RE: New CDI - opensource project JMJ and Bigboat
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Page: <<   < prev  8 9 10 11 12 13 14 15 16 [17]
Login
RE: New CDI - opensource project JMJ and Bigboat - 11/4/2009 12:58 PM
fb72
Score: 100
Last Login: 11/20/2009
Status: offline
Yes, i was using a homemade sparkcoil, im only using it for testing though. I have a factory-made sparkcoil on the way.
I wound the HV-coil with the specs on the schematic, same wire sizes/amount of winds.
Hide Signatures
(in reply to Bigboat)
       Post #: 401
RE: New CDI - opensource project JMJ and Bigboat - 11/4/2009 2:29 PM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
It's normal you distroy your homemade sparkcoil, I distroy maybe 10 of this homemade coils.
Sparkcoils need more isolation as normal, also between the wires must be placed isolationpaper.
Wait for your factory-sparkcoil befor you test the CDI again.
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to fb72)
       Post #: 402
RE: New CDI - opensource project JMJ and Bigboat - 11/4/2009 2:45 PM
w8ye
Score: 133
Last Login: 11/21/2009
Status: offline
when winding ignition coils, it is extremely important to keep your windings level and to have fish paper between each layer.
Your goal is to have minimum voltage difference between two adjacent wires to minimize flash over.
If there is several hundred volts difference between two adjacent wires, you are going to loose the ignition coil.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 403
RE: New CDI - opensource project JMJ and Bigboat - 11/4/2009 10:47 PM
fb72
Score: 100
Status: offline
wasnt planning on using the homemade coil, i knew i was going to fry it pretty quick because i wound it with a drill and i didnt insulate between the layers.
Hide Signatures
(in reply to w8ye)
       Post #: 404
RE: New CDI - opensource project JMJ and Bigboat - 11/19/2009 3:19 AM
fb72
Score: 100
Status: offline
Ok so i finally got everything i needed to fully test my ignition, But when i power it up, it is very erratic, the microcontroller doesnt seem to be doing anything. I made a ground shield that covers the HV circuit and that filtered out the noise and now it doesnt respond to anthing, it just cycles. I havent tried re-programming the PIC yet but do you have any suggestions for things that i can check?
-Thanks
Hide Signatures
(in reply to fb72)
       Post #: 405
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
