RBean -> RE: H9-F6F Hellcat 60 ARF (11/27/2009 5:03 AM)
chuck993, The Century Jet retracts are not cheap. List is about $280. Some times you can find them at $230-$240. But every thing you need comes with them. Retracts, struts, air tank, air line, air filler valve, air regulator valve etc. I own three pair of them, all rotator types as in the Hellcat. They are a lot of work to install in the Hellcat because because the mounting flang is on the bottom of the retract instead of on top like the hanger nine. Also the gear needs to be mounted as deep in the wing a possible so you can have in raked forward slightly and it still be mostly in the wing when retracted. Also have to cut enlarged hole in the spar for the air cylinder and then reinforce the wing in the wheel well area. I use wheel collars on the air lines for adjusting the speed of the gear. I have found the CJ gear to be stronger than Robarts and less expensive than Seirra retracts. The only problem I have found with the CJs is they use rivets to hold the oleo sissors on, which develop slop with use. I replace the rivet with small nuts and bolts, and that solves the problem. If the gear is simple folding gear like the P-51 or P-47, I prefer Spring Air Robo Strut ready gear. I have one pair and they work great, so far. They are $130 but then you need to purchase Robo struts, and I think the CJ refill valve is better.
