HS 5245 to nylon gear questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HS 5245 to nylon gear questions
Page: [1]
Login
HS 5245 to nylon gear questions - 6/2/2006 2:46:48 PM
Rudeboy
Status: offline
When swapping out the metal gears in the HS5245 for the nylon gears of the HS225 do you retain the "bottom" ball bearing of the 5245 or do you change it to the bronze bushing of the 225?
Can I just pry out the metal ring out from the 225 main gear and will the nylon main gear then accept the ball bearing from the metal gear? Does the bronze bushing also come with a replacement nylon gear? If it doesn't, and for some reason the ball bearing doesn't fit the nylon main gear, then I have a problem...
Do the replacement nylon gear sets come with a suitable servo arm screw, or do you have to find something suitable yourself? What exactly is included in these replacement gear sets?
Is the output spline of the metal gear and the nylon gear the same: are the servo arms interchangeable?
_____________________________
Revver Brother #33
...I think it needs more power...
       Post #: 1
RE: HS 5245 to nylon gear questions - 6/2/2006 5:28:54 PM
MikeMayberry
Status: offline
It would be best to use the bearing instead of the bushing and yes, it will fit if you completely remove the bushing.
Yes, the gearset do come with a screw and the splines and horns used are the same.
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to Rudeboy)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
