gibb
Joined: 1/26/2002 From: Livonia, MI, USA Status: offline
Thanks guys for the MO insight. I'm surprised that MSELBY needs so much flap. MY Z- hellcat needs significant amounts of flap at 37 lbs to land , but my 30 lbs B25 could slow down easily without them. Remember, over 10-15° and you will lose lift and increase drag. I also add a bit of elevator trim when the flaps are down. I just mixed it in and use a switch for both. For calm wind:I use about 15-25% throttle on final and then just reduce toa tick over idle as I cross the end of the field. Then at about 2-5 feet above the ground, I cut the throttle and let it sink in. For 10-20 mph head wind: same power on final leg, then reduce and hold to about 10%until touchdown. The one bad thing about the 25 is that in strong winds, you really have to fight the roll. Especially with the smallish ailerons. My buddies and I are heading to the IMAA rally of Giants this year at Muncie. Are you guys attending? Would be good to have a formation flight. My club field is about 750 feet too. Only need about 300 though. If you want a test pilot, Id be glad to fly them all. The tank in the fuse is an interesting one. I would think that the carb could pump without problems, but I sure would test it first outside of the airplane by mocking the exact location. Then I would raise the whole thing to simulate a take off and check at full throttle. Once again, idle and low throttle sync is more important than full throttle. By the way, where did you install the fuel tanks? Theres not much room in the fuse either.
