RE: New CDI - opensource project JMJ and Bigboat
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $18.95   |  11/3/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: New CDI - opensource project JMJ and Bigboat
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 11:09 AM
Bigboat
Score: 100
Last Login: 11/6/2009
Status: offline
You need a unipolair hallsensor.
Bipolair needs a switching magneticfeeld N/S/N/S to switch, unipolair not.
Choose a higer voltage for the hallsensor then your batterie voltage, 4,5 till 6 Volt isn't high enough.
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to jirvin)
       Post #: 26
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 1:25 PM
jirvin
Score: 100
Last Login: 6/27/2009
Status: offline
Hello Rob
I feel more informed in my searching for the hall unipolar type
Also available locally is this
IC, sensor, Hall Effect, unipolar, SS443A
Details from data sheet
Am I close to the correct type
cheers Jeff
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Bigboat)
       Post #: 27
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 1:34 PM
Bigboat
Score: 100
Status: offline
You can use this one without any problem.
Hide Signatures
       Post #: 28
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 2:46 PM
jirvin
Score: 100
Status: offline
Thankyou Rob
I have spent day going around in circles looking at available online Australian electronic shops
I find to my embarrasment that the final hall was originally listed on the original site:-
http://home.online.no/~jon-mj/cdi_ignition.htm
Now to find most of other components_
have found Bt151 locally
Your circuit lists "Flashlight" is this a led or incandescent?
Any thing special about opto TIL111 "standard led photodiode"?
here i find 4N28/4N25
it appears similar except the pin 2 is anode and pin 3 is cathode
wheras til111 has pin1 anode and pin2 cathode from research?
cheers Jeff
Hide Signatures
       Post #: 29
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 2:54 PM
Bigboat
Score: 100
Status: offline
It's a bright-LED (they call it whitlight-LED)
Any opto is good, I was using TIL111 and 4N25.
Yep.
Hide Signatures
       Post #: 30
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 3:45 PM
jirvin
Score: 100
Status: offline
Thanks again Rob
Im getting closer
Capacitor for storage C6 is what we call
Greencap, Polyester or"Mylar"
I have found 630v dc 470nf 26mm lead spacing ?
L4 1uH is this a RF Choke type?
IC3 LP2950CZ from specs is 100maH +5v
I have found similar 78L05 100maH low power
This leaves just the capacitors and resistors
plus programminf pic (next week!)
and pc Board
cheers Jeff
Hide Signatures
       Post #: 31
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 4:18 PM
Bigboat
Score: 100
Status: offline
Any type is good if the voltrage is high enough > 400Volt
Yep and it lookslike a 1/2 Watt resistor.
A 7805 doesn't work becourse the voltagedrop is to high (3 Volt)
If the voltage from yor batterie is 6 Volt, after the regulator it's only 3 Volt.
You realy need a type with a voltagedrop >/= then 1 Volt.
BTW, why don't you sleep......it's now 17 h in the Netherlands, I acpect it about 5 o'clock in Australia (?)
Hide Signatures
       Post #: 32
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 4:25 PM
jirvin
Score: 100
Status: offline
Thanks Rob
Sleep soon- now 1.30am - home with a brocken arm plenty of time off
(fell of my nice BMW bike)
Last for today
I find cheap JDM programmers on Ebay - will research later.
I can see 16F628A pic not 16f628 - will reseach to see if compatible with your hex?
cheers jeff
Hide Signatures
       Post #: 33
RE: New CDI - opensource project JMJ and Bigboat - 6/25/2006 4:38 PM
Bigboat
Score: 100
Status: offline
Build your own programmer, it's not diffecult.....only a few componets.
The A-type is OK, I forgot to write the A into the schematic.
Hide Signatures
       Post #: 34
RE: New CDI - opensource project JMJ and Bigboat - 6/26/2006 2:03 AM
jirvin
Score: 100
Status: offline
Hello Rob
On the schematic the capacitors c3,c7 are listed as 0.1u (100n) + (electro type?)
These have been difficult to find - must be looking for the incorrect thing?
