Scott_GTR
Status: offline
quote:
ORIGINAL: dogman_1@hotmail.com
I Have Three!!
I think this is what I'll do.
I have thought about a Nemesis 2spd, but I think Ill keep the 3sp and reverse.
But with the Nemesis I can fit the better brakes. I did buy a set of Nenesis brakes from E-Bay, but found they don't fit the Genesis.
Is the Nemesis transmission housing the same moulding as a Genesis does anyone know, (ie. could be converted into 3sp + R)???????
       Post #: 10
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/5/2006 5:56:02 AM
The Real Dogman
Status: online
Scott,
Yes, The Tranny Housing Is Virtually The same, Except for the Mounting Studs For The Brakes And Output Drive Cup Bearing Size.
Before I Rebuilt My Genesis Into A Nemesis, I used The Nemesis Tranny With The Reverse And 3rd Speed In Nemesis Tranny.
This Is The Nemmi After Rebirth, Due To A Late Afternoon High Speed Encounter With A Block Wall. (Despite Breaking 3 Out Of 4 Upper Arms And Shattering The Front Brace It Stayed Running & I Was Able To Drive It Back To The Van!! Tough & Mean Ass Truck!!! )
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 11
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/21/2006 3:57:23 AM
jigga2177
Status: offline
dogman,
what's the purpose of that tube for the air filter?
       Post #: 12
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/21/2006 4:13:35 AM
The Real Dogman
Status: online
Jigga, I live in the desert where it gets very hot and dusty. Everytime I went out bashing I Would have to change filters every tank of fuel.....So I noticed Clean Air in front of the front wheels......1 +1=Clean air snorkel="Cold Air Tube"
Since, That realization I only have to clean the filter every 5 tanks!!!! WootWoot!!! I swear it changed the exhaust note too but can't be 100% positive of that.
Very easy mod! cost about $4!! Looks cool too!!!
< Message edited by dogman_1@hotmail.com -- 6/21/2006 4:15:26 AM >
(in reply to jigga2177)
       Post #: 13
RE: **HELP** Genesis 1st/2nd gear removal ?? :-( - 6/21/2006 6:02:24 PM
