Dave McDonald
Joined: 1/4/2002 From: Eldon, MO, USA Status: offline
Mike! Don't go just yet! Just so you know, I REALLY appreciate both of you and Gibb chiming in about the Skunkworks B-25 projects! The way I see it, the more minds involved here, the better the chances are that these B-25s will have a long life. As far as the RF interference issue, you have far more knowledge of antenna theory than I do......and I'm really glad to hear that we both agree that the aluminum wing tubes shouldn't cause any problems. Steve, Glenn, TJ and myself have already discussed some other potential RF interference problems with their B-25s, and they have already made some changes based on my advice. But since you guys are here, I would REALLY appreciate hearing your opinions! My first concern was that each engines ignition kill switch was going to be located in the fuselage, with the ignition kill wiring within inches of the receiver. Plus with a throttle servo located in each nacelle, the ignition kill wiring would have been running parallel to the throttle servo leads. As soon as I saw this, alarm bells, sirens, and flashing lights started going off in my head as a MAJOR source of RF interference! Since then, they have relocated the kill switches into the nacelles, but I'd still like to hear your thoughts on whether or not you agree that this could have caused interference problems. My second concern was that originally they were going to run individual servos into each nacelle for throttle control, with the servos very close to the engine. Because of the close proximity of the servos and wiring to the ignition engines, I suggested that they install optical isolaters to minimize the ignition RF noise from being induced into the the throttle servo wiring. I would think the closer these optical isolators are to the receiver, the more effective they would be. Do you know of a better way of doing this? Or am I being paranoid here based on your experiences? My third concern was the length and the amount of servo extenisons that are being run throughout these planes. All of the servo extension that they have run are homemade of twisted wire. I think using the twisted wire is a good idea, but I dont' know the optimum number of twists per foot to minimize interference. Do you know? Do you think that these wires should also be optically isolated from the receiver? Or am I being paranoid again? My fourth concern was the use of PPM receivers in these B-25s. I agree that the PPM receivers will work fine if all of the potential RF sources are eliminated. But unfortunately, you only get one chance that way. Therefore I have strongly suggested that the Skunkworks guys use PCM receivers (JR). Are you flying PCM? Or PPM? And again, am I being paranoid here? Even if we don't agree on this stuff, make no mistake that the Skunkworks guys and myself value your opinion on these things!
_____________________________
McDDD ProBro 415