Could these be replaced with greencap "mylar" type similar to the c8,c4,c5 100n
cheers Jeff
ps found the low drop out 5v regulator
Hide Signatures
       Post #: 35
RE: New CDI - opensource project JMJ and Bigboat - 6/26/2006 2:41 AM
captinjohn
Score: 135
Last Login: 11/8/2009
Status: offline
Guys.....there is a lot of talk about electroniccs here. What some us wants to know does this system work good for airplanes? Also what is the cost of the ignition system ready to go? Thanks Capt,n
I never met a engine I did not like!
Hide Signatures
       Post #: 36
RE: New CDI - opensource project JMJ and Bigboat - 6/26/2006 3:02 AM
jirvin
Score: 100
Status: offline
Yes a lot of talk about electronics.
It is an open source project where this talk helps develop the goal to a DIY CDI for engines.
I take it on faith that it works.
The original thread (see page1) shows video of strong spark and success with the project
Rod has his mounted on a gas engine - see page1 of this thread.
Cost? This is DIY so far around $30AUS plus 3 days of research (priceless!)
it is cheaper to buy completed project ie Desert Aircraft, CH, so on at $200 or more if you want it now.
cheers Jeff
Hide Signatures
(in reply to captinjohn)
       Post #: 37
RE: New CDI - opensource project JMJ and Bigboat - 6/26/2006 1:28 PM
tomservo
Score: 100
Last Login: 8/12/2009
Status: offline
What's the feasability of using an optical sensor in place of the hall effect sensor? similar to what they do to sense engine RPM with some tachs? it would just require painting the flywheel white and black, and possibly a small LED for a light source. I want to build a CDI for a small engine, but without removing my magneto (it supplies accessory power as well) and the stock flywheel (with two magnets).
Hide Signatures
       Post #: 38
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 1:48 PM
tomservo
Score: 100
Status: offline
Replying to myself - did a little research tonight, and it seems the recommended hall sensor outputs a mere .4v - would it be possible to use this optical sensor ( http://www.taosinc.com/images/product/document/trs17xx-e14.pdf ) with it's output of ~2v nominal? I know it's not a focused type sensor, but it should work fine if placed within 1-2mm of the flywheel. There's another sensor that could be used - but instead of a straightforward output voltage, it has a phototransistor and while I can troubleshoot a dead circuit, I have no idea how to wire this in to work as a switch - ( http://www.optekinc.com/pdf/OPB740.pdf )
Any help would be great, otherwise I'm willing to just try it on.
Hide Signatures
(in reply to tomservo)
       Post #: 39
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 2:31 PM
Bigboat
Score: 100
Status: offline
@tomservo,
Why will you risk false light to stop your engine with a opto ?
Hide Signatures
       Post #: 40
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 3:59 PM
jirvin
Score: 100
Status: offline
I have spark- ouch!
quote:
ORIGINAL: jirvin
All very messy at the moment
Operating at this stage without scr by earthing the capacitor C6 to earth to generate spark.
Using 4 cell nicad (5.2v) - I can get a solid spark every 1 sec?
Faster tapping to earth doesn't generate more sparks.
At this stage many unknowns -
4 cell nicad sufficient?
100n = 0.1u c7 greencap/mylar sufficient - OK?
0.15mm to wind 400 turns L1 and 8 turn L2(my mistake should have used 0.2 on circuit)
scr BT151 will be inserted when I can work out triggering before pic arrives and is programed
Is 5v sufficient to trigger scr?
Use of cheap ignition coil from pocket bike? - Need to order CH coil!
Before I was convinced I had a working circuit - a strong shock woke my brocken arm up
Poor quality photos from web cam showing circuit and coil.
Cheers Jeff
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 41
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 5:14 PM
Bigboat
Score: 100
Status: offline
I use 5 cells, but 4 cells are enough to test.
Thats not the problem of your powersource, but your fastness
0.1 uF is a littlebit low, use 470nF/400VAC / 600VDC atleast
No problem, have to work.
