RE: New Blackhawk Heli... A lil bigger than T-Rex
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: New Blackhawk Heli... A lil bigger than T-Rex
Page: <<   < prev  3 4 5 6 7 8 9 10 [11] 12   next >   >>
Login
RE: New Blackhawk Heli... A lil bigger than ... - 8/28/2007 4:57:33 PM
mikek0416
Status: offline
thanks on the url and will check the teethe
(in reply to tzeming)
       Post #: 251
RE: New Blackhawk Heli... A lil bigger than ... - 8/28/2007 9:20:14 PM
mikek0416
Status: offline
getting the toothe count for you and all the pics I looked at are 450s, unless I missed one when I loaded them, except under the 500 category where I have 500 pics. If you want me to order a 500 motor, etc email us.
       Post #: 252
RE: New Blackhawk Heli... A lil bigger than ... - 8/29/2007 12:31:07 AM
tzeming
Status: offline
thanks in advance Mike.
the url is http://www.rcuniverse.com/market/item.cfm?itemId=317212
where I notice two pictures in it that do not match with the rest of the photos.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to mikek0416)
       Post #: 253
RE: New Blackhawk Heli... A lil bigger than ... - 8/29/2007 12:54:45 AM
mikek0416
Status: offline
oh thank you kindly - I was on my website www.ka-planes.com looking at my 450 photos
       Post #: 254
RE: New Blackhawk Heli... A lil bigger than T-Rex - 8/29/2007 10:01:26 AM
scottyh1990
Status: offline
Hi guys,
I recently bought a new blackhawk 450, and am new to the 6ch heli scene. It came supplied with a flight simulator (a freebie) of which i eagerly tested the controller on, only to find that the throttle controll was mixing withe the main rotor controls. This is also occuring with the acutal heli, and i don't know if this is normal. I sent the transmitter back, but the supplier told me it was fine, but still sent me a new one of which does the same thing. I was wondering if anyone here knows what the problem is, or indeed if there is a problem at all. Any help would be greatly appreciated as i am only new to this great hobby.
(in reply to retired911guy)
       Post #: 255
RE: New Blackhawk Heli... A lil bigger than ... - 8/29/2007 11:11:57 AM
mikek0416
Status: offline
I see you wrote to me I will talk to you there
< Message edited by mikek0416 -- 8/29/2007 11:13:28 AM >
(in reply to scottyh1990)
       Post #: 256
RE: New Blackhawk Heli... A lil bigger than ... - 8/29/2007 11:17:32 AM
scottyh1990
Status: offline
Thanks for the reply,
yes, the throttle is affecting the head. As i said, the flight simulator has the same problems, but i dont think that it could be possible to get two faulty transmitters. a friend said that perhaps the crystals could have not been prgrammed correctly, but i havnt had time to show him the new transmitter as i only recieved it today.
       Post #: 257
RE: New Blackhawk Heli... A lil bigger than ... - 8/30/2007 11:06:21 AM
mikek0416
Status: offline
I hope that last email this morning helps you out.
Mike
       Post #: 258
RE: New Blackhawk Heli... A lil bigger than ... - 8/30/2007 1:13:13 PM
tzeming
Status: offline
not sure if your last email refer to me, but I got your email this morning , it was very useful, at least I have an idea what is the KV rating of the original outrunner for 500EP.
do you know the power output (W) as well by any chance.
when you receive the main gear spare part, please kindly post the number of Teeth. so that I can make a decision on what to buy. thanks
what kind of ccpm servo would you recommend for 500 or 450 ?
I am using towerpro 9g servo ( blue in color) . what I found is that there are some degree of end play ( loose ) when power is applied. this means that the swashplate has certain free movement.
this introduce a little bit of vibration and delay on responsing to ccpm command.
       Post #: 259
RE: New Blackhawk Heli... A lil bigger than ... - 8/30/2007 11:18:17 PM
mikek0416
Status: offline
personally, I like Hitec 55 and 65s - smoothe and reliable.
Ps getting the 500SE kit and RTF samples in next week.
       Post #: 260
RE: New Blackhawk Heli... A lil bigger than ... - 8/31/2007 5:29:47 PM
mikek0416
Status: offline
www.ka-planes.com has sales prices
< Message edited by mikek0416 -- 9/6/2007 11:37:24 AM >
       Post #: 261
RE: New Blackhawk Heli... A lil bigger than... - 8/31/2007 10:19:08 PM
Helihap
Status: offline
good time to stock up on things, thanks
       Post #: 262
RE: New Blackhawk Heli... A lil bigger than... - 8/31/2007 10:22:31 PM
TomOver
Status: offline
time for carbon 315's.
(in reply to Helihap)
       Post #: 263
RE: New Blackhawk Heli... A lil bigger than ... - 9/4/2007 2:22:36 AM
rcjetflyer
Status: offline
how goes it retired911guy? lost your address so hope to catch you here
Haven't heard from you in ages, here as I am sure where you live it has been so hot you could not do anything. Finally today I went out in the morning and flew the Blackhawk 500 electric around a bit did some loops (if that is what you call them they were so lopsided) but at least it will loop. Also tried some rolls, same sorry thing but it will do it. I am so rusty that I can hardly fly anymore. But I am going to try to get out more often.
Went out again this afternoon and did some loops that were a little straither and a roll that was still sloppy. I am getting a little more of seeing the heli in the air so I feel more confortable flying it away from me. Also I am getting new glasses soon so maybe I will be able to see it even better. Also took the MX400 out and did a loop and roll with it, it uses a lot of air for a loop so I will have to get some adjustments on it to get it to do better.
Also I want to set them both up for inverted after I get some time under my belt. It has been almost 2 years since I have flown a helicopter around so I have a long way to go
BUT - - - - - - HOW ARE YOU DOING WITH YOUR HELICOPTER FLYING???? DROP ME A LINE AND TELL ME WHAT'S GOING IN YOUR WORLD
Regards
Bailey
       Post #: 264
RE: New Blackhawk Heli... A lil bigger than... - 9/4/2007 2:25:37 PM
tzeming
Status: offline
