Shawnusa
Joined: 3/6/2002 From: Houston, TX, USA Status: offline
Hey guys, I was wanting to know if you had to modify the Wing Spars at all to make the Ribs match it. As the written instructions clearly say "Be accurate in this procedure". My spars are cut exaclty as the templates, but do not exactly match every rib layout on the plans. There either off to the left or right. However, some do match. Also I'm alining the spars to the w-5 AND w-7. When I do this it leaves about a 1/16" gap. Where sis you do your alignment to. Anway, I just want to hear your stories and ideas. Also, when glueing the wing spars together witht the Joiner, did you use Epoxy or CA? Plans or instructions do not specify. Thanks, Shawnusa