5 Volt is (to) high for a BT151, he will ignite on 0.8 Volt allready (don't forget a resistor into the gate!)
Why to order a new coil, I use also a cheap pocketbikecoil.....BUT, don't forget to ground the metal of your coil to the sparkplug and powerboard, otherwise it isn't work !!
OEPS.......
Hide Signatures
       Post #: 42
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 5:40 PM
jirvin
Score: 100
Status: offline
Thankyou Rob
0.1 shown on circuit diagram will try larger value- off to the shops in the morning!
I will include r3, c3 and r4 onto test board and use this to trigger.
Thankyou- I was carefull to do this - I get a solid spark but tapping faster than 1hz shows no spark.
cheers Jeff
Hide Signatures
       Post #: 43
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 7:13 PM
tomservo
Score: 100
Status: offline
Rob: On the engine I want to put this one on, the area around the flywheel is enclosed and no light will enter. So for this case, it could be a perfect solution... Since I have to keep the magnets on the flywheel. I can just paint the flywheel black and use a white line to trigger. (or vice versa, as the case may be) Now, on my G23 in my boat, I will use a hall sensor Any idea if one of those sensors I linked to will work? I can't even put the hall sensor on the other end of the crankshaft, as there is a gearbox there..
Hide Signatures
       Post #: 44
RE: New CDI - opensource project JMJ and Bigboat - 6/30/2006 8:03 PM
Bigboat
Score: 100
Status: offline
Don't forget, you have to adjust (~40 degrees BTDC) the (any) sensor befor you can use the cdi.
Any sensor will do the job, also optosensors, but choose a IR-sensor not a normal LED-opto.
The switch between high low is the point to go into the advangetable of the cdi.
If the window of the sensor is 5mm befor swithing, you have to notice you have to calculate this distance (=time) within you timing.
Hide Signatures
       Post #: 45
RE: New CDI - opensource project JMJ and Bigboat - 7/1/2006 5:01 AM
tomservo
Score: 100
Status: offline
Good to hear! Thanks, Rob! For future searching, is any particular voltage level necessary to trigger the advance?
Hide Signatures
       Post #: 46
RE: New CDI - opensource project JMJ and Bigboat - 7/1/2006 1:28 PM
Bigboat
Score: 100
Status: offline
You have to notice, a trigger is a digitalsignal (0 > 5 > 0 Volt) and not a analogsignal.
If the signal is analog, _somewhere_ in this analogsignal you reach the triggerpoint, but when do you reach this point.
There are optocouplers with a trigger output, I don't know witch one.
Normaly the half of the source voltage is the trigger voltage.
Hide Signatures
       Post #: 47
RE: New CDI - opensource project JMJ and Bigboat - 7/1/2006 4:39 PM
tomservo
Score: 100
Status: offline
Thanks again, Rob - I found an application diagram showing the optosensor being used in a logic level circuit exactly as we are using the Hall sensors - but with a 15k resistor to ground instead. So I'll order a 10k and a 15k resistor and see what works better...
I should be able to trigger by painting the flywheel black except for a small (trigger) section which i can paint white or polish. The resolution of the sensor is ~1mm so I shouldn't run into problems with timing it. I'll let everyone know how it goes once I've gotten it all sorted out.
< Message edited by tomservo -- 7/1/2006 4:43 PM >
Hide Signatures
       Post #: 48
RE: New CDI - opensource project JMJ and Bigboat - 7/2/2006 2:17 AM
jirvin
Score: 100
Status: offline
quote:
ORIGINAL: Bigboat
Hi Rob
I wonder is this C7 you are suggesting to be "470nF/400VAC / 600VDC" it looks more like C1?
I have used greecap/mylar type for C7 0.1u as per circuit diagram - is it correct to change this to 470nf (0.47u)?
cheers Jeff
Click for fullsize
Hide Signatures
       Post #: 49
RE: New CDI - opensource project JMJ and Bigboat - 7/2/2006 11:39 AM
Bigboat
Score: 100
Status: offline
You're right, it have to be 0,1 uF/16Volt type.
I got a old schematic, not the new one I put on my site, sorry.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.312RCU1
